loading
A zeer pot is an evaporative cooler used in rural Africa and the Middle East to keep vegetables fresh. They consist of two terra cotta pots, one nested inside the other, with the gap between them filled with wet sand. The sand serves as a thermal mass that helps keep the pot cold once it has cooled down, and acts as a wick to spread the moisture up the walls of the pot. When placed in a shaded, breezy location, the evaporation of water off the outer surface chills the pot. If you have a good breeze, or a fan powered by a solar panel blowing the pot, the pot can get quite cold. Imagine that chill you get when you step out of a pool when the wind is blowing. Now imagine that wet wind chill going on all day. That's what the pot feels with a constant breeze.
Unless the air is very dry and the pot is exposed to a constant breeze, they generally do not become as cold as a refrigerator, but they will keep vegetables fresh for a couple of weeks. If you do have cool dry air and a constant stiff breeze, the interior of a zeer pot can chill down to around 40˚F.
Think of it as an open-cycle refrigerator. Conventional refrigerators evaporate a refrigerant in a closed circuit to absorb heat from their interiors, then compress the refrigerant vapor in the coils in back to condense it and to expel heat. The zeer pot simply uses water as its refrigerant, and leaves the condensation to nature.
Zeer pots were re-discovered and popularized in the early 2000s by the Nigerian teacher Mohammed Bah Abba. By manufacturing and mass distributing zeer pots to the poor, he was able to bring refrigeration to tens of thousands of impoverished farmers and home makers, enabling them to extend the usable life of their produce from days to weeks. For his efforts Bah Abba was awarded the Rolex Award for bringing life-changing technology to people in need.
In the under-developed parts of Africa and the Middle East, zeer pots use custom made pots prepared by local potters. Here in the developed world, we need to settle for pre-made pots from the hardware store. There are some drawbacks, but also some advantages afforded by these limitations, as you will see.
What makes this zeer pot practical?
There are other zeer pot instructables out there, but this one is optimized for practicality. If the capacity is too small, the cooling capacity too low, or if it an eyesore or is annoying to use nobody would want to use it. This zeer pot uses a large glass pot lid, has an interior basket divider, and sits on a rolling cart. It even has a layer of decorative pebbles over the sand to make it look pretty. The terra cotta pot legs hold the pot off the rolling cart with enough clearance to let the bottom surface contribute to evaporation; this adds about 10%-15% more evaporative surface. The inner pot is bolted down so that it doesn't float up when you charge the pot with water. Nearly everything I used in this project was purchased at a hardware store, and it can be made in a few hours, plus a day to let the sealants cure.
I will be building a zeer pot array for A Place for Sustainable Living in Oakland (California) based on this design. The goal is to use an array of zeer pots to displace the use of at least one of their refrigerators. The design shown here is the outcome of my experimentation with making zeer pots for them.
(Be sure to read all the notes to all of the photos. Many important details are listed there.)
Parts list with prices
Prices are rounded to the nearest dollar. (I must admit, this is by no means the inexpensive original African zeer pot, which cost $2 to make. You're going to spend well over a hundred dollars on this design. This one is for people are intentionally going out of their way to go off grid or to pursue sustainable options.)
Items are mostly from Orchard Supply Hardware (Berkeley, CA). The pot lid was from Kukje market (Daly City, CA), and the sandwich basket was from Web Restaurant Store.
  • 18" unglazed terra cotta pot— $30 @ Orchard Supply Hardware
  • 14" terra cotta pot—$15 @ Orchard Supply Hardware
  • terra cotta pot feet, quantity: 7— $1.79 each, so about $13 @ Orchard Supply Hardware
  • heavy duty planter caddy with five casters—$30 @ Orchard Supply Hardware
  • 50 lbs of sand; the finer the better, pre-washed — $6 @ Orchard Supply Hardware
  • 4" long 1/2" bolt
  • 2" washers for a 1/2" bolt, quantity: 5
  • jamb nuts for 1/2" bolt, quantity: 4
  • Refrigerator thermometer: $8 @ Orchard Supply Hardware
  • Silicone Sealant—$5 @ Orchard Supply Hardware
  • 13.5" glass pot lid — $8 @ Kukje Market (Korean markets usually have these; wherever you are, if there's a korean market or housewares shop, you're in luck.)
