A SOLAR POWERED MOBILE PHONE
I WILL SHOW YOU HOW TO ADD A SMALL SOLAR PANEL TO A PHONE SO IT EXTENDS THE LIFE OF YOUR PHONE BATTERY.BECAUSE OF THE TYPE OF SOLAR PANEL I USED IT LOOKS GREAT AND DOES NOT GET IN THE WAY OF USING THE PHONE NORMALLY AND YOU CAN STILL USE YOUR MOBILE PHONE PROTECTIVE CASE IF YOU USE ONE BECAUSE OF THE TYPE OF PANEL I HAVE USED.MY NEXT INSTRUCTABLE IF I DO IT WILL BE USING THE SAME METHOD TO ADD A SOLAR PANEL TO A A LAPTOP TO INCREASE ITS BATTERY LIFE AND TOP UP THE BATTERY WHEN YOUR NOT USING IT.
PS THIS IS MY FIRST INSTRUCTABLR AND ALSO I TOOK PICTURES AFTERWARDS AS I SUDDENLY REMEMBERED THIS SITE.AND ALSO I HAVE NOT STUCK THE SOLAR PANEL DOWN YET THATS WHY IT LOOKS RAISED ABOVE THE CASE.I HAVE NOT GOT ANY DOUBLE SIDED STICKY TABE.PROVIDING YOU SOLDER IT OK THEN IT WILL BE FLUSH WITHT HE PHONES SURFACE.
THANKS PLEASE COMMENT AND ALSO TAKE A LOOK AT THE LAST STEP IT GIVES YOU SOME COOL IDEAS IF ANYONE WANTS TO MAKE THEM
Step 1BUYING THE RIGHT PANEL
I BUY MY PANELS FROM : http://www.selectsolar.co.uk/pics/SP3-37%20(22mA%20at%203v).php
THE LINK ABOVE IS THE PANEL I PARTICULARY USED. THE REASON I USE THIS PANEL IS BECAUSE IT PROVIDES THE RIGHT VOLTAGE FOR MOBILE PHONE BATTERIES AND IT IS PAPER THIN AND IT HAS A MIRROWED FINISH SO IT DOES NOT LOOK UGLY ATTACHED TO YOUR PHONE.
THE PANEL IS 22MA @ 3VOLTS AND MEASURES JUST 3.7cm by 6.4cm
more info ont his panel here:lightweight, paper thin and durable
flexible enough to curve around an object 3 inches in diameter
will not break if dropped
wide range of sizes and power configurations available
thin profile enables them to be easily integrated with devices for solar recharging or direct power
Ideal for recharging AA, AA, 6V and 2V batteries
Please note: these modules do not have a UV stabilised surface.
Simple to connect - just solder or crimp to the copper tape.
Size 3.7cm by 6.4cm.
57 comments
1-40 of 57next »
Dec 30, 2010. 5:35 PMRic46 says:
I just bought a solar batt backup at bensoutlet.com for $7.99. It even has an internal battery in it, and it is the size of a large cell phone.I don't think you can build it for that.
Feb 21, 2011. 2:12 PMRic46 says:
It is the same size as my touch screen cell phone. It is 1 1/2 x 3 1/2 x 3/8. not very big.
Jan 9, 2011. 1:34 PMDoneitmyself says:
So if my phone has a battery rated at 3.7v, would a 4.8v thin solar cell work? What about a blocking diode to prevent the solar cell from sucking the battery down when not in the sunlight? thx.
Apr 1, 2010. 6:31 PMhaunted_lady says:
 I think this is awesome!! My battery is always dying..I think I am a little worried ( only because I am afraid of the cell phone not of your instructable) about the radiation being magnified with this modification. And really there is no way to test this unless  you exposed people on purpose. I think I like the charger that sits alone connected with a cord away from the phone not attached. When it is attached it is next to your head. This could be giving off some sort of energy within the panels into a persons brain..I don't know..Just a bit concern...
maybe make a cord so you can lay it to the side??Great idea maybe just fix this part?
Apr 12, 2010. 5:04 PMhaunted_lady says:
 Well I know with the solar film that are imbedded on the roof shingles the heat is so much it warps the shingles so that means the heat is amplified. If you are attracting heat from the sun you are attracting solar energy with has radiation near your head. As well as would damage the phone.
And maybe this is the reason why no one has done your idea.
Jan 23, 2010. 5:46 PMhydrogenman says:
Nice!!  But i should inform the americans about the euro thing when buying a solar panel.  The same solar panels are on sale at 4lots.com for american money.  You should also consider those.  This is a very good idea for on the go charging!!!
Feb 10, 2010. 6:49 PMhydrogenman says:
yes, and nice instructable
Feb 3, 2010. 8:33 AMdagenius says:
I think you have the panel on backwards-- the blue side should be exposed to the light.....
Sep 17, 2009. 7:47 PMnepheron says:
ellislake, I apologize for some of these member in the community who only offer negative, pointless comments. I think your instructable and idea is great. keep up the good work! 5* -Neph
Jan 13, 2009. 12:55 PMThe magical duct tape kid says:
CAPS LOCK...
Jun 28, 2009. 5:36 PMReCreate says:
YA WY DOZ HI HAV TU US CAPS LOK???!!!111one 1one1
Jul 19, 2009. 9:25 AMReCreate says:
Well i guess you could remove the caps lock now that you realized that it was on...
Jul 19, 2009. 4:06 PMReCreate says:
Because caps lock covers your work...
Jul 20, 2009. 11:17 AMReCreate says:
I mean I see BHAH CAPS LOCK MY EYES*eyes/brain/head explodes*
Jul 20, 2009. 1:20 PMReCreate says:
Will do ;)
Jul 18, 2009. 11:45 AMDIY Dave says:
lol
Jul 18, 2009. 3:15 PMReCreate says:
ORLY?
Jul 19, 2009. 2:25 PMDIY Dave says:
RLY
Jul 19, 2009. 2:26 PMReCreate says:
RLY?
Jul 19, 2009. 9:24 AMReCreate says:
Oh really? > O RLY? > ORLY?
May 2, 2009. 8:29 PMAsa J says:
is it a good idea to leave your phone in the sun?
Jul 18, 2009. 3:16 PMReCreate says:
Oh sure, Why not?
May 6, 2009. 5:32 AMgrimgroper says:
what about battery overcharge?? if i was to put a solar panel on my lappy lid it would be alot larger than one for the phone so i suspect that overcharge will be a bigger problem i have a m1710 dell so if i could remove the aluminum plate and replace it with a solar panel it could look really nice as well as effective..
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ellislake
crazy ideas.. very old profile pcture by the way but as you can tell i do like clubbing, look how battered i am in the pic
