3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A SciFi Scanner/Ray Gun movie prop
Step 6Insert controls
Insert controls
get your switches and other flapdoodle and put em in there respective holes.
if you have some sort of square switch like i did (see below) then you probably discovered this vexing little problem. drill bits work best when circular *OOPS*. well there is no fast way to do this, i just traced around the hole i want to cut and drilled LOTS of little holes and ground out the rest.
And now whip out your hot glue gun and glue everything in (unless its on of those switches with a nut you can tighten) go ahead and glue in your vibrator and/or buzzer.
hot glue your light cubes/cylinders on the end and/or sides (when gluing to sides you must first drill a small hole for the wires to come through)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:whitish
I'm not going to explain my self so your going to have to let my groups and 'structables do the talking.
