3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A SOLAR POWERED MOBILE PHONE
Step 3Mounting the blocking diode
now you must find a place to mount the blocking diode.i mounted mine in the plastic casing between the battery and the case.but if you want you can take the phone apart and mount it inside somewhere but you must insulate it so it doesnt short andything out.also conside where you mount it you must allow access for small wires from the solar panel and the battery. IF YOU FOLLOW MY INSTRUCTABLE THEN THE WAY TO INSTALL THE BLOCKING DIODE IS AS FOLLOWS. the white strip on the diode need to face the battery wire.the whote strip acts as a gate and will not let power from the battery pass through it.but it must be nearest the battery wire. if thre strip is nearest the solar panel wire then you wil only discharge your battery and not charge it.ps ue a dremel if you have one as i used a soldering iron to melt the plastic and it loks messy. i do aactually have a dremel but didnt think to use it here for the whole for he blocking diode. lol
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ellislake
crazy ideas.. very old profile pcture by the way but as you can tell i do like clubbing, look how battered i am in the pic
