3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A QUICK BATTERY HOLDER -- for electrical experiments
This is a quick way to hold wires to the terminals of a AAA or a AA battery for electrical experiments. Two modified clothespins are mounted to a 3/4" thick wood spacer. The clothespin springs maintain pressure on the battery terminals.
Two holes in each of the clothespins allow for attachment of the wires.
I just nailed the clothespins to the wood with 3/4" finishing nails. You could also use a little glue if you wish.
Step 1MODIFY THE CLOTHESPINS
Slide one half of the clothespin sideways out from under the spring that holds it. Cut the end off one of the halves. Make sure that when the battery is in place, the terminals of the battery will make contact with and be held by the contact points on either side of the holder.
If you don't have a tiny drill bit to make the holes with, you can just drive in and pull out a 3/4" finishing nail. If the wood splits, it may still work. If it splits badly, try another clothespin. Sometimes they don't split.
28 comments
Apr 4, 2011. 11:13 PMgrithms says:
graet londs
Dec 2, 2010. 12:56 PM5STARGBLOOD says:
Any one have any suggestions on were to get goo wire for this all my wires suck
Oct 22, 2009. 2:28 AMJavaNut13 says:
Brilliant idea!
Jul 12, 2009. 7:36 PMGrathio says:
Excellent idea! I'm going to make several. As soon as I figure out what I did with my old clothes pins.
Oct 22, 2009. 1:03 AMDr. dB says:
...when lawyers design clothespins....
Jul 28, 2009. 3:05 PMGENIUS!! says:
I LOVE MAKING THINGS SO RIGHT NOW IM TRYING TO FIGURE OUT SOMTHING I CAN MAKE JUST BY USING ONE BATTERY THANKS ALOT :)
Jul 28, 2009. 3:09 PMGENIUS!! says:
PLUS TO GET THOSE STRONG CLOTHEPINS JUST TRY UR LOCAL $1 STORE NEAR U
Jul 13, 2009. 6:26 AMcapn_midnight says:
I've always used a couple of coins strapped to the terminals with a rubber band. The coins provide surface area to pin the wire to the battery, and the rubber band provides the tension. Very compact, and no gluing or nailing necessary.
Jul 13, 2009. 5:46 AMwobbler says:
Putting heading in caps in design terms is fine. It's called "adding weight" and it allows you to discern the importance of infromation and to give a page structure. Sheesh, some people don't recognise good design when they see it! Oh yes, before I forget, great idea by the way.
Jul 12, 2009. 7:13 PMdepotdevoid says:
That's a very simple solution for a somewhat vexing problem, I like it!
Jul 12, 2009. 7:39 PMmawktheone says:
very clever. I like it
Jul 12, 2009. 6:47 PMosgeld says:
Brilliant!
Jul 12, 2009. 6:43 PMstone3408 says:
Great use of materials. This is one of those that goes under the so simple I should have thought of that. Good job.
Jul 11, 2009. 9:16 PMCarpetGnome says:
Amazing! I wish I had heard of this idea sooner!
Jul 12, 2009. 1:38 PMleevonk says:
nice, I had used electrical tape and rubber bands in the past but doesn't really work too well.
Jul 12, 2009. 5:33 AMPhil B says:
Very clever!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
339
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
