3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A high-power LED torch using a single AA-battery
Step 7What's next?
What\
I hope you have lots of fun making these lights.
Here are a couple of different combinations: 4-LEDs or 1 120mA LED. The single LED is simple enough that I soldered the components directly onto the leads of the LED. Sealed in 3/4" heat-shrink tubing.
You will find much more about LED circuits at my Website: http://www.quantsuff.com Give me a visit and let me know what you are building this week!
6 comments
Apr 10, 2009. 4:47 AMRusdy says:
I wonder how efficient this circuit is (i.e. volts and current input and output)
Apr 11, 2009. 7:51 PMRusdy says:
I was a wee bit pessimistic when I saw the circuit. But after testing it myself in PSPICE, I stand corrected. It is pretty damn efficient for such a simple blocking oscillator circuit (as they're not really efficient). Those components choice, do give efficient conversion. At 1.2 V, PSPICE simulation does give around 40-50% efficient, and it's consistent down to 1V. The transistor does play a big factor here though (as you commented), definitely need high gain in high frequency, your typical hobbyst transistor (such as BC547/557) won't give the same efficiency (and less brightness as well for the LED). I wish I saw your circuit first, before I ventured out to LM2623 from National Semiconductor. It definitely gives 70-80% efficiency down to 0.9V. Unfortunately, it only comes in a surface mount (for a very good reason, with upto 2MHz switching frequency), so it's pretty expensive to work with.
May 16, 2009. 7:36 AMSagar Gondaliya says:
your ideas are amazing. i was just wondering, i dont have a very good monitor so i cant read your schematics on the webite. could you maybe post some computer generated ones so i could read them? thnx very much in advance -a fellow maker
May 16, 2009. 1:41 PMSagar Gondaliya says:
im mainly having problems with the hack-lite one. thnx
May 17, 2009. 6:26 AMSagar Gondaliya says:
yea it is. thnx
Jul 29, 2009. 7:00 PMcarpeteknus says:
Excelent ! lined up for my next weekend project :) Do you know how long will a new alkaline battery last? my rough math says around 20 hours for a 2000mA h(2000mAh/(4x25mA) ), but i'm not sure that's the complete discharge calculation
Jul 29, 2009. 8:54 PMsign-up says:
Remember that the LEDs are run at 3.3v, while the battery is only 1.5v
Using the power calculation:
Input = 2500mAH * 1.5v = 3,750mWH
Output = 4 * 3.3v * 25ma = 330mW
So, to get operation hours: Input / Output = 11.4 hours. Of course there is also a penalty in the conversion (in-)efficiency we have to factor in, about 75% by my observations, which lowers the operation time to about 8-1/2 hr.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
