3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A fast and flat coding machine
When I saw the cryptex Instructable (http://www.instructables.com/id/How-To-Make-a-Cryptex/) I thought: "I will make something like that with my grandson this summer to generate coded messages". He is smart with his hands and he will love building one. I also realized that if we were to play spies, I should have my own... I did not want to have one that he could compare with his, so I decided to make something quite different. Since I have some experience with sliding rules I decided that my machine would be flat.
Step 1You only need
You only need
- a piece of cardboard, about 2.5 or 3mm thick and 10x20cm large
- glue
- a sharp cutter knife (and a rule!)
- the template (flatcryptex.pdf)
flatcryptex.pdf(842x595) 42 KB
60 comments
1-40 of 60next »
Dec 3, 2011. 5:35 PMacoleman3 says:
im gonna make one from 3mm (1/8in) aluminium and rivet the pieces together, using glue only to affix the labels.
Dec 17, 2011. 10:53 AMacoleman3 says:
oh sorry, i forgot about my project idea and this page until now. this next month ill be able to get the materials, including the pop rivets. heh....i still have teh pdf.
Dec 3, 2011. 5:36 PMacoleman3 says:
of course ill need to make a top/bottom margin space for the rivets, but that'll be easy peasy for me.
Dec 9, 2011. 11:42 AMskidemon455 says:
cool but is it ok to use corregated card for it instead of solid
Sep 24, 2011. 6:53 AMcarsoncool says:
Wow. This is pure genius. I remember this is the 'ible that made me decide to join this community. I've forgotten about it until now. I'm making it as i speak. I'll post a pic when im done!
Sep 24, 2011. 3:49 PMcarsoncool says:
here it is!
http://www.instructables.com/id/My-Flat-Cryptex/
Sep 26, 2011. 2:46 PMcarsoncool says:
Thanks for the feedback! It slides well, and i cant wait to do more!
Jul 11, 2010. 5:41 AMnutsandbolts_64 says:
I've been looking at this for a long time. I feel like I'm gonna make this any time now...
Dec 21, 2010. 7:43 AMbeehard44 says:
but you didnt....
Dec 21, 2010. 8:03 PMnutsandbolts_64 says:
Hey! I forgot about this project a long time ago... Maybe I'll make it sometime this break. I'm gonna make it out of my failed math project (by failed I meant the second version which I didn't use).
Jul 21, 2010. 3:22 AMultrafreak128 says:
Great design! i have actually completed one out of balsa wood.
Aug 9, 2009. 6:27 PMgupper2 says:
My family an I love the design. So far I've made two out of cardboard (one for my father and one for my brother) and I'm working on a third out of balsa wood to aid in the sliding between the pieces Thank you for you great ideas!
Feb 27, 2010. 11:47 AMgupper2 says:
 sorry i took so long to comment back.
I'll make sure I do!
Dec 13, 2009. 7:15 PMCubie2 says:
The Cryptex is completely different but good job!
Sep 6, 2009. 3:33 PMD.L.H. says:
Do we have to use cardboard can we also use wood like a thin sheet of ply wood ? Other than that it is a cool idea,
Jul 16, 2009. 7:50 PMconrad2468 says:
How would you write a program that changes all your letters into other letters that can then be decoded?
Aug 6, 2009. 3:45 PMthepelton says:
One thing about straight letter substitution is that it can be decoded by knowing certain things about the English language. First, the ten most common letters used in the English language are, in sequence, ETAONIRSHDL. If you have watched "Wheel of Fortune" a lot, you see those letters come up all the time. Second, there are only three words that have one letter in them- A, I, O, and O is not used that much unless the writer is writing in a style like that of Shakespeare. You should read "Sherlock Holmes: Mystery of the Dancing Men".
Jul 16, 2009. 1:28 PMthepelton says:
now, I am working on perfecting one of these in a circular mode. The problem I have been having with it however is spacing. Everything has to be evenly spaced, and the letter "I" is the narrowest one. Perhaps I can post you a picture when I have perfected it..
Aug 6, 2009. 5:59 AMzimmemic25 says:
i often use Inkscape for such text-alignments. just make a path, align a text object to it, edit it, and print/export.
Jul 17, 2009. 11:11 AMthepelton says:
One thing I should add is that I am making it with a double alphabet (52 characters). That way you can just line one alphabet up under another almost anywhere along the way. I still have to work on the spacing.
Jul 18, 2009. 12:12 PMthepelton says:
I did it that way so that there was one letter lined up on the code section with a letter on the original even at the ends of the alphabet. I suppose I could make the whole thing a single circular piece, but there are 26 letters in the alphabet, and I'm not sure how to divide a circle into 26 even parts.
Aug 6, 2009. 6:02 AMzimmemic25 says:
you dont know how to divide 360 by 26? BC says its "13.84615384615384615384", so i'd use 13.8 degrees between the letters...
Jul 20, 2009. 10:27 AMthepelton says:
That's a little difficult. I was reworking my idea as a straight decoder the other day.
Jul 22, 2009. 9:25 AMthepelton says:
So did I.
Aug 6, 2009. 3:38 PMthepelton says:
I still plan on working the whole thing out, and making a photo of it that I can post.
Jul 21, 2009. 1:53 AMFred82664 says:
this is a cool ible and one can use any type of creator instead of the alphabet say Binary or Oct numbers and letters hehehehe make it harder to crack the list is endless on what one can code it on. it depends on just how creative the builder can be just forget what you use for a key
Jul 16, 2009. 1:21 PMheathbar64 says:
If I may share a pet peeve, I can't stand the instruction to download and print this. I want to know how to figure out and do it myself. This allows for adaptation, and broadening the mind, rather than just copying.
Jul 18, 2009. 1:22 PMheathbar64 says:
Thanks for your response. Yes this paricular project is pretty easy to figure out, my comment was more general in nature. I've seen it done a lot. I do plan on making one of these soon to use with my daughter.
Jul 18, 2009. 12:08 PMthepelton says:
I found I could get a cheap flash drive locally and copy interesting instructables off the site, and put them on the flash drive so I could read them at my leisure off my home computer with no internet. It is 2 gigs and cost 7 dollars US.
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Papydom
