3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Simple and Inexpensive Cheese Press
Cheesemaking is an amazing alchemy that transforms milk into a profusion of different textures and flavors.  The entryway for me was ricotta, an easy and forgiving cheese to make with no fancy equipment or supplies needed.  Mozzarella came next, also very do-able with supermarket ingredients and kitchen utensils.  I was so pleased with the results of these first forays into cheesemaking that I decided to go all in and try making hard (as in consistency) cheeses like cheddar.
There is a certain amount of gear that you need in order to go to the next level.   One of the main pieces of equipment necessary for making harder cheeses is a cheese press to squeeze the curds under a specific pressure for a set amount of time.  I found cheese presses for sale online but they were expensive ($70-$275).  I decided that making my own was the way to go. I wanted something that would be able to handle up to two pounds of curds and generate up to 50 lbs of pressure.  I took my inspiration from a couple of similar press designs I found online and added my own ideas.  After a little experimentation I ended up with a press that was simple to use and inexpensive to build using basic tools.   Expect to spend between $10 to $25 depending on how much stuff you have at home already.
As with any set of instructions this will guide you to replicate what I made.  Don't feel constrained by my ideas though, you should modify my design to meet your needs any way you see fit.
Check out my blog for other stuff I've been making including a cheese cave for ageing all this cheese I'm going to be making with my new press...
Step 1Stuff You Will Need
Materials
1 piece of wood-    3/4" x 7 1/2" x 5 1/4"
2 pieces of wood-  3/4" x 7 1/2" x 1 3/8"
2 pieces of wood-  2" x 5" x 5"
2 pieces all-thread rod at least 13" tall (depends on the springs) x 3/8" dia
Asst'd 3/8" dia. hardware:
2 wingnuts, 4 nuts, 6 washers, 2 lock washers
2 springs w/ 50lb compression strength approx. 3 1/2" tall x 7/8"dia (more about this on step 4)
4 screw in feet
1 index card or piece of card stock
1 small wood screw
1 plastic pitcher
1 5" x 5" piece from a plastic cutting board
Some scrap wood pieces
Mineral oil      (you can get this at drugstores, make sure it is unscented)
Tools
Saws (I used a table saw, jigsaw and a handsaw)
Drill and bits
Sandpaper
Ruler
Small square
Pencil and a pen
Possibly a tap for threading the holes for the feet (optional)
Bathroom scale or any scale that will read up 50 lbs.
23 comments
May 20, 2012. 8:15 PMFrederbee says:
I love your press, the book on cheese-making I just picked up called for it in every one of my favourite cheeses, and the prices of the presses terrified me (what if I only use it once and then stop?). Thank you so much for your instructable, when I finish making mine I'll definitely post pictures. Depending on how well I use it, I may end up making more than one for bigger cheese!
Also, isn't it odd that the spell-check on the comment box underscores the word instructable?
Nov 7, 2011. 2:24 PMEddie j says:
I took a 3 hr class on cheese making (Gouda) is what we made. he told us that 50 lbs is not always 50lbs it all depends on the surface area of your mold. for
example a 4" round mold will have less surface area than a 6" round mold. which means that it will also have more pessure on it. to find out how many sq inches you have in a round mold is to PI 3.14 X R X R = sq in
Now I am trying to find out the PSI on the soft press and the PSI on the hard press.
Oct 10, 2011. 7:38 PMAnna W says:
Excellent! Beautifully crafted, well documented and explained, and just what I've been looking for. I should get one made before the cold sets in. Thank-you!
P.s. Have you any further suggestions/modifications since then? And how goes the cheese-making?
Jul 15, 2011. 2:25 AMmslaynie says:
Is it really this easy to make cheese? I mean, I don't mean it's easy, but... this actually looks like something I could do! I'm speechless...
Dec 22, 2010. 1:04 PMcraigbw says:
This is my next project in 2011. I can also envision using the press for applications other than cheesemaking! Thank you for doing all the design work.
Dec 20, 2010. 7:26 AMaeray says:
Cheesemaking rocks, as does your press. I'll be building one of these well-designed-and-executed presses once I get my meat-curing fix. Meat and sausage curing has been distracting me from cheesemaking for a while now (and the kraut, and the kimchi, etc). Thanks!
Dec 20, 2010. 11:43 AMaeray says:
I just finished some bresaola and corned elk, and I'm working on a prosciutto and some guanciale. Elk landjager is next, and I'll be using the kitchenaid as well, so hurry up and post the stuffer design!
Dec 19, 2010. 7:16 PMtbcross says:
I love love love this ible!!! Did I mention I have goats? I had been dreading shelling out the $ for presses once we start getting milk. This is brilliant! Thanks
Dec 20, 2010. 9:19 AMtbcross says:
I've got a recipe for queso blanco and one for mozzarella. My step-dad is from Wisconsin and he influenced my eating habits greatly, ....I eat cheddar on my pancakes even! I've got mini's Nigerian Dwarf and Pygmy so I am hoping for milk next spring.
Dec 19, 2010. 5:10 PMChicken Girl says:
This is great! I've been wanting to get into cheese making but was a little intimidated.
Dec 19, 2010. 10:26 PMzack247 says:
I love cheese, but i don't think making one of these will be done by me.
great work on the cheese press, and it looks like the cheese turned out great too!
Dec 19, 2010. 9:12 PMRonyon says:
spike3579:BTW, your blog is great, as is your wifes, and I have just spent a couple nice hours on perusing them, and the links from them...
Dec 19, 2010. 7:37 PMjprewitt6 says:
I like your press, especially the fine detail of the wood, etc.
Dec 19, 2010. 7:27 PMspillmatic says:
very cool! practical, straight forward, very useful. I might not be pressing cheese in my near future, but this is how a good instructable is made. Here here!
Mike in Portland
Dec 19, 2010. 4:48 PMRonyon says:
Uh, wow! I am an avid bread maker and have been considering branching out into cheese.Your Instructable is inspiring!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:spike3579(Mike and Molly's House)
I like to make stuff, all kinds of stuff. Everything from building a guest house out of household trash to how to make holiday baby hands. I'm posting projects here at Instructables as well as my bl...
more »
