3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Simple Wire Ring
A Simple Wire Ring
An easy to create and inexpensive wire ring!
I posted this a few years ago on a jewelry forum and people seemed to enjoy it, so I thought it would make a great instructable. I sold a lot of these when I started making jewelry - I called them "Bellybutton Rings" and it was one of my very first designs.
I usually made them out of 20 and 18 gauge soft wire (half-hard is too brittle and the "bellybutton" isn't as tight because the wire springs out a little).
  • You'll need a ring mandrel (or suitable equivalent), a flat-nosed jewelry pliers, a wire cutter, a small metal file, and a length of wire (the example is made with 14 gauge soft sterling silver).
Step 1Initial Wrap
Initial Wrap
Wrap some wire around a ring mandrel twice so the ends shoot out in opposite directions.
  • Before I had a ring mandrel I used socket bits from a ratchet set - being metal they worked pretty well and it was easy to hold the ends of the bit while twisting wire to make the bellybutton. I tried a wooden dowel too but it would get all hacked over time.
107 comments
1-40 of 107next »
Jan 11, 2012. 1:35 PMvberry says:
Made the ring in silver colored 16 gauge aluminum wire and it really came out well! Again, thanks for the great tutorial! I'm getting ready to make some more for my daughters and granddaughters!
Jan 10, 2012. 3:32 PMvberry says:
I found this on Pinterest and decided to try it. I've made a few other wire rings and they were quite fun to make. I made 3 of these today using 20 gauge craft wire and they turned out pretty well for a first try. I'm going to get some 16 or 14 gauge wire and try some more. I also glued a bead to one of the rings to see how that would look. It was okay, but I'm going to try some rhinestones on the next one. Thanks for an awesome tutorial!
Feb 5, 2010. 5:50 PMswinding says:
So cute and easy - I used two 18g twisted together instead of one thicker gauge!  I think it turned out cool - kind of looks like a rose :)  Here's a pic.
Dec 3, 2011. 7:16 PMmrmwright1977 says:
wow this is beautiful
Jul 16, 2010. 12:20 PMGrey_Wolfe says:
Very pretty.
Aug 28, 2011. 1:41 PMgjanelle says:
very pretty:) reminds me of a flower hahah
Aug 21, 2011. 5:39 PMinsructoperson says:
Love it! Great job!
Jul 25, 2011. 3:13 PMkittknight says:
that's amazing how cool it looks from a wire, nice one
May 26, 2011. 7:57 PMThe nerdling says:
when i make on i will put a gem in it an post how to do that.
Nov 8, 2010. 3:51 PMCoffeeFreak says:
Just made this out of found copper wire. My GF loves it and is coating it with clear nail polish to keep her finger from going green.
You could almost put a "gem stone" in the middle.
May 26, 2011. 7:55 PMThe nerdling says:
i know how to do that
Apr 21, 2011. 9:43 PMshowkat21 says:
thanks,very good tutorials.
Apr 2, 2011. 7:54 PMVerdantic says:
Awesome instructable! Such a clever idea and so easy to make!
I made a set of four using colourful paperclips and only one wrap per ring, then bent the bands together to form a stackable set. It makes a nice toe-ring too!
Feb 13, 2011. 9:45 PMdmueth says:
Sweet, just made one for my wife.
Thanks
Jan 18, 2011. 8:11 AMLadylisa says:
I love this ring!
Jul 25, 2010. 1:02 PMjanettetsmith says:
Sweet! Getting my mandrel and wire and tools this very moment! Thanks for the instructions!
May 20, 2010. 6:24 AMjimjamaroo says:
now i know that it may not be the easiest thing to get a hold of but what about silver soldering the ends so you dont risk catching your finger on the tucked in ends
Apr 28, 2008. 10:26 PMbasketballstarz says:
so was their soldering involved in this? also - how/what did you make your mandrel out of?
Mar 13, 2010. 11:21 AMtheatre_tech_guru says:
i have done this for a couple of people i use a socket set and i made a sizing wire that has all the sizes that i have available so i can see what size to make them. but if i dont have it i can eye ball it pretty good
May 13, 2009. 7:21 PMShut Up Now says:
solder would be no good for you if it wasnt lead free...you should never have lead touching your skin for long periods of time..
Mar 21, 2010. 1:13 PMSteveH says:
If you were going to solder it you would want to use silver jewelry solder not plumbing solder.  The jewelry solder won't hurt you.
May 5, 2008. 5:21 PMcasey321b says:
no soldering i think I read a while ago but id have to check again... im to lazzy tho but im pretty sure no soldering
Mar 13, 2010. 3:21 AMwhopoder says:
Beautiful and creative!
Mar 12, 2010. 10:37 PMToxicity says:
i'm gonna make one to appologise to my girlfriend for something i dont know is my fault. i'll tell you how it goes when i do it!
Dec 1, 2009. 5:52 AMaressa says:
Wow!  I make wire rings too.  This one is incredibly easy.  Thanks for sharing!
Amy
Nov 26, 2007. 4:41 PMrickick says:
why not use solder and then melt some to make a design
Nov 5, 2009. 9:48 AMRoosterSocks says:
solder is very weak. i  think it would bend and scratch like crazy
Dec 3, 2007. 7:44 PMtyeo098 says:
Some solder has lead in it?
Lead+Human=BAD
Mar 15, 2008. 1:36 PMtwenglish1 says:
the lead in soldler isn't bad for you unless you like eat it or something
Dec 7, 2007. 11:05 PMHAL 9000 says:
You can get solder without lead. In fact, most doesn't.
May 27, 2011. 7:31 PMPwag says:
What about silver solder?
Feb 26, 2008. 10:19 AMNotbob says:
solder without lead does not flow as easy as solder with lead
Feb 7, 2008. 6:50 PMGrey_Wolfe says:
Silver solder would be an excellent choice. Since it would be jewelery quality, and still maintain the workability of solder.
Mar 24, 2008. 11:20 AMerie94550 says:
it hurts when it splatters right in between your eyes...
Jan 12, 2009. 11:28 PMbug on fire says:
i got it on my check
May 27, 2008. 12:30 AMGrey_Wolfe says:
I'm pretty sure that's true of all solders. I could be wrong though. Still between your eyes is better than in them. Maybe you should get some safety glasses, just in case.
Apr 13, 2008. 12:03 PMcowscankill says:
???? How did that happen...
Sep 23, 2009. 5:58 PMMattandJora says:
where did you get the silver wire?
Jul 31, 2009. 6:10 PMjdogsbart says:
a little bit of extra fancyness is that instead if just tucking the ends under you wrap them around the double band a few times
1-40 of 107next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:totemic
I was born in Minnesota where I've spent the majority of my life, and I've been active in many areas of artistic creation; including sculpture, jewelry design/construction, graphic design, ink drawing...
more »
