A Rocket in your Pocket
 by Kiteman
Featured
Not just a rocket in your pocket, but an entire rocket factory and launch system!
Step 1: Materials
The materials are easy to find in most modern homes:
  • A pocket-sized box.
  • A box of matches
  • A small scrap of wood.
  • Some pieces of kitchen foil
Optional extra: a pocket lighter.
stevo69nz says: Jan 28, 2013. 1:37 AM
nice one mate we'll try it tommorrow after work or at work :-)
smiley G.I JOE says: Nov 1, 2012. 6:30 AM
i gona try that and make like 20 of them next thing you know it i gona have a mini missile launcher. ladies and gentlemen this is how we crush our enemies.(quote tony stark iron man 1)
Patna43 says: Nov 23, 2011. 10:18 AM
Hey guys! I cool mod is to just cut of the red tips of the matches and stuff about five of those. If one match heats up, it causes the others to heat up in a chain reaction. When i tried that, my match rocket when about 40 feet. Plus add an extra layer of foil so the smoke doesn't leak out, otherwise it wont fly very well or not at oll. And instead of using a match as plug for the nozzle of the rocket, use a paper clip. That makes the nozzle smaller and causes the pressure to go up and the rocket goes further. Just a few tips.... :P
Patna43 in reply to Patna43Nov 23, 2011. 10:21 AM
Another thing I did was make a full scale match rocket. I made a couple of these as booster rockets attached to a huge match rocket made from "Extreme Burner" Matches. These matches have HUGE flames that cause the rocket to fly far. This rocket flew almost 80 feet.
chimei62 in reply to Patna43Apr 26, 2012. 2:41 AM
wow were do you buy the extreme burners?
avgas says: Jan 13, 2012. 10:51 PM
personaly I think it sucks the only reason is I followed o all of your insrtuctions and used 4 hole packets and matchs
TheAmateurArtisan in reply to avgasJan 26, 2012. 7:53 PM
somebody's not a happy camper...
Personally, I'm always looking for various designs in pyrotechnics and well, everything. This is a very nice design Kiteman. I had an altoids tin and a zippo utility bending lighter soldered together to make a launch pad that could light far from your fingers over the summer.
somebody12345 says: Dec 5, 2011. 5:01 PM
Kiteman please respond to this
i think that this could work better if you used a small pinpiont blowtorch to light the matches
Kiteman (author) in reply to somebody12345Dec 6, 2011. 2:26 AM
They certainly ignite more quickly, but there is the risk of burning through the foil from the outside before the matches ignite on the inside.
If I use a blowtorch or bunsen to light these, I usually wave the flame over the match-heads to stop the whole thing scorching.
somebody12345 in reply to KitemanDec 7, 2011. 3:04 PM
forgot to add- i don't have any problems with the foil burning through just that the rocket won't take off
somebody12345 in reply to KitemanDec 7, 2011. 3:01 PM
thanks for your reply, my problem is that i do not really know what i am doing wrong i think it is that i wrapped the foil around the bottom match a little too tightly but i am not sure.
Kiteman (author) in reply to somebody12345Dec 8, 2011. 4:44 AM
So slacken it slightly by pulling one match out and then sliding it back in.
mkanoap says: Nov 17, 2011. 10:55 AM
When I was a kid, we made them in a slightly different manner. I'm eager to try your version to see the difference.
What we did was use a single match from a matchbook instead of two wooden matches. Before wrapping the head in tin foil, we would lay a pin on top of and in parallel to the match with the point touching the head. After applying the tin foil, the pin would be carefully slid out leaving a small raised channel exiting the end opposite the head for the exhaust to escape.
ihaveguitarskills! in reply to mkanoapNov 25, 2011. 8:31 PM
thats how i first made them too. but im still a kid.
Kiteman (author) in reply to mkanoapNov 17, 2011. 12:59 PM
That's a cultural difference - matchbooks have never really been popular in the UK.
Kryptonite says: Sep 26, 2011. 5:05 AM
Gah, beat me to it! Matchstick rockets are the greatest, I like your little rendition: poor photoshopping and all!
