3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Word Clock
Step 8Houston - We have minute LEDS!
Many many people have asked, so I have modified the design to support the addition of Minute LEDs on my clock.  You are welcome to add them around the corners, or in a straight line if you like.
There is new firmware for the PIC micro - but the firmware does not mind if the LEDs are there or not - meaning that if you would like to have the minute LEDs you can add them, and if you don't want them, you don't have to have them.
Start by downloading the new firmware into your micro - you can find the HEX file for your micro attached to this page.
Then, we need to add the cabling for the LEDs onto the back of the controller board - There are a few spare pins that are not really used that we can use for the minute LEDs.
LED1 - Pin17
LED2 - Pin18
LED3 - Pin10
LED4 - Pin33
Ground - Pin12
Simply connect some 5 conductor ribon cable to the pads shown above.
Drill some holes in the front of the clock for the LEDs in each corner and mount the LEDs using a small amount of hot melt glue.  Solder a  270 Ohm resistor to each cathode (Short lead), and wire the ground lead from your 5 conductor cable to each resistor.
Finally, connect the LED leads to the anode of each LED, and tidy up your wiring.
When the clock is turned on – the self test will cycle through all of the LEDs to re-assure you that you have connected them correctly.
Simple as that - You may mount your minute LEDs however you like.
the photos I have attached should be helpful!
Finally - Remember when you download the files - you will need to rename the file with the correct extension .c  .h,   and .hex  depending on which file you downloaded.
6 comments
Dec 7, 2011. 10:15 AMmahsa arian says:
thank you *drj113*
for Minute LEDs :-) good idea
nice clock..
Oct 10, 2010. 9:39 PMchinx says:
gud day sir..we've finished installing the leds and other components of this project but the leds wont light up..we've try double check our connections and loaded the program twice..still the leds wont light up..can u please send me other program or schematic diagram for this..?i guess i donwloaded the wrong one..thank you sir.
Jun 27, 2010. 12:57 AMMavamaarten says:
GENIOUS :D
May 31, 2010. 5:52 AMMIRAMANALI says:
what's the size of the controller pcb?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
362
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
