loading
Last year i made a carbon fibre violin ,
I started out  by drawing a violin on paper ,  working out the curve heights , plotting the lot on paper ,
Once i had my plans drawn it was time to start making moulds , the violin plate moulds started as block of plaster , that i routed out and fine carved to produce a "plug" , the 1st mould was taken off that  , then fine finishing the top and bottom plate  mould  took about 1 month , and i  still had a lot of fibreglass moulds to make , rib mould , neck mould ,   finger board mould, they all take time. ,
To have a Shop Bot would be a huge help with the mould making  , change the shape slightly on the CAD drawings ,rerun CAM , and watch the Shop Bot produce its magic on HDPE ( only a dream )., using a Shop Bot to draw perf lines , and trim the carbon fibre , i wish i could afford one .
The first plates i made from carbon fibre were way to stiff , "tap tone's " told me it was better used as a brass bell than a violin , after producing about 10 violin plates i was getting into the ball park of tone , a combination of different materials  , laid down in different thicknesses in different areas produced a violin front and back plate i was happy with .
I used the infusion method of carbon fibre making , were you lay all your layers up dry and vacuum bag it , once the vacuum is over 25hg (-12psi) you open the tap to the resin , and the vacuum pulls the resin into the carbon fibre fabric , the laying up of the rib mould took me 5 hours each side to get the fabric to sit in the right position , very fiddly ( pardon the pun) .
The gluing jig was made from MDF with 10mm cup heads sticking through , designed to allow side ways positioning of the rib and neck parts , and the holding down clamps for the top and bottom , the centre part  of the jig was removed to glue the top on, with the 4 hour set time of the resin ,its important to keep it all firmly heard in position.
The cutting and shaping of the f holes is another reason they call them fiddles , carbon fibre is a bugger to cut , found that if you submerge the carbon fibre in water and use a Flexi Drive bit holder on a Dremmel, it keeps every thing cold , and produces no dust , just ware a rain coat
After a final coat of clear and a polish it was ready to string up and hand over  too some who who could play it , ive had grate feed back and a few offers for this violin and at the moment are remoulding for violin 2 ,working on the  2nd set of plans  now ,drawing them up on a  low budget Cad , AutoCAD would be a big  leap for me and  used with a Shop Bot would speed up design changes 100 fold , and allow me to produce Cello's and Violas .
All up it took me 10 months of Sundays , from the time i decided to start to finished product , i had never made a violin before , and my carbon fibre skills were below basic , it was a huge learning curve but between the info on the net and getting your hands dirty and " givin it a go" , anything is possible
Dont forget to vote for this ,
by Ken Van Laatum
Step 1: Plan what you want to make
After purchasing a good violin making book or 2 , i set out to draw a violin ,not an easy thing to do.
All the compass work comes from a single measurement , the centre measurement of a violin bridge's feet ,that measurement is ether 2x 4x ect and the shape comes to life with the golden spiral rules .
The length and 8 widths were measured and the curve shape plotted , the 8 different width positions have different heights set from the length curve , once all the curves were plotted it was redrawn on a second plan as 2mm contours so a router could rough out the Plug for the mould
EDIT : 3.34AM 10th12/11
I down loaded a Mp3 of the open strings of this violin to make all the rioting people happy ,
please take the time to log in and vote for this instructable,  as it is a competition , and I would like to win  :-)
Step 2: Make your moulds
You have to make exactly what you want , then take a fibre glass mould from it , the original object can be made from any thing , plaster , wood , wax ,
The top and bottom plate mould started off as a block of plaster , while it was set but sill moist i roughed it out with a router and smoothed out the contorts with a chisel , once the plaster had dried it was sanded filled  and sealed and polished to 1200 grit before fibreglass was laid over it to produce the mould .
The rib mould was 2 layers of  16mm ply laminated together , planed down to a wedge shape , then cut to shape with a band saw , once the "Plug" was sealed and polished it was placed between 2 boards and fibre glassed up to produce the mould
The neck i carved out of timber , with mould making you have to look out for your angles , you cant under cut your mould or you wont get the finished product out
Dont forget a bond beaker on you r"plug" , there are many different types but i found PVA mould release easy to use
Step 3: Make your parts
Once you have your moulds made your 1/2 way there , if you look after your moulds you will get several "runs " out of them
Carbon fibre is not as expensive as you might think , and readily available on the net , my violins use less than 2 square meters of carbon fibre cloth
Carbon fibre comes in many different fabrics and weaves , ill leave it the net to explain the "K" and weave patterns and there uses.
Basicly Carbon fibre cloth is like any other cloth (soft) and once its set in resin ,it gets its strength  , its the strength and acoustic abillitys of the resin that is important , fibreglass polyester resin is no good , epoxy must be used , there are several was to make carbon fibre ,
Wet lay up , is when you wet down the fabric with a paint brush and lay them up , place a peal ply over it , an absorbent layer , then plastic vacuum bag it up and suck the air out , the pressure from the vacuum bag forces the excess resin through the peal ply and into the absorbent .
Infusion , is when you lay it all up dry and vacuum bag it , waiting until the vacuum is high before  allowing the resin in through a tap , once the mould has been infused you close the tap and pull a good vacuum on the mould , i like  this way because it gives you lots of time to lay the layers down and your not running around like a mad man if your vacuum bag has a hole in it .
Prepeg is the professional  way , manufacture has wet it down with a resin , most need ovens and autoclaves , it must be stored in a freezer even then the shelf life is short
i put down 3 layers of clear before the carbon fibre so the parts come off the moulds just needing a polish
Step 4: Put the parts together
The jig i came up with has 2 parts , the centre part can be removed once the bottom is glued on , so you can turn it around and and bolt the top and neck down on the same jig
The side ways threads hold the ribs in the correct position so they can be joined and and hold them inplace while the bottom plate is glued on .
Step 5: Admire it
Give it a good polish and your done
Step 6: How to Draw A Violin A
This"How too" is in response to people asking how i drew my violin , its not a strad
I call this a 1234 design , if you use this to make a violin , please call it a "1234" design
its quite simple and basicly  shows how the shape comes around using the golden rules where each radius is 1x  2x 4x
To start off you need a measurement to start , so measure the bridge , you want the centre of the foot stance , on my violin its 32mm
so starting at 1/2 , 1 , 2, 3, 4,  the measurement  you get
16mm ,  32mm ,  64mm , 96mm , 128mm , these are the radius of your circles
To start draw a 32mm radius circle on a centre line about 200mm right of the edge of the page (A3)
Step 7: How to Draw A Violin B
Now draw 3 circles at 64mm radius , these mark the rib wall at the widest point , and the 3rd is needed to get a line for bout position
i will show the new circles in blue and the centres as black dots , they will turn black for the next step
Step 8: How to Draw A Violin C
2 more circles at 128mm  , these mark the out side rib edge where the bout circles touch
Step 9: How to Draw A Violin D
now 2 lines , these mark the position of the lower bouts
Step 10: How to Draw A Violin E
this circle's radius is best fit ???? well it seems the best spot for the centre , it marks the very bottom of the violin
Step 11: How to Draw A Violin F
Now its all looking like a mess ,  so what ive done is to draw the rib outline in black , and reduced the construction lines to yellow , just so its clearer
Step 12: How to Draw A Violin G
Now its time to draw the the upper side of the violin ( still could be a guitar ? double bass ? cello ? viola ? if the 1st measurement is modified )
The only difference with this side is that the starting circle is 1/2 the size on the upper , than the lower
Its best to draw it all out , and measure the distance from the the " Bout arcs " crossing point to center ,
We are looking to over lap the top and bottom halves by 1/2 the bridge foot centre  measurement ( 16mm )
so from the bout arc cross over point  ,  measure out 102.6mm from the dot on the last image , and draw a circle  16mm diameter
Step 13: How to Draw A Violin H
we now have to redraw what we have in a mirror image of the lower 1/2 , i wont just rush and draw it all , ill draw it out , bit by bit
so were up to the 3 circles again , there the same size as the lower 1/2 at 64mm radius , but there centres are 1/2 the distance apart ,making the top smaller than the bottom
Step 14: How to Draw A Violin I
now we draw 2 circles , these mark the out side rib edge where the bout circles touch, there 128mm in radius  , they should cross the lower lines  by 16mm   ( blue dots )
Step 15: How to Draw A Violin J
Now we are about to draw two straight lines , that mark the positions of the upper bouts
Step 16: How to Draw A Violin K
now the the arc that forms the very top curve , the top plate is left as it is ,  the bottom plate has to have a arc to accept the lower part of the neck
Step 17: How to Draw A Violin L
Once again now its all looking like a mess ,  so what ive done is to draw the rib outline in black , and reduced the construction lines to yellow , just so its clearer
Step 18: How to Draw A Violin M
Guitar builders can work it out from here
The violin needs some bouts , unless there a carbon fibre violin maker who thinks a " 4 string small guitar" = a violin , now there size and combination are up to the maker , 1x , 2x  , its up to you
the radius's are 16mm or 32mm
Start on the outer most circles , and match the inner ones to where the lines cross
A word of warning , if you do make a carbon fibre violin ( small 4 string guitar ) without bouts , you might ( you will) infringe apon a USA's company's patent , check weather the major Carbon fibre violin ,  cello ( 4 string guitar maker ) maker , has bothered with a patent in your country  ( they have in mine )
Read there patent ,
Step 19: How to Draw A Violin N
Time to fill in the bouts , 64mm radius circles
Step 20: How to Draw A Violin O
So now the bout lines have been simplified to the rib edge line , and another line 3mm away forms the outside eadge of the violin shape
Step 21: How to Draw A Violin P
The flat side's of the bouts are always a challenge to get right , the best way is to run a line from the opposite  top or bottom centre to miss the rib out line / block by 3mm
the top 1/2 and the bottom 1/2 of this drawing are diffident around the the top bout area , i personally like the top 1/2 , so will modify the drawing to be the same top 1/2 and bottom 1/2
This is the basic out line of the "1234 violin "  , the same as the my plan of the violin , on the second photo , it shows the out line against an ebay purchased "Strad template " , its not that far off but it is not a Strad
If you want your brain to hurt , you can modify the size of the circles , some thing ive been playing with ,is trying to draw a STRAD by modifying the circle size by the ratio of a guitars frets   on a guitars finger board
So if you divide a string length by 17.817...... (magic number) , take that length off the string , you will end up with tone 1 note higher
This "how to" is all my own work , and i challenge anyone to search the web for a web page that shows  " how to draw a violin with a compass" , there are 2 images of finished drawings , very complex , and are the result of reverse measuring an existing  famous violin  , it took me about 3 months to work this way out from those 2 images  , some of the other books ways of drawing violins refer to drawing angles down to the 1/100th of a degree , imposable with a pen and protractor
If you use this "how too " please call the shape a "1234  32:16overlap violin " starting with a larger measurement should result in a larger instrument , viola , cello ,  double base , quad base  the octobase is just plain unplayable
Step 22: Drawing the 3d shape
The violin consists of a 3d curve , back in the 1700's sound did not travel in a sine wave , so they tinkered with the plate shape for over 400 years and got pretty dam close to sine wave , the purest's will shoot me , but since im not making my violins out of timber , there not on my side any way .
The plate shape all starts with a curve from top to bottom ( see 1st pic ) , the sine wave curve and the rib-line meet , the 3mm over hang side starts to turn back up , around the bouts ( pointy bits on the side ) it cuts the corner , so all the curves lowest points are at the rib-line or the inside of whats called the" block" ( a block of wood on timber violins , the bouts or those pointy bits on the side )
There are lots of sine wave plotters available free off the net , you just have to enter length and height
Start with the long sine wave, i used the height of 16mm because its 1/2 of the measurement we set the hole violin out with   ,  at 90 deg to it set out your "width " sine waves ,getting the height of each one from the long sine wave
Step 23: Turning it into 3d
Keep plotting your sine waves , or just scale them to fit perfectly  (pic2)
Then lay a mesh over the top , and set the Zaxis points to match the sine waves (pic1)
have fun , this drawing took me 2 months , over 7000 points all raised up to correct height
Step 24: Get it machined
Once you have your 3d drawing , its off to the machining shop , or you could hand carve it like i did the with my first violin
The image has to be ran through a CAM program , and then its off to a CNC machine to be turned into reality
Step 25: The Quick Way
The first mould i every made was made from plaster , and it took me a lot less time than drawing a full 3D plan in CAD
The sine waves were plotted on paper , and measurements taken in 2mm increments , and a contour plan was drawn
The contour plan  was laid over a block of plaster ( 2nd mould was WAX ) and a hand herald router was used to rough out the contours , then chiselled into shape , and sanded smooth
Then it had to sealed and mould release applied before  a fibre glass positive  mould was then taken from it , then the positive was sanded  polished , sealed and moulded to get the negative mould i used
It wasn't that much faster , the drawing was fast , but the sanding was endless , with the CNC ones , the drawings took for ever and the moulds came back smooth
Step 26: How to make Carbon Fibre 1 ( wet layup )
So now you have your polished  mould , your 1/2 way there
In the image below , the mould has had a coat of PVA based mould release , and coated 3x with clear epoxy resin , dont confuse epoxy resin with fibre glass resin , there different , select the hardest epoxy resin you can find ( MPA) , the harder the more resonate the violin plates will be , im using West System's 105 here with there 108 hardener , its easier to tone them down by playing with the  layers
You have to allow each coat of epoxy to "jell " before applying the next coat , if you let it go hard , some bad stuff forms on the surface , and your layers will peel off
Step 27: How to make Carbon Fibre 2 ( wet layup )
Once the 3rd layer of clear has "Jelled" , you can lay a layer of Carbon Fibre cloth over the mould , and pat it down to the tacky clear coats , it will stick so 4 hands are needed
Slowly pore a tiny amount of resin into the middle , and wait , the resin will flow into the first layer , you do not want to trap air in under the fibre , take this part real slow , pore some more resin and the middle and wait again for it to wet down real slow , do this about 5 times untill you have a puddle in the middle , with a paint brush , slowly pull the resin out of the puddle and up the sides , allowing enough time for the air to escape working out would from the puddle
When the first layer is totally  soaking wet , add the second layer , you should be able to use the existing resin to wet out that layer ( a lot faster) , and keep on building up the layers until your happy , try different cut outs , different materials  , carbon comes in a huge amount of weave patterns and each has its own properties  that affect tone
Step 28: How to make Carbon Fibre 3 ( wet layup )
After the laying up of the carbon fire is complete , a layer of "peel ply " is laid over the top , this membrane allows the resin to pass though but wont bond to the resin , it can be peeled off later
Step 29: How to make Carbon Fibre 4 ( wet layup )
1/2 inch Dacron is used to absorb the excess resin , it works well , it stays flexible where cotton rags will set rock hard
Step 30: How to make Carbon Fibre 5 ( wet layup )
The mould is then placed into a "Vacuum bag" , and a vacuum pulled to over 25Hg/in , this compresses all the layers together , with the excess  resin flowing through the peel ply and into the Dacron , the Dacron also helps to get an even vacuum over the hole surface
In this photo ive used Forticon concrete underlay plastic , but now use a nylon super stretch bag material
When you make your bag up , leave the front edges "Mastic " with the non stick tape left on , its a lot faster to seal , this mastic is easy to use , its also easy to repair leaks when the vacuum is pulled
The vacuum pump is one of those electric pumps refrigeration mechanics use to suck the air out of a air-conditioner before re gassing , with a filter and " resin Catch Can " installed before the pump
Step 31: How to make Carbon Fibre 6 ( wet layup )
A few hours later when the resin has set ,( resin left over in mix container  is hard )  it time to strip the mould , grab the peel ply and rip it off , taking the Dacron with it
Before the resin sets real hard brake the bond around the edges of the mould , but dont remove the carbon fibre from the mould until 24 hours has passed , its easy to damage it when its still soft
Step 32: How to make Carbon Fibre 7 ( wet layup )
24 hours later pop it from the mould , they come off quite easy , the "Blue PVA mould release" is good stuff
Iif your mould is polished the finish is perfect , a lot easier to have a smooth mould than to sand , and fill the carbon fibre parts
<p>AMAZING!!!</p>
<p>Could you make the CAD plans for the violin public? I am interested in making a copy of your 1234 design.</p>
<p>What you have done here is an amazing achievement. I congratulate you.</p><p>I am in the early stages of designing an electric viola. I was going to use wood, but now I am thinking very seriously of using CF after making a model in clay or some other easy modelling material. Mine will be solid-body, and should present less challenges than the acoustic violin. I ought to be able to make the body and neck in one piece. If you have the time to correspond I would very much appreciate it.</p>
<p>Beautiful, and a first try ! How many layers of carbon fiber did you use for the top plate? what is the final thickness before resin and after resin? thanks</p>
<p>i know you did it but it looks impossible</p>
<p>That is the coolest thing I have ever seen. The violin isnt the most exciting instrument the world has ever seen, but you have made this one super cool.</p>
<p>Truly an amazing instructable (sp LOL) be proud of your contribution!</p>
Congratulations! Your perseverance must border on the obsessive. I don't even play violin anymore, but I'd buy one of these.
great job! i play the violin and i totally feel like playing the one you made....its so cool?
Found this carbon fiber violin maker who has managed to keep the scroll work on the end of the neck. Pretty rad. <a href="http://www.kickstarter.com/projects/156894760/violin-carbon-fiber-engineering-and-tooling" rel="nofollow">http://www.kickstarter.com/projects/156894760/violin-carbon-fiber-engineering-and-tooling</a>
lol , kickback fund raising for digitizing an existing violin and making aluminium molds , great idea , i went down the track of buying a CNC machine and making a furnace , so i can sand cast aluminium molds , the machine and polish the surface ( 36hours to get too mirror finish ) , im on my 4th CAD drawn violin plans now <br> <br>CNC ,with CAD and aluminium / diesel furnace set me back , $4000( a lot of work and learning curve ) , lol , less than 1/2 of what hes asking for 1 one set of molds to be made ? <br>
Aussie. Thanks for the great write up. Would you be availabke by email or chat? i'd like to pick your brain on a project i have and it's too lenghty to write here. My email is javier at coachcall dot net
the advantage of owning your own CNC is that the inside of plates can be ground down to perfect thickness , and the out line and F holes cut with out any hands on time
Holy.. If I had a violin like this I'd definitely start playing xD <br>Amazing work!!<br>Should have made the bridge piece out of carbon fibre though. Would have looked better. But maybe there is a reason it's wood?
really nice work, <br>a friend of mine made a copy of &quot;Lucille&quot; the famous guitar, but he played only one time with it in concert and got shocked with electricity, so now it is only decorating his rest room... :(
Who doesn't think carbon fiber is awesome? Anyone?
it is, but it is also really cancerous !
Marvelous! =~~) <br>Congratulations man! You rock!
Will it work without the vacuum bagging process?
What kind of carbon fibre cloth did you use?
2Ktwill , 12kUni , 6kuni , 2kUni , all sorts
A carbon fiber violin by the brand Luis and Clark was featured in WIRED magazine for $5539!
Aussie I am working on a project where the connecting rod of an engine will be subjected to very powerful magnetic fields. Powerful enough that the eddy currents in a metal connecting rod might generate to much heat. Could a connecting be made out of carbon fiber?
Carbon conducts electricity , so will still have eddy currents , probably worse and more uncontrollable than aluminum / steel <br>Maybe a Kevlar blend would be better ?
The question is.... does it sound good? I play violin.
you could use sketchup a google cad program. it is free and has a large following. they have an extensive library of drawings, possibly already have a violin or viola to start from. you did a great job! thanks for your instructable!!!
no i dont think you could draw one in google sketch
I'm going to have to agree with AussieCFviolin. I've been using sketchup for 5 years now, have been able to master something as difficult as the attached photo, but the only thing I can figure the program doing with ease would be drawing the several circles to create the paper violin shape. <br> <br>Wonderful work sir. Thank you for sharing your instructable. :)
Apologies, the photo would not attach. Here is a direct link: <br> http://i954.photobucket.com/albums/ae25/jbrand61608/Banetumblercamo-7_zps2d37545c.png
im using turboCADpro to draw them , drawing up my 4th molds this week <br>i only had a short play with google sketch , with out the type in edit boxes on the bottom most CADs have , it would be hard to position any thing accurately
wow......wow.....
I was the owner of a small, yet successful, carbon fiber parts manufacturing company in the automotive industry, and I must say this violin is EXCELLENT! Very very nice work my friend! Wow.
I want a guitar like this :3 <br>
I haven't done much with CAD, but from what I have... that seems really difficult. Great Job
Impressed with the project and responses, however the spelling skills are atrocious . Bought a book years ago because of an article in mechanical engineering. The book was a specially designed book of info templates etc. by 2 brothers named Doerr.
Actually I've bought many books but I actually bought 2 of the Doerr violin books and donated one to the Carnegie Library of PPittsburgh music Department.
thanks for the complements , and wow you bought a book once ????
Congrats on being a finalist, and good luck!
I would love to hear it played...
I second (or as other have also requested, 5th or 6th) this request. A video of you playing it?
lol i cant play <br>ok ok , ill dig it out of the shed and restring it , tune it up and play it to the best of my ability , 4 open string notes , i can manage that , the bugs are a bit loud now , but it would be better than traffic during the day , im on to it
Don't do that... Get someone who can play WELL to play it. The violin is beautiful but if the sound quality isn't right then there is no since building it.
well did you hear it ?, oh ,you want to judge the player not the instrument
No judgement at all on your part. Obviously your build skills rock. It is beautiful, I would just like to hear the sound quality.
Instead of AutoCAD, you might try BricsCAD, go to Bricsys.com. It costs $395US &amp; has all the functionality of AutoCAD &amp; none of the attitude.
dunno ,Autodesk's AUTO CAD is pretty well an industry standard , they use it at my work now on a self loading CNC robotic cabinet making machine ( different department ) ,i would hate to learn another CAD that isn't used much ,like the one im using now<br><br>have you seen Autodesk's up and coming Photo's to 3D addon ?? in testing now at <br>http://labs.autodesk.com/utilities/photo_scene_editor/getting_started/<br>unbelievable soft ware , take a heap of photos of an object , following there guide lines , up load them , and they come back as a 3d CAD drawing <br>
Wow...yet another piece of awesomeness that I've learned from this incredible Instructable. You've got my vote. <br><br>But please do answer the question (that preventec47 asked earlier): so what IS the low cost CAD program that you are using?
Why would you pay that much? Check out DraftSight http://www.3ds.com/products/draftsight/overview/<br><br>It is free and developed by Dassault Systemmes owner of SolidWorks and Catia. It must be missing a lot of what AutoCAD has because it is on 66MB but it works on Windows Mac and even includes deb and rpm files for Linux.<br><br>The interface is pretty much identical to AutoCAD 2004 so you wouldn't have much relearning to do.
About This Instructable
144,551views
450favorites
License:
Bio: Carpenter and Joiner
More by AussieCFviolin:Speaker box design / Nautilus shell Dunny Plunger Project A carbon fibre violin i made from scratch
Add instructable to:
