3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Solar Powered Reading Light
Using the basic Solar charger developed here, we can build a very simple and effective reading light. Bright enough to light a small room, it is more than bright enough to work by, and a day's recharging is all it needs to provide over 2 hours of use.
A garden-variety solar cell (2-volt, 20mA) is all that's needed, and the entire circuit consists of ten basic components.
Step 1The Parts List
The Parts List
The  components required are:
BC327 PNP transistor
BC337 NPN transistor
1N914 or 1N4148 Low power signal diode
10K resistor
5.6-ohm resistor
100uF 6v capacitor
330pF capacitor
100uH inductor (A larger can-type is chosen for its lower internal resistance. Thanks to acmefixer for bringing this up!)
1 x Red LED 20mA
1 x White LED 100mA. A wide angle unit (90-degrees or more) is recommended here to avoid glare and hot-spots. I also chose the piranha style so I can get the 90-degree angle when I assembled it.
Connecting and Mounting hardware.
2 comments
Jun 2, 2010. 2:22 AMacmefixer says:
QS, what I'm really interested in (and see no info on) is what is the battery holder and where did you get it from??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
