Step 2The schematic!
The relay I chose was a Z240D10 from OPTO22. It has a maximum rated current of 10 amps @ 120VAC. This should be more then enough for my desk. The control input accepts from 3-32 VDC. So the 5 volts from the USB connector is more then enough. It was also chosen for its low cost. If you need more current capacity you can order a larger SSR.
The protection part of the circuit is three fold:
The first line of defense is the actual SSR. It uses an optical isolation between the power and control rated at a 4000 volts.
The second part of the circuit is a pair of 125mA fuses that will blow if over loaded.
The third part of the circuit is a pair of (1.5KE6.8CA) 7.14v transient voltage surge supressing diodes (TVSS) These are similar to a Zeiner diode. When the voltage across the terminals exceeds a limit. They begin conducting. Except unlike the Zeiner diode, they are bidirectional. So if for any reason the voltage in the control parts of the circuit exceeds 7.14v they act like a short and blow the fuses. The power dissapation for these parts is rated at 1500 watts for 1 millisecond. Which is more then enough to blow the fuses and protect the circuit. Circuits like this one are used in various communication devices that are subject to lightning and power surges.
![Smart Master/Slave Power Strip for your PC [mod] (self shutdown but zero standby)](http://img.instructables.com/files/deriv/FVX/H8BL/FY3KH7OK/FVXH8BLFY3KH7OK.SQUARE.jpg)
i am searching some thing like this but much more advance...so that i can control at-least 8 switches with USB.