  • sandpaper
  • 12" diameter sandwich basket— $7 at Web Restaurant Store
  • 8" eyelet or hook bolt and a pair of nuts and washers— about $6 @ Orchard Supply Hardware
Note: won't work as well in high humidity
If you live in a hot and humid area, the zeer pot probably won't work well; high humidity results in much less evaporative cooling. (However, a friend of mine who used a zeer pot to cool water in a humid part of Africa tells me that even with the humidity, it worked surprisingly well, so this is not definitive.)
Note: direct sunlight will cancel out all cooling effects
On the day I was doing the zeer pot seminar at the Place for Sustainable Living, we accidentally left one in direct sunlight. The amount of heat imparted by the sun totally overwhelmed the evaporative cooling effect. The cooling is supposed to come strictly from wind-induced evaporation, not from evaporation due to sun exposure. Sun exposure causes evaporation by imparting heat; wind exposure causes evaporation by lifting away water molecules, which carries away heat proportional to the heat it takes to evaporate the quantity of water carried away. If you do build a zeer pot, make sure you keep it in the shade for best effect.
Note: outer pot must be unglazed clay or terra cotta
At the hardware store, I saw a lot of fake terra cotta pots made of orange plastic. These are not usable for the outer pot of the zeer pot; the zeer pot cools by wind evaporating water that has been wicked through the outer surface. Plastic fake terra cotta is not porous, and will not work as an evaporative surface.
Glazed terra cotta pots also don't work for the outer pot. The inner pot doesn't necessarily have to be made of unglazed terra cotta, but the outer pot must be unglazed because glazed pots won't wick moisture to the outer surface for evaporation.
Note: many medium sized zeer pots work better than one giant zeer pot
The ability of a zeer pot to cool its content depends on the surface area to volume ratio. As you make the zeer pot larger, the volume will increases proportional to the cube of the linear dimensions, but the surface area only increases proportional to the square of the linear dimensions. Because the volume increases much faster than the surface area, one huge zeer pot will actually perform much worse than several smaller zeer pots. The size of the zeer pot in this instructable is about as large as you can make them while having a practical rate of cooling. You can always make them smaller; making them larger is not likely to give you reasonable performance. If you are serious about going off-grid, you would do better to make several zeer pots of this size than to make one huge zeer pot.
Step 1: Prepare the Central Bolt, Bolt Shut the Hole on the Outer Pot
(Be sure to view all of the photos above; much of the explanation is contained in the photo notes.)
In this practical zeer pot design, we have a limitation that I turned into an opportunity. The terra cotta pots that we have access to have holes in the bottom for drainage; these need to be plugged so sand and water don't drain out the outer pot, nor into the inner pot. I have found that it is insufficient to merely plug the holes; zeer pots also have another annoying problem where the inner pot will try to float up as you wet the sand in the space between the pots. In order to solve both of these problems, I use a 4" long 1/2 diameter bolt, and a bunch of nuts and broad washers and a bit of silicone sealant to seal the holes in both pots. The secondary benefit of this is that the inner pot can't float up because it is bolted to the same bolt that seals the outer pot. This way, you can be generous with charging the sand with water without worrying about the inner pot floating up.
The first thing you need to do is to put a pair of broad washers on your bolt, put some silicone sealant on the threads, and tighten them down with a nut. Then, seal around the nut with more sealant.
While the sealant is curing, use your sanding block to remove the clay burr around the hole of both pots. Be sure to sand off the burr both on the inside and the outside of the hole until the washer can lay flat against the pot. If you do not remove the burr, water will leak past the hole.
Now, it is time to seal the hole in the outer pot. This works best with an assistant helping you. Lay the pot on its side, and put some silicone sealant on the clay around the hole both the inside and outside the pot; insert the shank of the bolt through the hole, and have your assistant thread on a washer and bolt it down from the other side. Wipe up any sealant that squeezes out around the washer. Then smear sealant around the nut and bolt to prevent water from leaking out around the threads.
Step 2: Prepare the Washer on the Bolt to Seal the Inner Pot
Turn the outer pot upright, and rest it on pot feet on your rolling pot cart. Put three pot feet into the pot near the bolt, and thread another washer onto the bolt such that when you put your washer down on the nut, the top level of the washer is just a tiny bit higher than the top of the pot feet. The washer must not have its upper surface lower than the upper surface of the pot feet; if it does, the inner pot will rest on the pot feet, and won't have its hole pinched tightly by washers from above and below.
