3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A great technique for scanning your inked drawings
Step 4Quick rundown, examples and notes
Ok, here's the rundown for the intermediate Photoshop users.
1. Scan your artwork in Line Art at twice your intended resolution
2. Remove any apparent mistakes
3. In Grayscale Mode, unlock your layer
4. Use Select->Color Range to select the white background, then remove it
5. Go to Image Size and set the resolution to half of what it was before
6. Done
If you often scan a lot of drawings in high resolutions I can recommend that you save them in the bitmap mode for later use and do the following steps when you need to, there's a huge difference to be made in file size in the long run.
The example drawing I made for this Instructable was maybe too simplified, if you do comics or more advanced inks by hand the improvement should be apparent once you try it.
Even though you might be able to get the same results by scanning in grayscale, adjusting the levels and removing any irregularities, this method will save you a lot of time.
I have a feeling you need to have tried scanning inked drawings in grayscale before to actually know how big of a difference this makes but check out the attached examples and compare yourself by switching between them.
Don't forget to note that the background in the grayscale example is in the same layer as the drawing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rauz
