Step 3The Board
Here is the PDF that I used for Toner Transfer PCB manufacturing - As long as you print the sheet out in full size, then you won't have any problems with size.
Also included is the parts overlay, for the top and bottom of the PCB. As was suggested, I re-wired the protection diode across the coils - so the PCB changed, but not enough to warrant replacing the parts overlays!
There is a small number of surface mount components on the board, but, like the Arduino Ethernet controller, their use is minimal.
I have also loaded up a PNG of the board from KiCad. It is sooo pretty!
Ethernet-Relay-Controller-v1-rear.pdf(842x1190) 12 KB
Ethernet-Relay-Controller-v1-Component.pdf(842x1190) 55 KB
Ethernet-Relay-Controller-v1b.pdf(842x1190) 105 KB| « Previous Step | Download PDFView All Steps | Next Step » |
It is here
http://kicad.sourceforge.net/wiki/index.php/Main_Page
Were you successful in getting Kicad installed?
Give this link a go.
http://kicad.sourceforge.net/wiki/index.php/Download
Don't click on the windows logo - click on the text below it - that will take you to a download page with both linux and windows versions.
Here is a direct link - savethe file and run it on your machine - that will install the program.
http://iut-tice.ujf-grenoble.fr/cao/KiCad-2010-05-05-BZR2356-final-WinXP_full_with_components_doc_autoinstall.exe
Thanks,
Marc
The tutorial that I found that was most use was:
http://kicad.sourceforge.net/wiki/index.php/Mini_tutorial
and
http://www.kicadlib.org/Fichiers/KiCad_Tutorial.pdf
It is well worth the effort to learn how to use the tool.
Doug
BTW Awesome job on your many different designs and project ideas.
Good stuff