Add a little bit of sand to the outer pot; you want just enough to fill the places that will be hard to get to once the inner pot is in place. Be sure there isn't sand on the washer or pot feet; the sand may prevent the inner pot from sitting flat on the washer, and will prevent a good seal. If you decide to dampen the sand to make it more easily shapable, do so BEFORE you put it into the pot, and add water using a spray bottle only until the sand has the consistency of brown sugar. Any more, and the sand sticks to everything.
Once the washer is in place, seal the threads with silicone, and thread on the nut that holds the washer in place. Put some silicone on the washer so that it will seal against the bottom of the inner pot, and rest the inner pot on that washer. Then put some sealant around the hole on the inside, add another washer to the bolt, and pinch it down with a nut. Seal the threads and the gap around the nut with silicone, and wipe up any silicone that squishes out around the washer.
(Unfortunately, I don't have a picture of the last step where we tightened down another washer to pinch down the inner pot.)
Variation: inner pot nested an inch lower
In the photos above, I show the pot legs used as spacers positioned upright. You can also position them laying on their sides so that the inner pot sits about an inch lower. (If you do this, be sure to use sand paper or a file to remove the clay burrs from the side edges of the pot feet, or else the inner pot won't sit properly on these spacers. Also, you can use a shorter bolt; I don't know precisely how much shorter, but probably about an inch shorter.) You can see from some of the photos in the other steps that the inner pot's upper lip sits about an inch above the later of decorative rocks. While this affords a little bit more evaporative surface, it also means the inner pot's upper edge is not surrounded by as much thermal mass as it could. Having the inner pot nested a little bit deeper also means you can use a couple of quarts less sand, which will also make the completed zeer pot just a bit lighter.
The next zeer pot I build will be this variation.
Note: Be sure the pot feet are close to the central bolt
I made a couple of mistakes in the pictures which show damp sand in the pot. Firstly, I put too much water in, and the sand started to stick to everything, which was a real hassle. Secondly, the pot feet were too spread out, and I had to move them back toward the central bolt. The reason you must have the pot feet close to the center is that the bottom of the inner pot actually has a raised perimeter. (This slightly raised perimeter can be seen in the photo from the prior step which shows me sanding the burr away from the hole.) If the pot feet end up contacting the raised perimeter, the part of the pot right around the hole won't touch the washer that you matched to the height of the pot feet, and you won't get a good seal around the hole of the inner pot.
Step 3: Sand Down the Inner Pot If Pot Lid Won't Fit
When you buy your inner pot, you should bring your pot lid to find one that fits well. However, please be aware that terra cotta is an imperfect material, and the pots will not likely be perfectly round. Because of this, you should use some sand paper to sand the inner pot's upper lip to make the lid fit.
Try to get the lid to fit as well as you can, and note where it contacts the terra cotta. Mark those areas either with pencil or perhaps with chalk. Use the sand paper to sand away the contacting areas, and keep doing this until the lid fits right. In our case, it took several hours of very careful checking and sanding to get the two zeer pots to fit their lids well.
Wipe up or vacuum up all the terra cotta dust before continuing.
Step 4: Optional, for the Sheet Metal Blackbelts: Add a Thermometer.
If you really want your zeer pot to have that extra nice touch, get a piece of sheet metal, and cut out a bracket to mount your refrigerator thermometer. You'll need a bot and nut that fits the vent hole of your lid to lock down one end of the bracket; the other end will thread through the same screw that holds the handle onto the pot lid.
With the thermometer mounted on the lid, you can tell the temperature at a glance. Since the warmest air in the zeer pot rises to the top, you'll know that the temperature inside will be cooler than what the thermometer indicates.
Step 5: Fill the Gap With Sand, Add Water, and Top With Decorative Rocks
Firstly, adjust the four pot feet on your rolling platform at this time so that they are evenly distributed. Once the sand is in and the pot is wet, the zeer pot will be very heavy.
Use a funnel to add sand. You will likely end up using all 50 pounds of sand. Add more if needed; we ended up adding a couple of quarts of extra sand you want about 1/2 inch of a gutter going all the way around, which you will fill with decorative rocks after you wet it all down.
Before adding water, let all the sealant on the bolts and washers cure for at least 3 hours, or overnight for best results.
Add water one quart at a time; the sand will settle, and you will probably need to add a bit more sand when the pot is saturated. When the sand is saturated, you can add the decorative rocks, and perhaps a bit more water. The rocks are not just for looks; when you re-wet your pot, the rocks dissipate the water that you're pouring into the gutter so that the stream of water doesn't cut a pit into the sand.
