3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A credit card sized Ethernet Arduino compatable controller board
Step 6Parts LIst
Here is the parts list:
Semiconductors:
Micro - ATMega168 or ATMega328 - DIP (the 328 provides extra code space)
Ethernet - Microchip ENC 28J60 - DIP
74HC08 - Surface Mount
3mm LED X2
5mm LED
1N4004 Diode
78L05 Regulator
78L33 Regulator
16 Mhz Crystal
25 Mhz Crystal
Resistors
50R x 4
270R x 5
2k7 x 2
10K x 3
Caps:
18pF x4 - Surface Mount
100nF x 4 - Surface Mount
10uF x 3 - Surface Mount
Hardware:
28 pin socket  x 2
4 pin dip switch
RJ45 MAGJACK - Has to be a MagJack, as that has the ethernet isolation transformer inside it http://www.sparkfun.com/commerce/product_info.php?products_id=8534
10 pin header
6 pin header
5 pin header
2 pin header
Small Pushbutton switch
Arduino Ethernet PCB
42 comments
1-40 of 42next »
Feb 22, 2012. 12:02 AMkbates666 says:
According to Microchip the operating current of the ENC28J60 is 250mA. You list as using a 78L33 when it can only provide 100mA. Why is that?
Jun 29, 2011. 8:41 AMthiagottjv says:
Hi, i'm from Brazil... i can't order the ENC 28J60 from Micriship and shipping from Farnell or other big dealers are always something like R$40... Someone know any other store that i can buy them?
Jun 29, 2011. 7:39 PMthiagottjv says:
Oh, i found that here:
http://www.coolcomponents.co.uk/catalog/product_info.php?products_id=55
Good price... good shipping...
May 30, 2011. 7:04 PMtech industries says:
Could one perhaps eliminate the 74HC08 and just use a 3v3 regulator instead? I happen to have one, but not the '08...
May 30, 2011. 10:50 PMtech industries says:
Thank you for your reply-
Actually, what I meant to ask was, I saw above in the schematic that there is a separate "power" circuit (one that supplies both 5v and 3.3v) but no mention of the 74HC08 (forgive me if I'm misreading it). Could I construct two separate circuits, as shown above? Or is the "power" circuit actually an explosion of the '08's function? Thanks!
Dec 2, 2010. 5:37 PMxillwillx says:
whats a good site to buy most of these components? Ive been searching and only find a few parts at each site
May 28, 2011. 12:03 AMdarthneo says:
There are a few popular ones, the ones i use the most are http://www.digikey.com/ and http://www.mouser.com/ there are also other sites, i think jameco.com sells parts, and sparkfun carries a limited selection (sparkfun is overpriced imo)
There are also some sites that sell weird electronic stuff such as Electronic Goldmine http://www.goldmine-elec.com/
Mar 1, 2011. 6:50 PMReki3 says:
Do you, by chance, have links for the places where we can get these? I have checked the more known sites and have not found a few things.
Feb 11, 2011. 8:55 AMPuze says:
So could this http://uk.mouser.com/ProductDetail/Microchip-Technology/ENC28J60-I-SS/?qs=sGAEpiMZZMsloqAEgcTS55szDcrVZq9x be used possibly with a change to the circuit board.  Thanks
Nov 5, 2010. 6:06 PMMstrChief says:
Hi,
I am looking to minimize the arduino pins required to drive the Ethernet controller.
What is the purpose of using the interrupt (INT pin on ENC)? would it be possible to omit it?
Thanks.
Oct 24, 2010. 7:40 AMcrazymacleod says:
Hey Just to throw In an idea for power, I've been hitting my local goodwill and other thrift store's and picking up cell phone charger's to use a my power supply. They provide more then enough current and I haven't had any fail yet. I get the eletronic kind not the big bulky thransformers. as I believe they are better regulated. They've been renging from $0.50 to $0.99 Not bad?!
And you can attach your project to it and just plug it in.
Sep 15, 2010. 2:02 PMwcbzero says:
Any chance you have a part number for the mag jack? I picked some up and found they had a different pinout.
Sep 15, 2010. 3:38 PMwcbzero says:
Mine wont work because the pins are strait across in a single row, but thanks!
Sep 1, 2010. 6:44 PMpocketscience says:
Hi, How are you getting away with those small TO-92 regulators? I thought they could only provide around 100-150mA? Max requirement on the ENC is 180mA, and once you start adding external components you'll need more than 150mA for the ATMega as well right? Cheers,
Aug 15, 2010. 7:32 PMmfmjos says:
This may be a super newbie question. But are you sure you meant 2k7 resistor? Should it be 27k or 2.7k perhaps?
Aug 3, 2010. 6:29 AMmattadamsnet says:
I was up at 2 am putting together the parts list to order, Mistake number 1, never take the credit card out past midnight. Any who For the life of me, in my delirium, i couldn't find "Micro - ATMega368 - DIP" Anywhere. Only to wakeup this morning and realize it should be 328 or 168 -- Matt
Aug 3, 2010. 5:54 PMmattadamsnet says:
Step 6: Parts List
Jul 25, 2010. 2:35 AMdiamantmatch says:
(removed by author or community request)
Jul 25, 2010. 5:00 AMdiamantmatch says:
i can not seem to find the beads resistance?? what bead do i need? thank you :D
Jul 25, 2010. 6:50 AMdiamantmatch says:
Jul 26, 2010. 8:21 AMdiamantmatch says:
i am just replicating your circuit and drawing my own but still can not find the type of bead. just as im buisy with the dip switches i see that you have them connected straigt to a header and to the switches witch either are ground or float since i see no pull up resistor? wouldnt it be verry usefull to put a pulup between them ? to prevent unwanted ip's? cheers diamantmatch
Jul 26, 2010. 9:00 AMdiamantmatch says:
the transistors on the top of the pcb arent on the partslist and i don't relly understand what they do? damn i want an edit function here! * hint hint instructables ppl * greets diamantmatch
Jul 11, 2010. 1:53 PMjeremyvnc says:
To alleviate any confusion, I think you mean ATMega328 for the micro. Nice instructable though!
Jul 24, 2010. 6:39 AMdiamantmatch says:
no he means ATMega168 since the code is not any bigger than 16kbytes.
i would really love to build one of these but i can not seem to find anywhere to buy these parts ( the ENC28j60 ethernet controller and the 74HC08 gates.. i would preffer to use the 74HC08 as a dip package but smd would be fine, though a lot of work..).
why is the ferrite bead nessecery?? i never saw the use of beads..
you used 18 pf caps for the crystals hough a lot of people bealive that 22pf would work better..? why do you use 18 pf?
verry nicly done thanks for the insparation
Jul 24, 2010. 6:10 PMdiamantmatch says:
the Ethernet - Microchip ENC 28J60 - DIP on microchip is in a SPDIP package i cant find the DIP type can you send me a link? ( elseway ill just buy the SPDIP type but it looks cleaner :P (i just boght 3 AND gates in a DIP package on ebay :) hope they work and my pcb design works too :P) thanks diamantmatch
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
361
Author:drj113
I have a background in digital electronics, and am very interested in computers. I love things that blink, and am in awe of the physics associated with making blue LEDs.
