3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A countdown clock with LEDs
These are some brief notes about a 'Countdown clock' I built 10 years ago for Y2K, The clock is 4 feet square from the front. It is about 4 inches thick, and runs on an embedded microcontroller. Each Segment is made from around 20x 10mm LEDS.
I can't take a picture with it on, because it is WAAAY too bright !
The panel was carved from a template I made for an ordinary router, with an extended template following cutter. I made the template in hardboard (fibre board US-ian ?) and just carefully aligned it with marks on the panel to cut it out.
Laying out the second Leds was more of a bitch than I expected - do the math carefully to pitch them PERFECTLY.
Step 1A Digit
A Digit
Here's a view of the back of a segment. I used the classic LM317 constant current circuit to drive each bank of LEDs.
The drivers for the displays are done with serial-to-parallel converters which seem to have been replaced with these things:
http://www.allegromicro.com/en/Products/Part_Numbers/6275/index.asp
...these new parts will do all I did then with the 317 as well - a complete LED driver in one chip. Only a single resistor sets the brightness for all the leds !
Each digit is driven by that chained ribbon cable, which carries all the common signals for these chips, Vcc, GND Clock, Latch Enable and output enable. So there are only 6 wires leave the computer for ALL the segments of ALL the characters AND the 60 second LEDS round the edge. Each drive chip though has one unique line( the pink wire) that daisy chains through the whole system. The display looks like a very long shift register - see diagram below
An update for the display takes a very tiny fraction of a second.
24 comments
Dec 3, 2009. 8:41 PMmadrasi says:
Hey "steveastrouk" di you ever make a video or a new diagram for this clock? I want to make one for the 2012 countdown just for a joke around here but I am a very new novice on these things.
If you did or if you can make a diagram and or a video with the up to date way could you please email it to me through this site that would be awsome for me.
This I really would like to make.
Thank you
Sep 10, 2010. 6:19 AMh82lose says:
Steve ,
Do you have an email address? Long lost pal of Sharp Shooter , remember?
Sep 10, 2010. 9:27 AMh82lose says:
Don't you work for Yeasu in Cypres , CA?
Dec 4, 2009. 8:43 PMmadrasi says:
Thanks Steve for replying back to me.
I would like to put one together with the days,hours ,minutes, seconds and tenths 0f a second if that is the next in line, I am very tired right now I can't think straight right now so I hope you can under stand what im wanting to put together. I you have and questions please feel free to just ask anything
you want.
I am in the process of trying to put together the computer in a tool case. I have almost everything I need to do it so im trying it to see if I really can do it or not. This is my first time doing anything like this and if I can do this project it will boost me up so much and help me really help me get into this more and I will fell better about myself to try the clock that you have. I would really like that to be my neat project after this computer.
If you don't mind I may need some help when I get to loading the BIOS so I might be hollaing at ya for a bit if you don't mind. and if you do mind thats ok to.
Thank you for all you help and please send me the files or video when you get it done. I really want to get into LEDs so I think that one will be a fun project.
Thanks again and I hope to here from you again soon.
DD
Dec 5, 2009. 3:06 PMmadrasi says:
Thank you
Aug 7, 2009. 2:20 PMPhil B says:
Just so I understand, your Instructable describes in outline form how you built this LED clock. The Instructable really does not give enough information for readers to build it, unless they already have some specialized background expertise. It is impressive and deserves a nice case for display.
Sep 27, 2009. 5:14 PMT2Pogi says:
I wanted to make one like this b4 y2K. if you finally do a reversed engineering, could you add more digits , like the seconds and tenth of a second count? please do provide the circuit drawings please please . thanks. great project.
Aug 7, 2009. 4:04 PMPhil B says:
Thank you for the reverse engineering offer. It is beyond my knowledge base, unless there is a "for dummies" edition. I probably do not need one badly enough to get it done.
Aug 8, 2009. 7:22 AMPhil B says:
I have read a few Instructables about arduinos, even a web page about them. They are interesting, but so far I do not see anything I want or need to do with them.
Aug 8, 2009. 3:50 AMfrollard says:
Indeed - (I'm starting to sound like I want to marry an arduino) - An arduino would have plenty enough memory, program space, and speed to do a 42 segment + 60 led sign...It would need some sipo registers, or max led drivers... I want to build projects like this, just because...I can never come up with a reason why.
Sep 27, 2009. 5:16 PMT2Pogi says:
Do it please Mr. Frollard. for better or for worst, i'd like to be introduced to an arduino mp. I heard they're easier to work with.
Sep 27, 2009. 9:49 PMfrollard says:
www.arduino.cc easy as that
Aug 8, 2009. 4:26 AMfrollard says:
we are instructables. we SET the trends :D
Aug 7, 2009. 11:44 AMlemonie says:
Wow, on the subject of brightness - how much power does this use? L
Aug 7, 2009. 1:20 PMlemonie says:
Modest I suppose, yes a video would look good. L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:steveastrouk
I'm an Engineer, who has inherited the family business (Thanks Dad (JC Taylor, 1938-2011 - RIP) after working in it for 25 years, designing and building scientific instruments. I do electronic an...
more »
