Some will say, "Why bother?" since you can now buy an inexpensive table saw for the same amount of money. True, but the adaptation shown here allows the user to remove the saw from the table at any time and rip panels or frame houses, and then return the saw to its table precisely aligned and ready to do close fitting work. You cannot enjoy that dual purpose usage with an inexpensive commercial table saw.
This Instructable differs from similar Instructables because it offers that precise mechanism for automatically and exactly aligning the saw each time it is returned to its table. Details of this are in Step 16.
If you want yet another alternative for making your circular saw an accurate woodworking machine, see my earlier Instructable Get More from Your Circular Saw.
Remove these ads by
Signing UpStep 1Making the miter gauge
If you choose to make your own, begin with a straight steel bar. The one shown is 1/4 x 3/4 inch and about a dozen inches long. It is what I had at the time. I would recommend a bar of 3/8 x 3/4 inch steel about 18 inches long, but 1/4 x 3/4 inch may be easier to find and works well, too. Round the edges at the ends a little with a grinder so the miter gauge moves more freely in the slots. The photos in this step and the next steps are from my previous Instructable titled Bench Saw Table for a Lathe.
do you like do a plunge miter cut like a pocket cut?
i'm a new woodwork hobbyist and would like a bit of help please.
thanks
I add photo of machine.
As far as an "expensive shop" vs an "inexpensive shop" I do finish carpentry and cabinet installation for a living and have seen without fail that the better carpenters get more jobs=make more money=set themselves up better. While the less skilled carpenters...well you get the idea. If I couldn't afford a table saw at today's prices for that particular tool then I am in the wrong business.
If you have been in the business for years, you have surely learned some useful things. Please consider publishing some Instructables soon.
My sympaties went to other shows --such as New American Woodshop or Bob Rosendahl´s exploits with a router-- but above all, to The Woodrights Shop, which demonstrates how you can do a lot of excellent AMATEUR work using pre-electric tools only.
On another note: your Ibles are GREAT. Thanks a lot.
I might be wrong, but I vaguely remember reading on an old Popular Magazine instructions on how to convert a hand circular saw into a radial saw of sorts, very similar to the excellent idea you advance here.
I am glad you find something useful in my Instructables. I enjoy publishing them.
Back in the 1990s I listened to a lot of shortwave radio and very much appreciated RCI's broadcasts. I always wanted to thank Canadian taxpayers for helping to make those broadcasts available.
It even takes care of comments with a good point, but is so far off topic it could be its own instructable.
Thank you!
(And I will keep your instructable close at hearth for future needs. It's awesome!)
PS Check out some of the other things I have adapted or conjured on the cheap.
Carbon arc torch for a welder
Inexpensive welding hood for guests who want to watch
Torque wrench for a bicycle mechanic
Cone wrench for a bicycle
Automobile radiator pressure tester
Home postal scale from old CDs
Metal cut off saw from an angle head grinder
Banquet table mover for one person
Unfortunately I had to do an awful lot of cutting of steel with a composite blade. And that saw was a high powered industrial unit so any error at all could trigger a really violent reaction.
THIS project however:
I'll need to read through it a few more times to see how it'll apply to my circular saw, but I'm so happy to see this posted. I have had this precise project want in mind for as long as I realized that I'd likely want to spend more on a table saw than I should. I have a bandsaw that I'm not positive I have set up right, since it doesn't seem give perfectly straight vertical cuts and repurposing the circ saw would be an interesting option.
I have done table saw conversions on three or four circular saw, most of them for other people. All of the saws were different from one another. Still, each of them worked well. Most of what I showed in this Instructable is pretty intuitive, but with a few details that make the final outcome work very well. There are even other ways to do many of the steps, but I tried to show methods that pretty much guarantee a good outcome for anyone.
My saw has the blade guard. Since you have mentioned in the Step 7 to keep the opening as small as possible to prevent scrap bits of woods going under, I assume that the slot in the saw table will not be wide enough to accommodate the guard to come up. is this correct?
My saw base does not have any holes, but surprisingly has four half-a-mm-deep stampings of 5/8 th inch dia. Probably they envisaged the conversion. But they have riveted and fused the base plate with the main body. So I have to figure out how to drill holes now. I am contemplating using all the four holes for mounting along with the blocks with screws for alignment as in step 16. Any particular disadvantages of four mounts besides time taken to remove the saw?
While googling for the conversion ideas, I read somewhere about someone having a problem of the sawdust spewing up the table to the face. Phil, did you have any such problems? My saw has a slot for the sawdust to come out and attaching the dust extraction unit.
I am also contemplating having 2 slots (like the ones for mitre guage) one each near the front and back of the table running perpendicular to the mitre slots, have two more steel flats and attach a straight edge to them to act as a sliding rip fence. Any suggestions or comments, Phil?
Thanks again for the wonderful i'ble.
Regards.
Kulin
Concerning the saw guard, I actually removed it from my saw. i did not want to mention that in the body of the Instructable because several people would comment on nothing else and criticize me severely. But, when I sawed smaller pieces, the pressure from the blade guard broke them or pushed them out of position so I did not get accurate cuts. The best saw guard I know is to set the blade height so that only a tiny bit of the teeth stand up above the top surface of the piece being cut.
If you want to avoid drilling holes in your saw base, see the solution I proposed below in my response to lenny25. If you do drill holes, four will work. Removing the saw from the conversion table will take longer to undo more screws.
I did not have problems with sawdust blowing into my face. A dust extraction device, especially with a suction hose could be a big help.
Some use rails at the front and back of the saw table for a sliding rip fence. Slots might work. You might still want to check the alignment with a tape measure before sawing. I really liked placing a framing square against the miter gauge set to 90 degrees and then sliding a straightedge guide against the other leg of the square. It was always very accurate as long as I did not bump anything while clamping the straightedge down. It was fairly quick to set, low-tech, and very accurate.
Bwahahaha! Isn't that the truth? "My way is the ONLY way!"
Thank you for what appears to be the only instructable on how to make a miter gauge. I'm using it now, although I will probably embed a protractor on its face.
Thank you for what appears to be one of the the only instructables on how to make a miter gauge. I'm using it now, although I will probably embed a protractor on its face.
I saw on your member page that you chose an Instructable by Steliart as one of your favorites. He has another Instructable in which he built a miter gauge with a protractor on its face. He said it worked out quite well.
I have seen a few plans for a miter gauge, mostly in old copies of Popular Mechanics, etc. But, most of these were too crude and too simplified to do a good job. What I presented is based on improvements to a previous attempt or two, and it works very well.
The only beef I have with your setup is its too elaborate. Whenever I've been pressed to use this technique its always been with saw horses, or barrels, pails, milk crates are a classic with this rig too. With the old wooden milk crates just run the saw up from the bottom and you're done! They even had convenient ready made carry handles those did.
But I'm not that should criticize elaboration:
http://img178.imageshack.us/img178/2884/newshoptop.jpg
http://img294.imageshack.us/img294/2234/fenceside.jpg
http://img19.imageshack.us/img19/453/camq.jpg
As I've obviously gone to some lengths myself on this front.
Thanks for the reference to Steliart's version. I found it shortly after posting here, and am thinking about that.
I see so much vanity in you that I comment on just your safety issues because they are absolutely dangerous. SOME OF THEM, not all of them. I do like most of your instructables and use or modify it to my own adaptations.
Some of them are quite dangerous and I am not talking about this one although I do wish you would emphasize more caution to the potential safety of others. Product liability these days is a huge issue designed around safety and PROPER use of power equipment. Yeah I could hang a circular saw from trees with rope and tape the switch on and cut wood like that if it works. But who are we to judge what is safe or not by how many people posted instructables or not? Because I care about the safety of others I don't care what kind of scrutiny I get. If they delete my account I can get a hundred others. I am doing what is right and that is caring about others' fingers or limbs.
One man lost two fingers on a power tool adaptation and if he could be warned he said he'd pay all he had in the world to have kept his fingers from heeding a warning about doing modifications unintended by the designer of the safety of the equipment.
All of your other ideas and designs are really quite helpful and valuable and fun to read and learn. But I can't stop thinking of the one persone who follows a dangerous instructable and gets hurt. I have worked in an incredible workshop facility that is probably one of the best in the United States for over 28 years and I've seen it all and made it all. I am a professional. Junk yard rigging is for the back woods of some swamp tribe in another country. It pays to be safe and if not then send me one of your fingers. No not that one. I don't want you hurt and if it n ever happens then fine but you're taking chances with some of these modified power tool conversions.
Also I have published a couple myself, I feel your pain about the ability of some readers to obsess on petty incidental risks. I think the 'flag' button on comments needs a couple more entries like 'Already asked and answered' or perhaps "What a marooon...."
I once made one of these for a friend in which only 1/4 inch of blade cutting depth was lost. The saw was hung from a piece of 1/4 inch steel. 1/4 inch Masonite butted up against it from the left and the right sides. The Masonite was the top of the saw table. I left gaps between pieces of Masonite to serve as miter gauge slots. He was pleased.
