Introduction: A Sulky Lamp
About: I am an interaction designer and love physical computing.
Concept:
I made a lamp that always needs attention. It was inspired by my wife. I am a graduate student so I am always busy with my schoolwork. My wife wants to talk with me when I come home. When I pay little attention to her, she gets sulky, and I walk on eggshells. I put her characteristic into this lamp. To keep turning on the lamp, a user has to wind up a key every one hour. The lamp will turn off when the timer goes to 0 minutes.
If you make this lamp, please treat it well. (Tick-tock sound is a bonus for you.)
Buying lists:
Arduino Nano (ATmega328P)
Basic Desk Lamp
5V 5W USB Light Bulb
USB Type A Female Receptacle Breakout board
Metal Clock Keys
Cooking timer
Hall Effect Sensor (A1301/A1302)
Magnets (6 X 2mm)
Flat Phillips Head Screw 6/32 (2-inch long)
Nuts, 6/32
Step 1: Laser Cut Bottom Part and Disassemble the Lamp
For the bottom part, I designed and cut acrylic panels by using laser cut machine.
Disassemble the lamp.
Step 2: Insert Magnets and Sensor / Connect a USB Lamp
1. Put the hall magnetic sensor in the body part for detecting the magnet on the rotation part.
2. Connect a USB lamp, hall magnetic sensor, and Arduino Nano.
3. Insert magnets in the holes.
Step 3: Code and Schematic
Schematic ^
Code
<p>/////// HALL EFFECT SENSOR ///////////   <br>#define NOFIELD 505L
#define TOMILLIGAUSS 1953L
</p><p>// LED(USB Receptacle Breakout board) to digital pin 3</p><p>int led = 3; </p><p>// Hall effect sensor to analog pin 0</p><p>int hall = A0;</p><p>// The lines below are from <a href="https://playground.arduino.cc/Code/HallEffect" rel="nofollow">https://playground.arduino.cc/Code/HallEffect</a> by Rob Tillaart</p><p>int gauss;
int gaussX;
int gauss2;</p><p>
void setup() {
  pinMode(led, OUTPUT);
  pinMode(hall, INPUT);
  Serial.begin(9600);
}</p><p>void DoMeasurement()
  int raw = analogRead(hall);
  long compensated = raw - NOFIELD;                 // adjust relative to no applied field
  long gauss = compensated * TOMILLIGAUSS / 1000;   // adjust scale to Gauss
  gaussX = constrain(gauss, 0, 500);
  gauss2 = map(gaussX, 0, 500, 0, 255);
  Serial.println(gauss2);
//    Serial.println(raw);</p><p>  analogWrite(led, gauss2);
}</p><p>void loop()
  DoMeasurement();
  delay(100);
}</p>
Step 4: Last Step
Done.