Once the pots have their sand saturated with water, the pot will darken from water wicking through the terra cotta. Put the pot in a breezy area for the initial cool down. A breeze is absolutely necessary; it simply will not cool down enough without it.
A decorative trim is one of those things that sets this zeer pot apart; people are more inclined to use beautiful things. A zeer pot that looks really nice is not going to be something you're embarrassed to use.
Note: if you are using beach sand, wash the sand to remove salt
If you decide to use beach sand to fill your zeer pot, be sure you wash the sand in a couple of changes of water to purge it of salt. Salt will contribute to the mineral build up on the terra cotta that lessens the cooling effectiveness of the zeer pot.
Note: water will likely pool in the inner pot after saturation
Do not be alarmed if some water pools up inside your inner pot during the initial cool-down after you saturate it with water. Use a sponge to soak it up and wring the sponge over the decorative pebbles to return the water to the sand.
If water accumulates inside quickly, you probably have a leak, which is a whole different problem. If your inner pot is cracked, you will need to replace it. If your washers and nuts are not well sealed, you will need to let the whole thing dry out, and re-seal the entire thing, leaving at least a few hours for the sealant to cure.
Step 6: Add a Handle to the Inner Basket
Get your eyelet bolt, and a pair of nuts and washers, and bolt it onto the sandwich basket as close to the middle as you can. The basket should be pinched tight between two washers. This inner basket gives you an extra platform to put stuff on, and is one of those features that makes this zeer pot practical compared to some of the other "first world" hardware store zeer pots you may have seen.
Insert the basket into the zeer pot, and put the lid on. Adjust the eyelet bolt such that it is as high as possible without touching the glass lid. You want the eyelet bolt to be useful as a handle even if the basket is filled with fruit or other items.
Step 7: Root Cellar Variant, and Important Notes About Usage and Limitations of the Zeer Pot
You should moisten the zeer pot with a quart of water three times a day. If you store your water in the zeer pot, or have a dedicated water chilling pot, you will have the best results, since the water you add will be cold already, and won't increase the temperature of the pot.
Root cellar variant
One neat variant for keeping root vegetables and scallions fresh is to build your zeer pot, and to fill the inner pot half way up with damp sand. Then, burry your carrots and beets in the sand to store them. Damp sand will keep your root vegetables as fresh as possible by keeping them alive. You will find that they remain crisp for longer this way. Also, if you have scallions, burry the root parts in damp sand to keep them fresh. This works even better than simply keeping them cold.
Please note:
  • The zeer pot will eventually accumulate mineral build-up. Use hot water and a sponge, or perhaps a bit of lemon juice to dissolve away the minerals that crust up on the outside of the zeer pot.
  • The zeer pot will not be as cold as a refrigerator; it will be cool, and it will keep your food cool, but it will not chill a hot container of food down to safe temperatures.
  • The zeer pot needs a breeze to cool. If you have a good breeze all the time, or perhaps a small fan powered by a solar panel, the pot can get quite cold. Imagine that chill you get when you step out of a pool when the wind is blowing. Now imagine that going on all day. That's what the pot feels with a constant breeze.
  • High humidity will result in reduced performance. However, a friend of mine who used a zeer pot in a hot humid part of Africa told me that it still worked "shockingly well", so it might just work. But keep it in the shade, with a breeze.
  • Zeer pots actually perform better than refrigerators for many vegetables; vegetables wilt in the refrigerator because the condensation on the cooling tubes dries out the air. Refrigerators blow a lot of air over a little chilling surface that is really cold, causing the air to dry out. In contrast, the air in the zeer pot is chilled over a much larger surface that is only a little bit colder. This minimizes condensation; also, since the surface inside the pot will be moist terra cotta, the air inside will have as much moisture as possible, which keeps vegetables crisp in spite of not being as cold as a refrigerator.
The zeer pot is a greener option only if you use it according to the following rule:
  • These things can evaporate a couple gallons of water a day if you have a good breeze, especially if the weather is dry and warm. If you multiply this water consumption by several zeer pots, this can be a considerable water consuming appliance. I don't intend to unleash upon the world a device that wastes water in lieu of using electricity, especially in California, where we are experiencing a drought; I expect that everyone who uses these zeer pots to use a bucket to catch the gallons of water that you would normally waste while waiting for the shower to warm up, and to recover this water for the zeer pot. That way, you're saving electricity without using any additional water. Or, go ultra-sustainable and use captured rain water.
