A Swing Set that Generates Electricity
 by Cleveland Motley
Featured
Step 2: Work out the design, assemble materials
originally we were interested in using a product called LED vision flex on the singing chains, to simulate a video by flashing a section of the image as it flew by. Due to time and money we decided to just make the juice and we figured we'd work out what to power after we knew it would work.
We settled on hanging a drive shaft a few inches below the top of the swing by pillow blocks, and to attach the swings to that by roller clutches, (or roller bearings as some say. Essentially ratchets). as the swingers swung forward they would turn the shaft forward, and when they swang back the roller clutches would freewheel and the momentum of the generator would keep moving forward. if the two swingers were out of sinc. then there would always be someone pushing the generator forward.
The generator was to be connected to the drive shaft by gears and chain.
The picture shows when we thought we would be able to fit 3 swingers.
The roller clutches which fit around the drive shaft were to be pressed into a standard pipe, and the swingers chain secured to the pipe. that way the weight would be distributed over the drive shaft and the swings would be removable.
All in all the finished product came out very similar. which i don't usually expect.
chipper35 says: Oct 21, 2012. 7:10 PM
I was highly skeptical when I initially landed on this instructable; however, after a careful read.......VERY GOOD JOB!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
