As part of a longer term project to build an Aluminium Forge blower using a Stirling, I decided to try and build a basic LTD to make sure I could get the damn thing to run.
I had to use whatever I had lying around to try and build it, so my materials list may not be the best, or the right way to do it.
I had a good look at a number of Stirlings on the net before I began. It was obvious to me that the most difficult part of the manufacture would be the sealed piston assembly and the linkages. These were cast using the resin process in one of my other instructables.
I couldn't get the video to embed correctly, so here's a link to the Youtube video:
VIDEO
Step 1: Materials
I used the following materials to build this Engine.
Two hard drive platters from a 3 1/2" HDD
3 CD-Rs
A 10p piece
A 2mm steel rod from an HP printer (scrap)
A 2.5mm brass tube (dunno where that came from)
A piece of 22mm (1") copper pipe
A plastic storage container (Tescos 78p)
A bit of sponge floor tile
Some resin and alginate
Odds and ends from old scrap printers
Various glues, solder etc.
My main goals were to assemble a working engine that looked nice without doing too much machining. Access to a drill press and possibly a small lathe would be an advantage.
Here are my main 'ingredients' from scrap.
lithiumnights says: Nov 13, 2011. 1:10 PM
very smart looking sterling
Mudbud says: Feb 21, 2011. 12:03 PM
I kno wthis is an old instructable but what is the copper tube for? I see the crankshaft with the poles, one in the copper tube and the other in the diffuser. whats the copper tube do/ do I need it?
marshon (author) in reply to MudbudFeb 21, 2011. 2:26 PM
The copper tube is the power cylinder, and yes you do need it or the motor wont run. Sterling engines require two pistons, one is a sealed unit (the power piston) and the other is the diffuser piton who's job it is to move the air in the system from the hot side to the cold side in order to run.
Mudbud in reply to marshonFeb 22, 2011. 7:55 PM
thanks. I guess I'll find the parts later then
Kinnishian says: Jul 15, 2010. 4:48 PM
Hi. I really appreciate your instructable. It was the balance of feasible to find/make similar materials, and good design. If I can offer some feedback, some of those yellow boxes on your photos identifying the peices, like in other ibles, would have been very helpful for me. (I'm not quite done yet with my engine, i'll post a picture).
acobalto says: Jun 18, 2010. 11:02 AM
Interessante, mas quanto tempo será ele aguenta funcionando ?
spex says: Jun 16, 2010. 6:56 AM
hello have you any video of this engine?
marshon (author) in reply to spexJun 16, 2010. 7:53 AM
There's a link on the introduction page.
rimar2000 says: Jun 11, 2010. 4:02 PM
Very good work, clean and prolix. I think the upper and lower CD must be painted with a black permanent marker, to enhance the heat transfer. It will be better if you remove before the aluminum coating.
marshon (author) in reply to rimar2000Jun 12, 2010. 12:17 AM
Interesting, but there are no upper and lower CDs, they are metal hard drive platters and they don't have an aluminium coating. It would only be worth painting the lower hot plate since black attracts heat, the last thing you want on the upper plate. A better idea would be an ice container on the upper plate to increase the differential temperature.
trike road poet in reply to marshonJun 14, 2010. 8:12 AM
Just to let you know, infrared is actually absorbed better by the color of green found on the bottom of an oak leaf, then black. Many black paints are in fact I.R. blocking, to prevent fading, and you will actually lose heat. You may notice that many of the professionally made solar collectors are green inside, not black for this reason. The closest color to the green needed is ironically good old army OD Green. (go figure.) [If you have your heart set on a black that is very IR absorbent, try the soot you get from a candle, there is no IR blocking in this material, and a spray of regular Matte finish clear spray from an art store will fix it in place.] This project is great, introducing casting, fabrication and unique materials. Seriously ought to win a prize, this is the sort of expansion on skills and knowledge that makes Instructables such fun! Thanks for the project, going to be my winter project.
rimar2000 in reply to trike road poetJun 14, 2010. 12:25 PM
Awesome that of green colour, I didn't know it! I agree with you about this instructable, it is very good.
drorosz in reply to marshonJun 13, 2010. 7:40 AM
Just how big is a "10p" piece??
marshon (author) in reply to droroszJun 13, 2010. 7:51 AM
About an inch in diameter, but any metal disk the right size to seal the hole in the platter will do the job. I just happened to find that a 10p piece fit the hole.
rimar2000 in reply to marshonJun 12, 2010. 6:13 AM
Pardon, as I speak Spanish, not English, I do a superficial reading on the long texts. So, I don't saw the detail of the hard disc plates, only saw the photos. I insist that both sides should be black. A black surface is permeable to heat in both directions, and the Stirling engine, as a thermodynamics application, is not nothing but a converting heat into motion. More heat transfer, more effectiveness.
alienwear in reply to rimar2000Jun 13, 2010. 6:57 AM
He is correct, black heats up quicker, but cools down faster as well. Both plates should be black for maximum efficiency.
dylanyoung says: Jun 11, 2010. 10:17 AM
this is cool.....but is there anything i could swap for the resin???????? 5*
liam2317 in reply to dylanyoungJun 14, 2010. 11:17 AM
Copper pipe/tubing. You can buy two sizes that fit very closely within each other. You will still need something to fill the inner tube with though, but at least this way you don't have to make a perfect cast.
marshon (author) in reply to dylanyoungJun 11, 2010. 10:48 AM
For the power piston you can basically use anything that will give a seal and still run with very little friction. I've seen pistons made from epoxy putty, JB Weld, graphite, nylon and aluminium. I use resin because it's very easy to work and get a good finish. For the bearings, you could use a hard nylon like Delrin, Teflon or acrylic. For the crankshaft you could obviously use real bearings. I'm currently working on another engine using hard drive bearings for the crankshaft.
alcurb says: Jun 14, 2010. 7:42 AM
Very nice photography. In the final picture, the flywheel looks like machined brass. Kudos.
Nicola Tesla says: Jun 10, 2010. 2:44 PM
amazing 5*
Phil B says: Jun 10, 2010. 6:10 AM
This is the best description of a Stirling Engine project I have seen. I would like to try it sometime. Thank you.
marshon (author) in reply to Phil BJun 10, 2010. 6:28 AM
If you decide to make one here's what I learned. Don't try to glue the diffuser cylinder together. It would have been far better if I had used a slightly smaller food container or a bit of 3" plastic drainpipe and bolted through the outside with a pair of gasket seals. The glue simply cant keep a seal against the polished surface of the platters, especially once it gets hot. I am constantly patching little leaks that develop.
Phil B in reply to marshonJun 10, 2010. 9:03 AM
Someone gave me a kit for a Stirling engine. I have not had time to finish it, yet. One step had me gluing a brass connecting rod guide to an aluminum disc, but it did not stick. I need to re-engineer that step. Most of the kit is pre-punched cardstock. Thanks.
AndyGadget says: Jun 10, 2010. 5:08 AM
Whoo - That's quite a project. I bought one of a similar design some time ago. Congratulations on getting the power piston friction low enough and the displacement disc rod seal good enough to work - That must have taken some time. Mine has a glass tube and a graphite piston and bearings.
marshon (author) in reply to AndyGadgetJun 10, 2010. 6:25 AM
The resin is quite forgiving as bearings. I just drilled the holes the same diameter as the rods, an sort of forced them through and a bit of spinning beds them in. Very little friction. However I am thinking of another one using HDD bearings.
pilotox says: Jun 10, 2010. 3:18 AM
Congratulations, it looks very professional!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
