Step 7Opening for the blade
Notice that the opening has a bevel on the left side. That is to accommodate the blade's position when the saw is set to rip a 45 degree bevel. Keep the blade opening as small as possible so scrap pieces do not fall down into it.
This design sacrifices 3/4 inch of cutting depth due to the thickness of the plywood table. Most of the time you will be cutting materials no thicker than 3/4 inch, so less than maximum cutting depth is not a problem. When I had to cut a 2 x 4 (1 5/8 x 3 5/8 inches), I simply turned it over after the first cut and made a second cut. It would be possible to mount the saw below a piece of steel plate. The details on that would require quite a few more frames in this Instructable and will not be covered here.
Add Comment
