The Idea:
Recently I saw a video of a remote controlled boat powered by a miniature steam engine and was instantly hooked on the idea. After doing a bit of research I found miniature steam engines cost hundreds of dollars or require some very advanced skills and tools to build. Yet looking at the actual mechanism which allows them to run they are really quite simple so I decided to try and make one on the cheap.
The point of this project was really to see how cheaply and easily a miniature steam engine could be built. I built this engine in one day and for under $10 in materials so I think it's safe to call it a success.
This engine is 7.2cm (2.8") tall.
Some Things to Note:
First off I should state that this steam engine is only a steam engine. This instructable does not include instructions on how to build a boiler to produce steam. Instead I run the steam engine on compressed air. If you don't have a compressor a bicycle pump works well too, it's just a lot more work for you. ; )
I should also note that even if you did build a boiler this engine probably wouldn't work well because many of it's major components are wood. In the presence of steam the wood would swell and warp causing problems. A simple solution to this problem would be to replace the wood parts with aluminum ones.
I am a very visual teacher so be sure to read the 'Image Notes' (hover your mouse over the yellow boxes on the images), it will likely make my instructions clearer.
How it Works:
You could read my lengthy description below or you could check out the totally awesome animation by the guys over at www.animatedengines.com, find it here! I should note that this animation is of a "double acting" engine, in that is has ports on both the bottom and the top of the cylinder where mine is a "single acting" engine with ports just on the top. This just means that the engine relies more heavily on the momentum of the flywheel to keep it running but is a lot simpler to build.
This type of engine is called an Oscillating Steam Engine. If you watch the video below you will see that the cylinder on this engine actually moves back and forth as the flywheel turns (it oscillates!), this action is what opens and closes the ports which let compressed air enter the engine and exhaust air leave.
The cylinder has one port at it's top which is pressed up against the main body of the engine. The main body on the other hand has two ports, one for the compressed air and one for exhaust. As the cylinder tilts to the right it aligns with the compressed air port allowing air to flow into the cylinder and push down the piston. This causes the crankshaft to turn, thus tilting the cylinder over to the left and allowing the air to exit the cylinder though the exhaust port as the piston comes back up. Then the process repeats.
View on YouTube
Remove these ads by
Signing UpStep 1: Materials, Tools, and Plans
Most of the materials and tools for this project you will likely already have around the house. The only things I had to buy were the brass tubing, tubing cutter, and some wire.
Materials:
• 3/16" Plywood (aprox: 12x8cm)
• Retractable Pen (optional)
• Brass Tubing: (find some at your local RC hobby shop)
13/32" for the piston and 7/16" x 0.014" for the cylinder
• "Tea Light" candle
• Heavy washers with a diameter less than that of the tea light
• 5 Minute Epoxy Glue
• Plastic Tubing (to connect your compressed air supply)
• HomeDepot sprinkler marker flags or piano wire (~18AWG)
• Floral stem wire or piano wire (~24AWG)
• Q-Tips with plastic tube (not paper)
• Small elastic bands
• Plastic Wrap
Tools:
• Drill (or better yet; a drill press) and bits
• Tubing Cutter ($5) - you should also be able to find one at most hardware stores.
• Pliers and Wire Cutter
• Empty Tin Can
• Razor Knife
• Sandpaper
• Vice (optional)
Plans:
Attached are two PDF files. "Parts Only With Measurement" includes a layout of all the parts you will need to cut out of wood as well as the lengths for the wire and brass tubing parts. "Parts Only No Measurements" is exactly the same but without any measurements printed on the page; good for cutting out and gluing to your wood as a guide.
Some people are having trouble opening the attached PDFs, if you are too try the links below.
If you can't open the link to the PDF; here is a direct link to it.
If you still can't open the PDF; here is a link to a high resolution PNG image of the plans.
Visit Our Store »
Go Pro Today »
Here is a direct link to the large image of the plans.
I was going to run it with a boiler and a RC system. The boiler was going to be designed like a real one. Here’s what I thought of doing.
The PDF file really is the best way to go because it insures that everything will be to the correct scale if you print it, so try use it if you can. If not here is a link to the plans as a 100dpi PNG image. If you do print it be sure that the scale at the bottom of the page is correct.
Then in college I created all the plans for the steam engine in the picture. ~15 parts and only 3" tall. Has a 3/4" bore. Never actually made it though, ran out of time. Maybe in the future.
If you look at the final step under the heading "Final Thoughts" I have actually included a few suggestions for making this engine more efficient, bearings are one of them. Is it possible to run an engine like this without a flywheel? It seems like it would need at least 2 pistons, or air ports on the bottom of the cylinder as well to run without one.
Thanks!
Thanks for pointing out that this instructable really needs an explanation as to how this type of engine works. I'm going to add it right now!