<p>The breeziest place in my yard is right next to my AC unit outside, which also has a constant supply of very cool water from the evap. coils, few simple design changes....arduino temp monitor (http://www.raywenderlich.com/38841/arduino-tutorial-temperature-sensor).. some more tweeks... and BAMN!! </p>
<p>Excellent idea.</p>
<p>Can you provide a temperature reading of the inside of the pot, compared to the outside? <br></p><p>A semi permanent installation of one of these next to a rain barrel would be a good green combination, especially if the &quot;first flush diverter&quot; sent the waste water to this.</p>
<p>Someone did some performance measurements of the zeer pot for the California state science fair:</p><p></p><p><a href="http://www.usc.edu/CSSF/History/2003/Projects/J0226.pdf" rel="nofollow">http://www.usc.edu/CSSF/History/2003/Projects/J022...</a></p><p>he found that the temperature inside dropped to about 23.5˚F below ambient, with an inside temperature of 59˚F when the ambient temperature was 82˚F.</p>
<p>Unfortunately, the Place for Sustainable Living presently has the zeer pots I built for them indoors, where there isn't a breeze, so I don't have a reading for how effective it is with a breeze under regular use. Without a breeze, the interior temperature is mildly cooler, something like 5˚-10˚F, depending on ambient conditions. The plan is to eventually have them in a permanent home where it is always breezy, but until then, the best I can tell you is that on the first night we chilled the pots in the breeze, the temperature reading from the thermometer ranged from 15˚-20˚F below ambient by midnight, with a temperature of about 50˚.</p><p>For a table of lowest achievable temperature vs. ambient temperature and humidity of someone else's zeer pot, see this: <br><a href="http://rebuildingcivilization.com/content/build-evaporative-refrigerator-no-moving-parts-no-electricity" rel="nofollow">http://rebuildingcivilization.com/content/build-ev...</a></p><p>(The table attached to this comment is a screen shot of the table in the link above.)</p><p>I suspect heir zeer pot didn't have as much evaporative surface area s the one I built, so I don't know if the data translates, but this should give you some idea of what you can expect.</p>
<p>The canvas bag filled with water/large olla in a doorway with a cross-breeze is also used to cool a home interior in non-humid areas. I plan to build a few of these Zeer Pots and put them to dual use! Great 'ible - Thanks!</p>
<p>Among the best all time instructable I've read. Detailed, with rationale for the fiddly parts, even trouble-shooting advice! Very well done, Thank You.</p>
<p>Thanks! I'm a detail-oriented, quality-obsessed kind of maker. Check out my other instructables if you like this style. ^_^</p>
Great instructable! Glad that you didn't make outrageous claims of what this could do, you were honest and straightforward.
<p>Thank you for this well done step by step. Do you think the zeer pot would also work if I buried the pot in gravel?</p>
<p>No; gravel does not wick moisture the way sand does. Also, the pot cools by evaporation induced by air passing over its sides. If you bury the pot, it will not get sufficient air flow to chill well. </p>
Thank you for taking the time to reply. Perfect I shall try this summer the way you say is best and looking forward to let you know!
<br>Bharat Chopade's profile photo<br>Bharat Chopade<br>Public<br>Yesterday<br>The air cooling system that require less electric power than A.C. also give humidless air by using some green power and some electric power.<br>This system will involes zeer pots ( clay pot which by evaporation cools the water in it.)it is pot in pot arrangement one pot is fitted in other and between both pot charcoal powder is poured. water from this pot will circulate through water pump. The capillary tube after pump will be attached to the tube where at the starting nozzle its pressure will increase also it will compress some what persent but in capillary tube is pressure and temp. drop will takes place and this capillary tube willalso pass through another pot and after through expansion valve. it will pass through tubes on which air will keep blowing by blower. This water after circulation will again come to the pot.<br>will it work...?<br>
What if i use tape to shut the holes? Will it affect my project?
Tape doesn't seal well against terra cotta since the surface is rough and porous. Also, if you use tape to seal the hole, it won't hold down the inner pot like the bolts and washers would.
<p>There are a several things I like about this zeer pot - the wire basket, the pebbles, the caddy (if you have a need to keep moving it), and it is attractive. In addition the instructable is well written and I'm sure will get more people interested in alternative forms of refrigeration.<br><br>However, the inner pot should be impermeable to water so that the food area can not be contaminated by the refrigerant water and can be cleaned easily. The lid should be insulated or better yet a metal lid (better heat conduction) covered by several thickness of cloth (an attractive , quilted, sewn together pad?) which can be wetted to provide more evaporation. The cloth will still act as insulation after it drys out. Instead of a major source of heat gain you will have an additional source of evaporation/heat loss.<br><br>For those contemplating duplicating this particular pot, I personally don't think it is a good idea to have ceramics loaded in compression by bolts. I think that is a very real source of failure. The hole in the bottom of the outer pot could be sealed many other ways or left open (glue a cloth on top of the hole to prevent the sand from coming out) to allow excess water to drain out. If you added some wick material in before adding the sand and put a tray/saucer under it then the excess water can wick back up into the pot and can also provide more evaporation. A wire or cloth screen could be fitted over the tray to prevent mosquitoes from laying eggs in it in mosquito territory. Use a plastic/metal bucket or pot with no hole in the bottom for the inner pot. If you have a floating problem then secure the inner pot from the top. You can also simply replace the sand with absorbent material.</p>
using plastic for the inner pot would also reduce weight
I considered securing the inner pot from above, but there wasn't any way to do this that didn't involve even more work. sealing the holes and securing the inner pot with the bolt and washers was the easiest and most economical solution.
<p>In response to both perspectives, I would like to moderate by pointing out that the starting point is the desire or the need to become educated or proficient at figuring out life skills. I think both ways do this. The issue of who to appeal to is not insignificant. In my neighborhood, no one would dream of trying to figure out refrigeration- when the power when off briefly last night I heard the whir of all their generators kick on, while I searched for my flashlight and tried to remember that instructible using crayons and dental floss.</p><p>Sadly, we have to appeal to both ignorant and uneducated when presenting ways to survive, and visual appearance is a factor. Simplicity will hopefully come as we learn for ourselves to actually TRY something, learning by doing. My hope is that we can eliminate fear of failure as a barrier to making an attempt, as we learn more about what doesn't work and why when we have our hands in the game.</p>
<p>Warning. The rest of my comment is aimed at providing additional info to people who are interested in more info on &quot;zeer pots&quot; and is pretty long winded.<br><br>I am not trying to put this design down but I'm not sure that many people would want to spend almost $150 to build a $0 - $40 item. This shouldn't be compared to Mohammed Bah Abba pots. His idea was to build affordable, simple to make and maintain coolers out of locally available and/or mostly free stuff.<br><br>I believe in the KISS (Keep It Simple Stupid) approach to design. Abba's design has 4 parts (1 big porous pot, 1 smaller glazed pot, sand, and a cloth and/or pottery lid) all of which could be found or hand made locally and is considered more as a survival item. This pot has in excess of 25 parts to buy, assemble, and maintain, and I would consider it more as a novelty item. A large metal pot with a lid found at a garage sale or flea market for a few dollars would be a better and cheaper alternative for the inner pot. I don't however believe that you would be able to find these metal pots readily available in the middle of an African desert.<br><br>The other advantage to using ceramics and sand (besides being able to make your own or find localy cheap) is thermal mass, which is a double edged sword. Although it takes longer to heat up after you have cooled it, it also takes longer to cool down to start with. Having a light weight portable pot to put the fresh produce in for the trip home or to get some quicker cooling and then transfer either the produce or the inner pot from the &quot;quick&quot; cool pot to the ceramic pot could combine the best of both alternatives.<br><br>I think everyone should know how to make one of these in case of an emergency, although in a real emergency the water may be more important to you than food, waste water could be used as the refrigerant. <br><br> I don't think that zeer pots will catch on here in the USA for everyday use because it requires too much attention and most people can't or don't want to provide the attention necessary for success as long as electric refrigeration is available. Inattention results in spoiled food. If you want to make one for busy people then you need to automate the refilling process. As long as you have a running water supply and electricity this can be simply a mater of using an irrigation timer and a water line. A higher reservoir tank and drip irrigation could be useful, but you would still have to fill the reservoir periodically.