3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A SciFi Scanner/Ray Gun movie prop
Step 2Gather Materials
Gather Materials
a transparent box of some kind (i used an empty dice box and semi-transparent film cartridge, or you could build your own.
assorted pots (potentiometers) (around 3,000 ohms to 10,000 ohms) and switches (hopefully cool looking.)
about a 1' section of 1.5" PVC pipe (sch 40) (the handle)
aluminum/copper tape or sheet metal for the light box.
knobs for the pots
wire.
solder
BUTTLOADS of hot glue (alot)
high power LEDs of assorted color
2" PVC end cap
2 AA battery holder
buzzer (optional)
vibrator (no not that kind you pervs, see below) (optional)
spray paint of some kind (whatever color you want your handle to be)
shrink tubing or electrical tape
PVC cement. or MORE hot glue or just tape it shut with your aluminum/copper tape
tools:
drill (drill press would be best)
and array of drill bits (.5" is a must)
screw driver
Soldering iron (most of these thing like with most movie props are optional, however if this is going to be electronic at all you NEED TO SOLDER!! its not as hard as it looks, if you can drive to a store and but these parts then you can SOLDER!)
wire stripper
wire cutter
hot glue gun (if its a cheapie 4 dollar one then this project will be its last. its going to be hard on it)
alligator clips to test connections (optional)
eye protection (again REQUIRED!!!!!!!)
multimeter (optional)
hack saw or giant PVC cutter.
calipers
sharpie (or some sort of marker)
vice (not required, just helpful)
heat gun if you chose shrink tubing above
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:whitish
I'm not going to explain my self so your going to have to let my groups and 'structables do the talking.
