3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A SOLAR POWERED MOBILE PHONE
Step 7Cut the holes for the wires in the phone
now earlier on you decided where to mount the solar panel so you now need to get the wires from the inside of the phone to the outside so you can attach the panel.hold the panel in place then decide where to cut the holes.
remember you must allow enough play on the wire for when you take the case of to access you simcard or something.
you can cut the holes using very small circuit board drill bits or use a stanley blade or hooby nife or even heat up a needle on a soldering iron or with a lighter and burn a whole through you phone case,if you burn a hole you need to use a stanley blade to trim it flat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ellislake
crazy ideas.. very old profile pcture by the way but as you can tell i do like clubbing, look how battered i am in the pic
