A couple of days later, I remembered having seen a sketch of a chair in a book titled "Nomadic Furniture" by James Hennessey and Victor Papanek called a "Savonarola Folding Throne". After a quick search on the internet for better pictures of it, I thought I figured out how it was put together. Although I have only seen them in the open chair position and never folded, I could only imagine that the following is a pretty close (albeit very simplified) approximation of how it is done.
Remove these ads by
Signing UpStep 1: Materials and tools
Tools
-Table saw - for ripping lengths of pieces
-Miter saw with attached jig - the jig makes sure that every piece is exactly the same (and all without measuring)
-Router with 5/16" bit and attached jig - the router makes sure the holes are nice and straight and the jig makes sure the spacing on the holes are exactly the same on each piece (again, no measuring needed once you make the jig)
-Drill with varying bit sizes and a 3/8" boring bit for counter sinking screws
-Sander - this keeps the slivers out of our tender bits
-Philips head screwdriver
-Tape Measure
-Rack for applying stain and polyurethane, and also for drying
-Foam brushes for apply stain and poly
-Safety goggles and hearing protection
-Square for making sure things are squarish
-Vinyl paper for spacers - I'll explain these later
-Hacksaw - for cutting dowels to length in the finishing stages of the build
Materials
-Three 1"x4"x8' boards (actual dimensions 3/4"x3 1/2"x8') - These should be as knot free as possible because we are using such small pieces and if the knots span the width of the piece it will be very weak there (I am using pine for this build, but other woods work very well too, as you will see in later pictures)
-Two 5/16"x3' wooden dowels
-Thirty-four 1" screws (something reasonably appropriate for use with wood)
-Wood glue
-Wood stain - optional depending on type of wood used
-Polyurethane - again, optional depending on type of wood used
Visit Our Store »
Go Pro Today »
And I like your work area!
PS: Just to bother (and to challenge) your remarkable intelligence: how would you imagine a back seat could be added to this? (I guess chairs like these would look great on a country house dining room... just a thought)
Ever since I started making these chairs last year, I have been wondering how I could put a back on these things. I've never tried very hard to figure it out, to be honest. I have a couple of ideas and with you asking the question, I will now have to try to answer it for myself.
The biggest obstacle I have faced with it is how to have it be part of the chair (not a separate piece that could get lost or misplaced) that will still allow the chair to fold up to a nice compact package. Maybe it will have to be separate, but somehow attach to the chair while it's folded... I just don't know....
I'll work on something and put up a second instructable on how to do it once I have a decent solution.
A cloth back on two sliding rods would work but not really with the aesthetics of the chair.
Great job, won't be able to get the idea of putting a back on this out of my head all day now... Shouldn't have read the comments...
The cube would be 21 1/4" h x 24" w x 14" d for the open chair and the closed chair cube would be 37 1/4" h x 14" w x 4" d.
I really hope she makes it and please post some pics here when she does. I'm sure everyone would love to see it!
I'm not sure what all the rules are for stuff like that to be honest with you. I'm mostly self taught and learn by trial and error. I've never had any trouble with the stain or the polyurethane by using this method and have done the exact same thing with these chairs, tables that I have made, a desk, my kitchen cabinets, clothes drying racks that I make, one beast of a fish tank stand, etc. I'm sure there are other things as well, but you get the idea.
If anyone reading through these comments can help us out, it sure would be appreciated if you left a comment to help us answer this.
Wouldn't it be easier/more precise if you cut them into strips later in the process?
What would make the method you are suggesting more precise? Would you suggest drilling the holes before the rip or just cut my lengths? If you could lay out your suggestion more clearly, maybe a quick step by step, I will try it on my next build and let you know how things go.
I would probably rip in the end of the process (after step 4).
It just seems that you would always get 4 sets of virtually identical pieces*, and reduce the cuts/holes you need to make by 75% (the downside is that the ripping would take more time, and you might ruin a nearly completed piece).
*) I guess this doesn't matter much if you have proper jigs for everything, but maybe it might take less time.
Drilling like that would require a drill press or something with much more travel than I have on that router setup. I don't have a drill press but I'll have to see if I can come up with something....
Thanks for that!
Nice work on your folding chair, I can't tell you how many times I have looked at it. I think its really amazing!
Thanks!
Thanks for the great link too. It's really worth checking out.
Still, if someone wanted to make the chair base a bit wider, they could simply add a couple of inches to the side pieces and leave all holes and other pieces the same and it would turn out just fine. The seat height would be a bit higher, but I don't think that would be an issue for most people as the 17 1/2" seat height is on the low side of standard seat height range.
Awesome!
