Introduction: A Step Up for Natali
Picture of A Step Up for Natali
Two level step ladder with rail support.
perfect for unsteady balance and weak legs.
Step 1:
Picture of
A - cut and weld two side frames using 30*20mm steel profile. 20*4mm steel is used for the rail seatings.
B - cut and weld 20*20mm steel profile for the step, and 30*20 for the inner legs as shown in the picture.
C - weld all parts together, keeping the step level. use 4mm steel to weld the back legs to the inner legs
D - add 20*20mm cross braces at the front, as shown.
Step 2:
Picture of
B - cut and weld 20*20mm steel profile for the step, shown in the picture.
C - cut and weld 30*20mm steel profile and 20*4 bar, making the top rail seating.
D - weld all parts together, keeping the step level, adding the front cross bar.
Step 3:
Picture of
A - We used 10mm mahogany wood for the two steps, cut to size.
B - The rails were also made of mahogany, 20*25mm with rounded adges, cut to length.
C - Screw and glue all the wooden parts to place.
D - Assemble all parts with arm hinges, cut to precise length. Be sure to add lubricant.
seamster (author)2016-06-21
Very interesting design! Got any photos of the actual, physical step stool? If you did, that would be neat to see how it looks in real life.
About This Instructable
296views
9favorites
License:
More by liormoscoviz:A Step Up for Natali
Add instructable to:
