3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A carbon fibre violin i made from scratch
  • last photo ←
Last year i made a carbon fibre violin ,
I started out  by drawing a violin on paper ,  working out the curve heights , plotting the lot on paper ,
Once i had my plans drawn it was time to start making moulds , the violin plate moulds started as block of plaster , that i routed out and fine carved to produce a "plug" , the 1st mould was taken off that  , then fine finishing the top and bottom plate  mould  took about 1 month , and i  still had a lot of fibreglass moulds to make , rib mould , neck mould ,   finger board mould, they all take time. ,
To have a Shop Bot would be a huge help with the mould making  , change the shape slightly on the CAD drawings ,rerun CAM , and watch the Shop Bot produce its magic on HDPE ( only a dream )., using a Shop Bot to draw perf lines , and trim the carbon fibre , i wish i could afford one .
The first plates i made from carbon fibre were way to stiff , "tap tone's " told me it was better used as a brass bell than a violin , after producing about 10 violin plates i was getting into the ball park of tone , a combination of different materials  , laid down in different thicknesses in different areas produced a violin front and back plate i was happy with .
I used the infusion method of carbon fibre making , were you lay all your layers up dry and vacuum bag it , once the vacuum is over 25hg (-12psi) you open the tap to the resin , and the vacuum pulls the resin into the carbon fibre fabric , the laying up of the rib mould took me 5 hours each side to get the fabric to sit in the right position , very fiddly ( pardon the pun) .
The gluing jig was made from MDF with 10mm cup heads sticking through , designed to allow side ways positioning of the rib and neck parts , and the holding down clamps for the top and bottom , the centre part  of the jig was removed to glue the top on, with the 4 hour set time of the resin ,its important to keep it all firmly heard in position.
The cutting and shaping of the f holes is another reason they call them fiddles , carbon fibre is a bugger to cut , found that if you submerge the carbon fibre in water and use a Flexi Drive bit holder on a Dremmel, it keeps every thing cold , and produces no dust , just ware a rain coat
After a final coat of clear and a polish it was ready to string up and hand over  too some who who could play it , ive had grate feed back and a few offers for this violin and at the moment are remoulding for violin 2 ,working on the  2nd set of plans  now ,drawing them up on a  low budget Cad , AutoCAD would be a big  leap for me and  used with a Shop Bot would speed up design changes 100 fold , and allow me to produce Cello's and Violas .
All up it took me 10 months of Sundays , from the time i decided to start to finished product , i had never made a violin before , and my carbon fibre skills were below basic , it was a huge learning curve but between the info on the net and getting your hands dirty and " givin it a go" , anything is possible
Dont forget to vote for this ,
by Ken Van Laatum
Step 1Plan what you want to make
After purchasing a good violin making book or 2 , i set out to draw a violin ,not an easy thing to do.
All the compass work comes from a single measurement , the centre measurement of a violin bridge's feet ,that measurement is ether 2x 4x ect and the shape comes to life with the golden spiral rules .
The length and 8 widths were measured and the curve shape plotted , the 8 different width positions have different heights set from the length curve , once all the curves were plotted it was redrawn on a second plan as 2mm contours so a router could rough out the Plug for the mould
EDIT : 3.34AM 10th12/11
I down loaded a Mp3 of the open strings of this violin to make all the rioting people happy ,
please take the time to log in and vote for this instructable,  as it is a competition , and I would like to win  :-)
115 comments
1-40 of 115next »
Dec 8, 2011. 7:57 AMrawbits says:
I haven't read all of the making, but how did you managed to get some reasonable quality sound from it? Acoustic sound is depends on the materials density and a lot of things. Carbon fibre isn't the same in density as wood. Even kinds of woods make a difference.
Dec 9, 2011. 12:03 PMneffk says:
Actually, if you read carefully, you'll find that serious and informed instrument makers basically agree that wood species has little effect on the sound. It's aesthetically important, and there are some limited structural differences. However, in general, which hardwood you choose doesn't have much effect on the sound.
Dec 9, 2011. 12:40 PMrawbits says:
Sorry I'm not in the instrument making industry so I don't know of the rumors and such. I'm a material engineer and if my memory is good, then my prof at the university told this when we discussed violin making of carbon fibre. Yes, that was a topic... But we believed it becouse he works for NASA you know. No one question him... I also have a friend who works for a little company making Stradivaries. And he was my helper on the topic. He also sad that different wood gives different tone. But maybe he don't know anything in practice and maybe I'm allso bad at theory being a random material engineer.
I havn't analysed the sample that have been posted, but it's satisfying to me like that. But the question was HOW! I didn't question if that is possible...
Dec 9, 2011. 2:03 PMneffk says:
There's a strat with a knot right by the sound post... And many other examples.
Sorry, didn't mean to put the beat down on you for not knowing. I read all about making guitars (Engineering the Guitar, for example, by RM French) and because it's the interwebs, I decided to proclaim my vast armchair knowledge in a authorative tone. Oh, and you can confirm these claims on mimr.com, too.
Anyhoo, it's nice to see such a professional-looking project posted here.
Dec 10, 2011. 9:17 PMPearlZenith says:
Its the varnish more than the wood that affects timbre and sound quality. Even the shape isn't all that important, or the shape of the 'f holes' as there are trapezoidal violins and other odd shaped stringed instruments that sound wonderful.
Dec 12, 2011. 3:45 AMrawbits says:
Sorry, for my harsh reaction, but was studiing violin making for a whole month all day for my exam...
Also there is acustic testing (resonance) for the top and bottom parts for minimalise disortion. the top part get the resonance and the soundpost convey it to the bottom part which bouncing it back to amplify the sound and it comes out through the f-holes mostly.
The shape of the f-holes are trasitional, but the size is what counts in the loudness of the instrument. The size of the top and bottom part is matters in the pitch and this is something about wavelenghts. (it's a long story...)
And the inside shape of the surface of the top and bottom parts are critical becouse it ballances back the desortion caused by the f-holes, the soundpost and the bass bar. And this is why it should be resonance tested.
Even orientation of the wood pieces counts. Yes even the top part can't be build from 1 part. It's esential to get the parts from a specific place from the chunk of wood...
It's really complicated to do it right and thats making the difference in price, not the brand or the materials. (The test is really simple, but finetune is like hell and needs good skills in woodwork.) The cheap violines comes from factories aren't finetuned just copied over and over.
Dec 12, 2011. 7:05 AMneffk says:
Sounds like guitars are a lot easier to make than violins!
Dec 12, 2011. 10:16 AMrawbits says:
Now that's talkin', nice! I never thought in too deep in the f-holes physics back then. Can you share the calculations?
On the resonance testing from my last post, here is an indepth description on Chladni patterns that help finetune the violins body - and there arre other instruments as well if you are curious. :)
Apr 15, 2012. 4:03 PMBLUEBLOBS2 says:
Who doesn't think carbon fiber is awesome? Anyone?
Apr 7, 2012. 12:11 PMstickbf says:
Impressed with the project and responses, however the spelling skills are atrocious . Bought a book years ago because of an article in mechanical engineering. The book was a specially designed book of info templates etc. by 2 brothers named Doerr.
Apr 10, 2012. 1:51 PMstickbf says:
Actually I've bought many books but I actually bought 2 of the Doerr violin books and donated one to the Carnegie Library of PPittsburgh music Department.
Mar 2, 2012. 4:27 PMUptonb says:
Congrats on being a finalist, and good luck!
Dec 5, 2011. 12:31 PMmr.incredible says:
I would love to hear it played...
Dec 9, 2011. 6:05 AMimartens says:
I second (or as other have also requested, 5th or 6th) this request. A video of you playing it?
Dec 11, 2011. 7:35 AMmr.incredible says:
Don't do that... Get someone who can play WELL to play it. The violin is beautiful but if the sound quality isn't right then there is no since building it.
Dec 27, 2011. 5:01 PMmr.incredible says:
No judgement at all on your part. Obviously your build skills rock. It is beautiful, I would just like to hear the sound quality.
Dec 13, 2011. 8:06 AMsitearm says:
@AussieCFviolin; Thank you for the updated drawings showing not only the boundaries but the inner thickness contours. I loooove design. And yes, I voted for your Instructable. Cheers! :) Site
Dec 11, 2011. 8:54 AMamateurvisionary says:
this is an incredible piece of work you've created. simply gorgeous. even your initial pencil sketches are beautiful.
i've been a huge fan of carbon fiber for at least 20 years, and i've done a very small bit of work with cf here and their along with standard composites like fiberglass. to be able to work with it and get the tone quality you have, that's just fantastic.
i hope you keep the lovely instruments coming. i'd love to see a bass. :)
keep dreaming, keep creating,
av
Dec 7, 2011. 1:54 AMUgifer says:
That is a phenominal build!
I'd love to know what it weighs and how thick the plates are etc in comparison with a timber instrument. As well, of course, as how it sounds!
Interesting that the one part you didn't make from carbon was the bridge - was that because a carbon bridge gave a poor tone, or just because it looks great with normal bridge!?
Even more interesting might be a carbon bow - the weight of the bow must be significant in some fast pieces and a minimal weigth carbon bow might allow some techniques that are hardly accessable with a normal bow.
Thanks for posting - superb work.
Dec 10, 2011. 9:26 PMPearlZenith says:
Actually, from my experience, there are wood bows just as light, or lighter than many carbon bows. The weight matters, but balance is more important, and even a light bow can be frustrating if not properly balanced.
Dec 10, 2011. 9:14 PMPearlZenith says:
This is so cool. I want to make myself a new viola with this method, when I have the money for the materials.
Dec 9, 2011. 7:45 PMjohn henry says:
Thats Awesome
I kniw a guy who was friends with a guy who had a cantract with a museam for 3mill to make 5 carbonfiber benches. its crazy
and that just to sit on...
Dec 9, 2011. 11:16 AMsethzor says:
All craftsmanship aside, mind you it is a BEAUTIFUL violin and congratulations, I am a poor little guy like most of us are these days and when I used to play for my school we spent TONS of money on a new bass and violin for the orchestra ( I play bass) and there was nothing like the sound I have been searching for a great sounding lower than retail bass and I must say I have heard many sound qualities and of all of them yours is in the top 10 I might even dare to say top 2 or even the best the sound is amazing Congratulations. I am without a doubt ending my search for the perfect wood and making a carbon fiber bass, it sounds just beautiful. To end my drool fest If you want a real resonance buy the pricier round wound strings flat wound just doesn't touch the beauty that is round wound.
Dec 8, 2011. 9:50 AMeklipse says:
That's amazing and beautiful! Do you have a sound clip or a video with sound?
Dec 9, 2011. 12:15 PMeklipse says:
Thank you for posting that; it sounds superb :)
Dec 5, 2011. 1:18 PMsusanrm says:
That's amazing. Like the others, I would love to hear its tonal quality.
Dec 9, 2011. 10:42 AMsusanrm says:
Thank you, and it gives a sense - but what about someone playing a classical piece on it, so we can hear how it compares to a wooden violin?
1-40 of 115next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:AussieCFviolin
Carpenter and Joiner
