3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A better laptop stand for bed
Make a simple but incredibly useful Laptop Stand for around $15 and 30-60 minutes! Great for use in bed while typing, browsing, and especially watching movies.
When I use my laptop in bed, it's often uncomfortable. I have to balance the laptop on my lap and sit up, or on my chest when laying down. This laptop stand makes both laying and sitting laptop use a whole lot more comfortable, and it's simple to make... about $15 and 30 minutes. Let's do it!
Step 1The background
I use my laptop in bed a lot, as it's more comfortable for me. However, it's hard to balance the laptop on my chest and type with my hands sideways, so I needed a laptop stand. I found this one, but I'm a cheapskate and it looked simple, so I decided to make one myself. Turns out I spent just over $15 and took 30 minutes in the garage to make it, and it worked great for months! I just made another one, so I've chronicled it here for your building pleasure.
Another commercial stand is the Lapdawg laptop stand - possibly the worst name ever.
Materials Needed:
-wood strip, .75 in x 1.75 in x 6 ft. Just about anything of the right size will do.
-hard board, MDF board, etc - I used MDF the first time due to the clean white melamine coating, but the plain hardboard looked better and seemed more durable.
-two knobs attached to screws/bolts
-two big washers
-two socket anchors
-2 very short wood screws (for the lip)
-4 medium wood screws (for the legs)
-4 small nails
-4 plastic checker pieces (optional)
Tools:
-circular saw (could use a hand saw, but it'd be messy)
-power drill
-(Optional) dremel w/ sander bit
NOTE:
This was made to be simple and quick. You don't really need too many measurements; just line things up and saw away. I only measured the tray itself (11 x 20 in). The rest are self-evident as you're going along. Even the lips were circular-sawed freehand. Be careful where you put your hands! (If you want to keep them).
131 comments
1-40 of 131next »
Nov 18, 2011. 5:56 AMgeggodrums says:
Hi there,
thanks for all your great Ideas... here is my Try :) Its really comfty, y Ellbows can rest on the wooden staves on both side and I can screw it in every position, even the underground is not even, so i just screw the both sides differently :)
For the tricky part I used simple Spanner (dont know the word in english) but you all know this :) its cheap and very stable :)
I used for the middle panel pine wood from the alps, nice smell, and for the side some hard wood, walnut... The ornaments are freely designed and they giv good circulation for the machine :) thanks for all your inspirations !
good luck Geggo
Jul 12, 2011. 5:02 PMnlazaravich says:
Thanks for this, I just finished building a very, very rough version. Sort of a prototype. I made mine a little bit too tall for my liking and couldn't get a hold of the adjustable screws this time but next one will be better. Thanks again!
Jun 28, 2011. 3:55 AMjfer says:
I always thought there had to be a better way.I use my laptop in bed a lot, as it's more comfortable for me. However, it's hard to balance the laptop on my chest and type with my hands sideways, so I needed a laptop stand.
http://refurbished-computers.ca/
Apr 24, 2011. 7:14 AMzrahman says:
Hello, I intrigued with project laptop stand and I was have made this thing according to your way show in this project. However, I have problem on this project product. Where are I can get T-nut and knob with screw in Kelantan, Malaysia? Reason I was went some stores hardware, but I not find this thing. If there is, help state name and shop address hardware that nearest with my place.
Mar 27, 2011. 6:48 PMpowdernine says:
I wish I would have realized there were 3 and a half pages of comments before I planned out and built my version. There are some good ideas mentioned. Oh well, I thought I'd share what I made though.
Originally I was using the same design as the original. I thought I could put a rubber washer in between the pieces of wood to keep the legs from slipping but that was a total fail. So I decided to add supporting legs like another commenter did. I wanted to be able to adjust it though so I added 3 notches.
I was able to find the knobs at Ace Hardware. They had a few bins that had a variety of different knobs. I still like using the knobs even though I have the support legs because it keeps the whole thing from shifting.
All in all I think it turned out pretty well but if I did it again I might try the checker idea. So here it is:
Mar 28, 2011. 7:08 AMpowdernine says:
Thanks! The wood is poplar. I recently took a woodworking class and I had this left over. I'm planning on putting a clear polyurethane coat on it when I get a chance, I like the green streaks poplar has and I'm hoping that will preserve it.
I started using it last night and I love it. Thanks for the idea!
Dec 27, 2010. 11:11 PMlupin019 says:
it looks great. where did you buy knob with attached screw/bolts and and socket anchors? thanks
Aug 6, 2010. 5:02 PMnicubila says:
I tried something similar butthen you get addicted to bed. My back started to be so stiff that i have to abandon it alltogether. I just switched now to a more portable one (Standivarius aero), especially as travelling is an almost daily requirement. Now work in bad is no more than 1/2h at once.
May 19, 2010. 11:33 AMprofpat says:
 great instructables laptop  stand!!!
May 11, 2010. 9:10 AMberci says:
Can you make a photo with this checkers? My english is not the best, i can't understand what are this magic checkers with teeth :D
Jan 13, 2010. 10:00 PMGreenish Apple says:
Great Instructable, I need to make one of these but I think I have a better idea for the joints, faucet rosettes. The ones I found at Home Hardware were about 1 1/2" across and 3/8" deep. They are found in the plumbing section, they go under the sink on the hot/cold water lines to the faucet. They are light metal and have bigger, deeper grooves than checkers. I didn't pick them up so I don't know if they correspond to 30, 45, and 90 degree angles.
I was thinking of cutting them half as deep and cut a couple big notches (like a castle top) then use a hole saw to cut a groove for it to sit in the wood. Or dremel it. Then epoxy it in place. One or both would be sitting above the wood line, the other could be flush.
David
Jan 21, 2010. 9:43 PMGreenish Apple says:
Here are the Faucet Rosettes I found at the Home Hardware Building Centre here in Southeastern Ontario, Canada. They are labeled Home Plumber (brand) and have stock number 3231-425. On the back it says "Imported for/importe pour Home Hardware Stores Limited, St. Jacobs, Ontario N0B 2N0" which suggests that they are made in the US. I paid $2.69 CDN for a set of two (even though this set said $2.59), the other Home Hardware charges $2.99. I tried most of the hardware locations here; Canadian Tire, Home Depot, Lowes, Rona, Bardon, even Wal-Mart. Only Home Depot had something close, but they were taller, narrower and had wavy teeth not zig-zag ones. Another set made by Master Plumber did not have very good teeth.
They are 1 11/16 inches wide and 3/8 inch high. They just fit on a '2 inch' piece of stock. The teeth are 1/8 inch high and 1/4 inch wide. The bottom is 1 1/4 inch wide with a 7/8 inch hole. They appear to  be made of steel, very strong but light. They mesh together very well but I might use a thin rubber washer between them to keep them from slipping. They have 12 teeth and 12 valleys so they would work for 0/30/60/90 degree angles.
David
Jan 21, 2010. 9:52 PMGreenish Apple says:
Oh yeah, the hardware for the joint. I was thinking of using a Carriage Bolt because the head is domed and it has a square shoulder that would lock into the wood.* Then I'd use a washer and a threaded knob on the other side to pull the joint together tight.
David
*I had found a torque washer online that looks like the socket/anchor but a square hole, no threads and the barbs. Couldn't find it locally.
Jan 21, 2010. 10:10 PMGreenish Apple says:
Sorry, I meant that the torque washers have barbs, but no threads.
May 2, 2010. 12:17 PMChowmix12 says:
I believe "Ontario" suggests it was built in Canada.. just to put that out there...
Apr 15, 2010. 12:57 PMnotnorm says:
A big tip of the hat to jumpfroggy for inspiring so much creation and imitation!  I don't have access to a lot of tools or a Home Depot that will cut wood for me.  I found a way to create a modge podge of parts from different things that just needs to be bolted together.  The legs (Two foot shelving brackets) are bolted to two shelf supports an and then attached with random hardware to a closet shelf that was intended to hang.  It' not collapsible or adjustable but it's very sturdy.  I intend to get some washers and wing nuts to make the process of assembling and disassembling more convenient.  There were two pieces included with the hanging shelf that work as a great cooling stand for flat surfaces (also pictured).  They just require a bit of bending.  total it cost me around 27.  More than I intended but I'm still happy.
May 9, 2009. 9:15 PMnedfunnell says:
Your last step mentions a "leg-nail" mod by a commentor named Supafly, but I can't find the comment. Has it been deleted somehow? Could somebody fill me in? Thanks.
Feb 22, 2010. 5:01 PMrobomaniac says:
It is superfly289scroll down until you see some images.
Jan 9, 2010. 12:59 PMKill3rash says:
Another simple solution for the slipping legs is this circular fixing system. You just make holes in circle on both legs and you just have to insert a nail or some screw into the holes. But please consider to use a hard wood. Pine won´t work, as it won´t stick in the desired position. I have tested it with pine and it did not work properly. oak might be a much better solution. I used for my desktop stand the solution used by superfly
Jun 10, 2009. 4:13 PMgoldenskyz says:
Ok guys heres my version.. there was a lot of debate about how to hold the position, knurled knobs, checkers, etc. While a method like this is nice because it allows for infinite adjustment, I decided that most likely there would only be need for 2 or 3 positions. I don't know much about ergonomics so I just guessed at 45,30, and 15 degrees. So far its worked great, I use the 45 degree position for typing and the 30 for playing games. I've found the 15 degree position pretty useless and if I build more will probably eliminate it. Everything is counter sunk and pocketed so that it folds flat. The basket is from an old freezer and is perfect because it already had the "lips" on it. The stands are made from aluminum bar that I found at the hardware store. Questions are welcome. Thanks jumpfroggy for the 'ible and inspiration!
Jul 27, 2009. 4:58 PMgoldenskyz says:
Here you go..I did a little sketch up, it's not to scale but it gives you a decent idea about what's going on. For those of you that want more adjustability you can make the channel as long as and with as many stop notches as you like! And YES it is a little wide but keep in mind that the laptop in the picture is just a baby 13 incher! I use the extra space for a mouse and pad, it's awesome for gaming. Good to hear from you jumpfroggy!
Jul 27, 2009. 11:21 PMgoldenskyz says:
You know, I was thinkin'.. You mentioned that you didn't have need for it to fold flat, you could skip the channel altogether and put the stop notches on TOP of the rail. No routing, just drilling, a lot easier and basically the same thing!
Dec 18, 2009. 9:20 AMjasonprahl says:
Fantastic instructions!  I made mine a bit wider so I could put my mouse on there and added some fold-able support legs.  The added support legs means it can't lay as flat, but it's still able to be flat enough to fit under my bed when not in use.  I still need to add a hole or two for ventillation and I want to add a few more notches on the lower legs so I can put it at different angles.  My local hardware store didn't have the knob type screws that were big enough so I used more of a thumb type.  Thanks again!
Dec 18, 2009. 11:31 AMjasonprahl says:
If you look in the third picture there's a nail sticking out so the cord goes around that and plugs in on the other side of the laptop.  It sort of just hangs there when I'm not using it.
Aug 16, 2009. 8:58 PMsurfreak says:
BANK! The checkers are a bomber idea. I was just thinking about making a stand for bed when I ran across your instructable. Should be posting my variation on this stand shortly.
Aug 10, 2009. 7:50 AMdrinkbleach says:
Wow!! Everyone’s versions are awesome. Here is mine. used Peg board for top - has holes already allover board and one piece 10 foot fir - legs 4 x 1.5' , 2 x 2' cross pieces. Top piece is 2' x 1'. Used metal brackets already cut and with holes cost about $1.25 each. Regular nuts, bolts & washers 1/4' for hardware. Thanks for all the inspiration.. now i can really become the lazy sloth that i am and never get outta bed!!
Jul 20, 2009. 10:00 AMstarmoon125 says:
*Ž™†ïÜÀHåw_¡ åù*©©„ So wonderful!What a pity.I have no any tools,I'll make it in the future!
May 25, 2009. 5:55 PMbpruett says:
You might be able to solve over heaing in most notebooks just by using peg board instead of solid press board. That way you would have holes all over the back of the notebook and you would not have to worry about positioning like if you would if you cut a hole. I do like the wire shelf idea though, may try that instead. As far as the friction joints go, two discs of cork from the auto parts store should work very well. You also might be surprised how well a couple of discs of felt will hold.
May 11, 2009. 8:02 AMladyharley05 says:
where does the air flow pass through for heat build up?
1-40 of 131next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:jumpfroggy
