Step 4The frame support to the wall.
I cut the bottom of the two supports with a 15 degree angle to approximate the lean as it sat against the wall. I screwed 4 rubber feet on the bottom to keep the supports from sliding and put two more at the top to protect the wall.
With the frame clamped on the supports and sitting on the blocks, I drilled 4 1/4 inch holes 1 3/8 from the sides and 1 3/8 from the top and bottom. 1/4 by 3 1/2 inch bolts, 1/4 inch washers and wing nuts holds the frame to the support.
Add Comment
