A Sneaky Soda Can Safe
21,507
33
16
Posted in HomeHiding-places
Introduction: A Sneaky Soda Can Safe
About: Carnegie Mellon Design + HCI
Here is a simple instructable that can prevent family members coming into your room and taking your valuables. The soda can safe is a clever yet secure way to confuse oncoming friendly marauders.
Step 1: Materials List
You will need...
1. can opener
2. a soda can (Pepsi is easiest to remove top)
3. foam core, paper towel or spray insulation... your choice
4. some kind of jar or canister. (I used a small jam jar i had left over)
5. Hot glue
Step 2: Putting a Hole in the Can
First clean your can so that it doesn't start growing bacteria. simply guide the can opener around the mouth of the can and make a clean cut around so that you have the top of the can in a disk to work with.
Step 3: Holding Installation
This part is probably the trickiest. I advise to use a product called Great Stuff which is a spray insulation that expands and turns into a very decent foam holding material for your jar. I was cheap and made this project in less than 15 minutes and used bunched up paper towels to take up space. as you can see in the photo above i estimated how much paper towel to put in and had to fit it around the jar to keep it in place. the good thing about Great Stuff is that while it is expanding you can go ahead and place the jar in the perfect position, and if it expands to much over the jar you simply cut it off with a utility knife.
Step 4: Making the Cap
In this last and final step all you need is the piece of soda can you took off and the lid of the jar you chose. It is pretty self explanatory. all you really need to do is just hot glue them together as in the photo.  Now when everything dries put them together and you have your very own soda can safe! have fun!
    • Make it Move Contest
    • Spotless Contest
      Spotless Contest
    16 Comments
    I haven't been able to do this and really look like an unopened soda. You can buy these professionally made. I have seen them at truck stops and on-line
    You can get it perfect with almost no skill.
    I may post an instructable soon.
    The trick is not to use a can opener, but a dremel with a short blade and carefully cut all around the top.
    I was thinking dremel would work better than a can opener as well, before ever looking this up. You can also use silica along the edges and a TP roll, or another soda can cut down & rolled to your preferred size in the middle. Keeps it about the weight of a real soda. You will need an O ring to seal it off.
    O cool... thank you... i really didnt care about aesthetics but thank you for the support i suppose
    thanks you your feedback is greatly appreciated, of course your not going to get it perfect but up on a shelf no one will tell the difference.
    Interesting idea. Even more interesting username!
    How would you close the can? That would problably be a good thing to put in the instructable. After you glue the lid does it snap on or is their a way to screw it on and off?
    well mine after usage becomes easy to snap on and snap off but it depends on the jar you use. Thanks alot on the feedback. I should be coming out with a new instructables today or tomorrow:)
    Thanks when I find a bottle small enough I think id like to try it.
    Haha i hope your being sarcastic man if you want to see some other photographs ill be making a flickr soon:)