<br><br>In addition I think it is important to let readers know that the outer pot can be replaced by many other approaches. Anything that will support itself and allow evaporation will work. My favorite is a canvas bag filled with water, suspended from a metal frame, with a either a plastic bag or plastic/metal inner pot/lid. The sand is not necessary when it is easier for the water to saturate the outer skin and evaporate off. You could also put an absorbent material between the canvas and the pot to keep it fro sloshing around.This is more difficult than it sounds because if any of the wet part of the canvas bag touches the metal it will start leaking/dripping there, just like the old style canvas tents. Heavy canvas bags filled with water are a good way to provide cool drinking water in hot dry climates and were widely used here in the American deserts when I was a kid. We used to keep them tied to the front grill of the car while traveling and suspended in the shade while camped. <br><br>Lighter weight, more efficient, cheaper, more portable designs are possible and don't have any ceramics in the at all. There are several instructibles on these and some can be bought commercially fairly cheap. These usualy have an absorbent material in between the outer perforated metal or plastic &quot;pot&quot;/screen and inner &quot;pot&quot; with a lid or cap.<br><br>Wetted rags wrapped around a metal pot will also work for a cooler, you just have to keep wetting them.<br><br>Keep it in the shade and promote as much airflow past it as possible, but remember that on windy days you will have to replenish the water more often. If you want to know how cool it can get on a particular day you can calculate the wet-bulb temperature or ...watch the weather on TV and see if they give the wet-bulb temperature for that day.</p>
<p>I wonder if you'd consider doing an 'ible on your canvas bag version (or other approaches you've used)? Sounds very interesting!</p>
<p>While it is true that this pot is by no means as affordable as Mohammed Bah Abba's zeer pots, the audience is different. To be sure, this instructable is for people with the luxury of choosing to do this, and competes against refrigerators, whereas Bah Abba's pots were for poor folk, competing against no refrigeration and food going bad in a day or two. With this in mind, I spent a lot of effort trying to appeal to people in this situation, going out of my way to make it look nice with the glass lid, the decorative rocks, the inner basket, and rolling stand. If you do away with those items, you could definitely make it much cheaper. Doing a way with the bolt and using plugs would make it easier, but unless it's practical, it won't make an impact among the audience I'm trying to reach.</p><p>My next version will be to reproduce a pot version of the Coolgardie Safe (the Australian mine town evaporative cooler, which was a box with burlap wicks covering it), using stock pots, wicking material, and rope. This may end up being cheaper, especially if the materials can be salvaged, and will likely be much lighter.</p>
<p>I forgot to mention that one of the advantages of sand is that it doesn't rot. If you chose an absorbent material it also should not rot or should be easy to change, clean, or dispose of as needed.</p>
The bolt does not compress the terra cotta to any significant load;, they merely seal the hole, but more importantly, they keep the inner pot from floating up as the sand is saturated. I made simpler pots without the bolt, and the floating of the inner pot was a real problem. <br><br>A lid that contributes to cooling would definitely help if that is a priority, but visibility of the contents was important enough for our application that we opted for the glass lid.<br><br>In my opinion, there isn't really a need to drain extra water; this extra water simply lets the zeer pot be watered less frequently. When the zeer pot is exposed to wind or a fan, it can evaporate water at a pretty high rate, and extra water hasn't been a problem.
<p>A more high tech solution would be a coolgardie chest. Easier to access contents better Surface area to volume ratio </p><p>http://museumvictoria.com.au/collections/themes/712/food-storage</p>
<p>Wow all this information is wonderful and eye-opening. I would love to find a way to make something like this work inside, perhaps on a counter top, to store fresh produce in - without infesting the house with fruit flies and other nasties. Any ideas on that?</p>
<p>works best inside with a small fan to create the breeze needed</p>
You could make a few small pots of this kind, but it is important that you have a breeze on them. I would drape a wet cloth over the lids so the flies can't get in through the vent nor the gap around the lid. The wet cloth will also enhance the cooling effect.<br><br>Be sure to take the lids you want to use to the hardware store to find the pot that matches. For small zeer pots, the clay pot feet are likely to be too large to use as spacers.<br><br>To get rid of the fruit flies, make a fruit fly trap with apple cider vinegar and a little squirt of dish soap. Apple cider vinegar is the best fruit fly bait I've ever tried. Even an open jar of this will trap flies; as soon as they touch the surface, the soapy vinegar will pull them under and drown them.
<p>How large can you make these?</p>
The size I made in this instructable is as large as they can be practical. The cooling power is dependent on the surface area to volume ratio, since all the evaporative cooling happens at the surface; this ratio is worse for larger pots. It is better to make several medium ones than to make one large one.<br><br>(Also, I couldn't find pot lids any larger than 13.5 inches. it is a happy coincidence that this fit the 14 inch pot so well that a bit of sanding was all it needed.)