I'm glad you chose to document this method of make, in my opinion it's possibly the best in terms of simpleness : distance : matchstick usage ratio.
caarntedd in reply to KryptoniteOct 21, 2011. 12:15 AM
Simpleness?
Kiteman (author) in reply to caarnteddOct 21, 2011. 5:42 AM
It's really simple to make one that actually gets off the "pad".
caarntedd in reply to KitemanOct 21, 2011. 7:29 AM
Simplicity?
Kryptonite in reply to caarnteddOct 24, 2011. 10:23 PM
That's the one.
caarntedd in reply to KryptoniteOct 25, 2011. 12:14 AM
: D
mkanoap in reply to caarnteddNov 17, 2011. 10:49 AM
Simpleitude.
ihaveguitarskills! in reply to mkanoapNov 25, 2011. 8:30 PM
dude...fail pic...XD
caarntedd in reply to mkanoapNov 17, 2011. 3:05 PM
Ha ha!
Kiteman (author) in reply to KryptoniteSep 26, 2011. 5:10 AM
Haha, thanks. That's the exhaust plume of a Tomahawk missile breaking the surface.
Kryptonite in reply to KitemanSep 26, 2011. 11:33 PM
Oh dear, I hope no govermental institute was in the way!
smelly210 says: Nov 23, 2011. 4:28 PM
this does not work:(
Kiteman (author) in reply to smelly210Nov 24, 2011. 12:07 AM
It just takes practice - if it just sat and smoked, tighten the foil; if flame burst out of one side, use more foil; if you had a healthy jet of smoke in the right direction (down), but nothing moved, slightly loosen the foil over the lower match.
PotatoCoffee in reply to KitemanNov 24, 2011. 11:05 AM
Pretty cool!
smelly210 in reply to KitemanNov 24, 2011. 6:10 AM
thanks i will try it now:)
Electricdude says: Nov 1, 2011. 7:09 AM
.......I don't think it will fly very far you know and it won't look good when flying ,too.I'll test it later.wish it will be good
Don't be disappointed by my comment. i'm just a 12-years-old kid anyway
Kiteman (author) in reply to ElectricdudeNov 1, 2011. 7:38 AM
I regularly make these with 9 year olds, and they can make them well enough to fly 10-20 feet.
It just takes a little practice.
ghooey2 says: Oct 15, 2011. 10:09 AM
every time i light it off it stays and smokes...?
Kiteman (author) in reply to ghooey2Oct 15, 2011. 10:32 AM
Could be many things, but most likely two:
  • Is one end twisted tight, and the other able to slide off the match (just)?
  • Have you got enough foil wrapped around it?
lug big lug in reply to KitemanOct 15, 2011. 12:28 PM
you could possibly be heating it too slowly, mine wouldn't work because of that
the cat expert says: Oct 2, 2011. 5:00 PM
Genius.
I think you could make this tabletop-size, or bigger, if you wanted to
Kiteman (author) in reply to the cat expertOct 3, 2011. 12:26 AM
Not for a pocket-sized contest, though...
tqwerty says: Sep 26, 2011. 5:15 PM
The third last word.
Just had to point that out.
Great instructable though!
Kryptonite in reply to tqwertySep 26, 2011. 11:33 PM
Your totally right, that needs to be fixed.
Kiteman (author) in reply to KryptoniteSep 27, 2011. 12:11 AM
Fixed!
tqwerty in reply to KitemanSep 27, 2011. 4:52 PM
Yay!
Now it's awesome.. wait.. it probably already was‽
ZoDo says: Sep 27, 2011. 1:12 AM
Nice...but here's a challange for you...can you make a stalin's organ from this?
That would be really cool.
Kiteman (author) in reply to ZoDoSep 27, 2011. 1:25 AM
Oh...
ilpug says: Sep 26, 2011. 5:44 PM
i will definitely do this.
bubblebut says: Sep 26, 2011. 4:03 PM
this is awesome i'm voting for you great goob.
dragonsniper in reply to bubblebutSep 26, 2011. 5:13 PM
lol good goob spelling job
rimar2000 says: Sep 26, 2011. 6:21 AM
Those match-rockets are very funny!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
