When I use my laptop in bed, it's often uncomfortable. I have to balance the laptop on my lap and sit up, or on my chest when laying down. This laptop stand makes both laying and sitting laptop use a whole lot more comfortable, and it's simple to make... about $15 and 30 minutes. Let's do it!
Step 1: The background
Another commercial stand is the Lapdawg laptop stand - possibly the worst name ever.
Materials Needed:
-wood strip, .75 in x 1.75 in x 6 ft. Just about anything of the right size will do.
-hard board, MDF board, etc - I used MDF the first time due to the clean white melamine coating, but the plain hardboard looked better and seemed more durable.
-two knobs attached to screws/bolts
-two big washers
-two socket anchors
-2 very short wood screws (for the lip)
-4 medium wood screws (for the legs)
-4 small nails
-4 plastic checker pieces (optional)
Tools:
-circular saw (could use a hand saw, but it'd be messy)
-power drill
-(Optional) dremel w/ sander bit
NOTE:
This was made to be simple and quick. You don't really need too many measurements; just line things up and saw away. I only measured the tray itself (11 x 20 in). The rest are self-evident as you're going along. Even the lips were circular-sawed freehand. Be careful where you put your hands! (If you want to keep them).
Step 2: The Legs
First, get the .75 in x 1.75 in x 6 ft stick. The height/width dimensions are not important, just something about that size. You should have at least 6 ft. Cut it the stick in quarters (in half, and then each part in half again). This should yield (4) 1.5 ft sticks. Great.
-Round the corners
With the circular saw, cut off the edges on one side of each stick. Be careful! This is to round the corners so they don't stick out as much. Optionally, you can take a dremmel and smooth the edges here (I made them very round... really doesn't make any difference).
-Drill holes
Pair up the pieces, and stack them so you can drill through 2 at a time. Now drill a hole big enough for your big screw/bolts and socket/anchors through 2 posts, and then the other 2 posts. This makes sure that the holes are aligned. Make sure you're holding the drill completely vertical! (unlike what I did this time... still came out ok).
Step 3: Leg Hardware
Finding the Hardware
The black knobs + screws that I used are very hard to find. Most places do not have these. Big chain hardware stores (lowes/home depot) carry similar 3-prong triangle knobs with screws attached, but the screws are usually not very long. For alternatives, the easiest thing to find would be a normal bolt and a wingnut. Instead of turning the knob/screw into the T nut, you turn the wingnut on the stationary bolt. Same effect, different parts.
Those stores also have wingnut/bolt combos - basically a bolt with a wingnut on the end. If you can find one long enough, these are probably the best alternative.
Optional jackfishjoe checker mod:
Thanks to an idea by Strapped-4-Cache , which was tested out by jackfishjoe , we have a great mod for the joints. Normally the joints are held in place by the friction of the wood, and the pressure of the bolts holding the wood together. This requires a lot of pressure and can be a pain sometimes. A better way to do this is to insert plastic checkers pieces so the "teeth" grab each other and prevent movement.
-drill a hold through the center of 4 checkers
-carve a circular impression/hollow in each leg for the checkers to be inset slightly. This will be on the sides facing each other, so the knob goes through each checker.
-assemble the legs like so: knob - washer - wood - checker - checker - wood - socket.
The checkers should face each other and lock into place via the teeth, and when assembled you shouldn't really be able to notice the checkers. This will allow you to use less pressure to lock the feet in place, and avoid cracking the wood (or having the platform slump down and accidentally drop you laptop).
Step 4: Make the tray
Cut two more very small strips of hardboard, these will serve as the lip. Make sure they're straight (or straight enough), then line them up on one end of the tray and nail them down. Put a screw on either end of the lip, since nails don't seem to hold very well. Use short screws so they don't poke out the bottom of the tray.
Step 5: Attach legs
Step 6: Celebrate
You should be good to go. Tighten to where the legs wont move under the weight of the laptop (plus your hands as you type). Put the laptop stand over body, and put laptop on stand resting on the lip. Use laptop freely and abundantly, full of newfound semi-ergnomic convenience. Great for surfing, watching movies, etc. You may notice your arms get tired with long typing; make sure the laptop is as close to you as possible, that you don't have to raise your elbows off the bed to type.
Step 7: Other Thoughts
Update: view Supafly's comment below for the "leg-nail" mod. Supposedly it works great, and it seems the best/easiest way to assure no slipping. Thanks supafly! If you can't find his comment below, then here's a basic description: Drill holes in the bottom leg starting near the joint and going out along the leg. When you assemble the leg and open the joint, you can put a nail in one of the holes and it'll stop the upper leg from sinking. You can move the nail from one hole to another to accommodate different angles, and you can remove the nail to allow the whole thing to collapse.
The length of the legs will be determined by your stomach size, arm length, and how comfortable you want to be. I make it as short as will fit over my gut. If you wanted to get creative, you could cut out the portion of the lip/tray that touches your stomach, as long as there is enough lip on either side to hold the laptop from sliding off. A small indent like this may give you an inch or so (till the laptop is resting on your stomach), which may make a difference in comfort.
If you make one, please post up and let us know how long it took, how much it cost, and what it's like to use it. If you have suggestions, post them up. Good luck!
Visit Our Store »
Go Pro Today »
I finally came up with a variation to the design using two flag pole holders and two wooden dowels. This design is actually very straight forward. You need to use slightly wider boards on the outside. Wide enough so that the flag pole holders can mount. I drilled a hole in the dowels so the tightening knob and screw that comes with the flag pole holder would go all the way through dowel so the dowel could not twist in the holder.
I am quite happy with the design. The flag pole holder can be fully adjusted and locks into place for a wide number of angles.
thanks for all your great Ideas... here is my Try :) Its really comfty, y Ellbows can rest on the wooden staves on both side and I can screw it in every position, even the underground is not even, so i just screw the both sides differently :)
For the tricky part I used simple Spanner (dont know the word in english) but you all know this :) its cheap and very stable :)
I used for the middle panel pine wood from the alps, nice smell, and for the side some hard wood, walnut... The ornaments are freely designed and they giv good circulation for the machine :) thanks for all your inspirations !
good luck Geggo
http://refurbished-computers.ca/
Originally I was using the same design as the original. I thought I could put a rubber washer in between the pieces of wood to keep the legs from slipping but that was a total fail. So I decided to add supporting legs like another commenter did. I wanted to be able to adjust it though so I added 3 notches.
I was able to find the knobs at Ace Hardware. They had a few bins that had a variety of different knobs. I still like using the knobs even though I have the support legs because it keeps the whole thing from shifting.
All in all I think it turned out pretty well but if I did it again I might try the checker idea. So here it is:
Strangely enough, I've been using the unrefined v1, just tightening the knobs to make it stay. It's worked fine, and I use this just about every single day. But if I were doing it over, I'd use plywood + the same support system you used.
I started using it last night and I love it. Thanks for the idea!
Finally!
I was thinking of cutting them half as deep and cut a couple big notches (like a castle top) then use a hole saw to cut a groove for it to sit in the wood. Or dremel it. Then epoxy it in place. One or both would be sitting above the wood line, the other could be flush.
David
They are 1 11/16 inches wide and 3/8 inch high. They just fit on a '2 inch' piece of stock. The teeth are 1/8 inch high and 1/4 inch wide. The bottom is 1 1/4 inch wide with a 7/8 inch hole. They appear to be made of steel, very strong but light. They mesh together very well but I might use a thin rubber washer between them to keep them from slipping. They have 12 teeth and 12 valleys so they would work for 0/30/60/90 degree angles.
David
David
*I had found a torque washer online that looks like the socket/anchor but a square hole, no threads and the barbs. Couldn't find it locally.
What program doyou use to do this sketches?
Thanks and regards
Even without the channel, the stand could probably fold *mostly* flat, which is moot since I never really move it anyway. We'll see.
I'd love to see it in action. How do you keep the mouse from falling off?