<p>Nicely made.</p>
<p>Great project! We used the Zeer pot during our annual 4th of July camping trip! It worked great and we cant wait to use it again!</p>
<p>I notice that your pot is resting on the ground rather than on a stand or on pot feet. I highly recommend the pot feet; air circulation under the pot adds to the cooling power.</p><p>How large is your inner pot?</p>
<p>Excellent! I'm glad my design is being used. ^_^</p>
<p>Very nice! Excellent learning experience as one works through the different laws of thermodynamics. I liked the comment that if someone has this much trouble sourcing the glass lid, that's probably the least of the issues you will face.</p>
<p>The application, and scope of the original project in Africa interests me. I noticed 'Berkley' in your information. There are over 7 thousand homeless in San Jose and one of the major issued they face is that even when they can get food, they have no way of keeping it for any period of time. Have you considered reproducing the original project a little more directly? It might be in need of some fine tuning, but it might be a way to help a lot of people.</p>
I have not thought of how to adapt this to help the homeless. This method is too heavy and too dependent on water for it to be practical for the homeless. Even in Africa, zeer pots are for those who are settled and who do farming, not for nomads.
<p>This would be a great thing to keep in a basement to store excess fresh Vegetables from the Garden. </p>
The biggest difficulty with using a zeer pot in the basement is the lack of a good breeze. without air flow around the outer pot, the zeer pot will not cool down. If you could create a solar updraft chimney to draw air into the basement to circulate around the pot, that would be best. Also, finding some way of capturing the wind at night to keep the evaporation going even when the sun has set would be good.
<p>That is a very valid point. Didn't realize that it needed some airflow until re-reading it. Must have over looked that (Sorry). Though that would be cool to try something that you had suggested so that you could use it in the basment. The reason why I thought, was because my Grandparents said that they used to store carrots and other root vegetables in a container of sand in the basement. </p>
<p>this could be combined with a small fan, so you can cool a room in a house?</p><p>more efficiently clear the fan would spend at least light possible, even with a very remote solar panel</p>
There are other evaporative coolers that might be better suited for cooling the air in a house. If you want to cool the air, terra cotta and sand are not necessary. All you need is a wick type material and a fan. A damp air filter should work. You just need some way to keep it damp.
The most efficient natural way to cool a house would be to build a windcatcher to draw air through a moist basement. The cooling principle is the same: evaporation will lower the temperature of the air. This was used in ancient Persian palaces and other large buildings. <br><br>See this: <br>http://en.m.wikipedia.org/wiki/Windcatcher
<p>I love this idea. I have seen images elsewhere, but the directions regarding how to make one are great! I would greatly appreciate it if I could use the main image in a book about sustainability that I am writing. I will give you credit and send readers to this site. Please email me at LCPope@gmail.com</p>
<p>Would you happen to know the weight before and after adding the water? Did you transfer the pots without sand and fill in place? My sister lives in a very breezy area and I think this would be perfect storage for her Aquaponic veggies.</p>
My best guess is that the finished assembly weighed about 110 lbs, and about 120 lbs when wet.
<p>does it work at high temp like summers in india??. </p>
<p>Is it humid in India? If it is humid, it might not work as well. As long as it is in the shade and there is a breeze, it is going to provide some cooling power. My friend says that these still work where it is humid, but they work best when it is dry.</p>
<p>I did make the same .. Check my i'able </p><p>https://www.instructables.com/id/Homemade-clay-refrigerator-BEING-ECOFRIENDLY-/ . When i used it in humid cliamate it didnt show any cooling effect. </p>
<p>It should, provinded you do not expect to get low temp (as keeping ice cream frozen) nor preserve food for a long time (experiment with how long you can keep milk before using it for this technique).</p><p>Butter is a good product to test how efficient the contraption is.</p><p>Also do not forget that cold temp. will vary according to outside temp.</p>
About This Instructable
442,623views
1,681favorites
License:
Bio: I'm an inventor, poet, permaculture / sustainability nerd, and activist. I work in the renewable energy industry with biomass gasification. I love to show people ... More »
More by Berkana:Insulated Sous Vide Kit Caramelized Butter (a.k.a. Browned Butter or Beurre noisette) Inexpensive, Reliable Stud Finder
Add instructable to:
