3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A clear glass whiteboard
Step 6Final thoughts.
This was an easy project and it was nice to work with my son on it. The glass whiteboard is being used and may end up as a winner. All in all though, the IDEA sounded a lot better than the actual thing.
I think that Numb3ers uses the clear whiteboards so that they can film the actor's face rather than the back of his head while he is writing! It also lets there be more variety in the background than a huge white board.
I would love to hear about someone making a Lexan whiteboard so I could hear how well it works.
There are many other ways that I can think of using a clear whiteboard. I would love to hear some of yours.
15 comments
Jul 19, 2011. 9:13 AMmlelievre says:
Very nice project... my dorm room in university had a large mirror next to the desk with storage behind it... I wrote my notes and to do list on the mirror with dry erase markers... I was still able to use it as a mirror and it was provided free of charge by the school :)
Aug 18, 2009. 7:58 PMa.SuperNova.Sun says:
I found this extremely helpful. I am trying to build a clear free-standing board for my dorm room. I'm going to use either plexiglass or lexan. As i am familliar with lexan because we use it in robotics i will probably use that. I was worried about ghosting because i did a bit of research but to find that there are ways to remove it, lexan is the way to go. Thank you.
Mar 10, 2011. 11:58 AMGary Viveiros says:
It's not only a matter of the ink, but of the constant scratching of both the pen and the eraser felts. As mild as they seem, they still abrade the surface like mild 3M scouring pads when used repeatedly. Once the surface is abraded, then the ink soaks verically into the surface, making cleaning an even more challenging task. This is bad enough on whiteboards, but on clear boards you have an even better mechanism for capillary action, wicking the ink deep into the smooth-surfaced scratch. On whiteboards, you can use harsh chemicals and a slightly abrasive pad or compounding solution to expose a new surface. Plastic scratches are jagged, compared to harder surfaces like glass, so there's even more pockets to hold and dry the ink. I think that's why the Canadian company came up with Smartboards, which are mainly computer projection display devices.
Sep 16, 2009. 8:25 PMmlphilli says:
i'm considering using a large polycarbonate sheet as a marker board, but i want to hang it on the wall on its own rather than frame it. i'm wondering if you still think that i should get a thickness of 1/4" or 3/8". if it's hanging on the wall rather than free-standing, would 1/8" work just as well?
Mar 10, 2011. 9:47 AMedwards-research says:
See my writeup here: http://blog.edwards-research.com/2011/01/do-it-yourself-whiteboard/
I used exactly that (but mounted it on plywood). I also bought the plastic from freckleface!
Sep 17, 2009. 1:05 AMsdpaez says:
One nice use of this is if you are filling in data and you have a table on your whiteboard, you could have your table printed on a tarpaulin and attach it on the background... say like the surgery schedule on hospitals... other things like that.
Dec 19, 2008. 3:06 PMGuy.Fawkes says:
Edge-lighting would make any writing (or smudges) on the glass stand out very well; the writing would seem to glow. I suspect that wouldn't work as well with a black marker, though.
Sep 17, 2009. 1:03 AMsdpaez says:
I think it will work only if the marker color is contrast with the background and the marker is on the other side of the glass...
Dec 23, 2008. 6:03 AMGuy.Fawkes says:
I believe it's grease pencil, actually.
Jan 3, 2009. 6:18 PMAniawn says:
Would using acid etched glass, or something to that effect, be cost effective to use? It would increase readability while still being semi-transparent.
Dec 21, 2008. 4:05 PMV1rusZer0 says:
Another show that used a glass marker board was ReGenesis, it was a Canadian show about genetic engineering. Anyway on that show they used a black light at the top of the glass and then wrote with a fluorescent marker that would glow with the black light. I made the writing stand out quite well.
Dec 20, 2008. 1:03 PMgworth says:
If you wanted a permanent white surface behind the glass, you could always paint the wall-facing side of the glass with latex paint or spraypaint. But great idea man.
Dec 18, 2008. 3:00 PMcalimorrison says:
Why not use an old window you find at the re-store and just hang it from the ceiling or screw it into the wall???? Or put it on a tripod? Just a thought...I think I'll try it in my new home office! :)
Dec 20, 2008. 7:50 AMaviationalyours says:
I have a crazy idea, why not write on a window itself if the background doesn't move and is appropriate? Just hang a pen nearby and write whenever you want. Any thoughts about that?
Dec 18, 2008. 12:20 PMEmmettO says:
I have a lexan whiteboard that my family uses as a calendar and a to-do list. I chose lexan so that it would be invisible (mostly) to the decor of the room. The wall is grey that it is bolted to. The same would work with wallpaper but a pattern might make the calendar hard to read. We only use black, green red and blue ghost a bit. We found that we can get it off by scribbling over the ghosted color with the black marker. Oh and to make the calendar lines, I got some thin black tape from the office store and laid out lines for the days.
Dec 18, 2008. 9:03 PMJoCat says:
Some fingernail polish remover does wonders to undo ghosting. I've had unfinished proofs scribbled on my whiteboard for extended periods of time; little bit of acetone/polish remover and paper towels wipe it clean.
Dec 18, 2008. 2:41 PMEmmettO says:
It's a 3x5 sheet, so a good size, it does flex but it's right up against the wall so it doesn't matter too much for us. If it was free standing, it might be a problem.
Dec 17, 2008. 5:02 AMStephM says:
Would it make the writing easier to see if it were lit? Maybe with some LEDs embedded on the inside of the frame pointing towards the glass.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:johnpombrio
