3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A magnetic field strenght audible indicator
Though not as simple as Proteon's, this gauge gives a change in the pitch depending on the intensity and polarity of magnetic field.
Hall effect chips are simmetrical devices: given a small current flowing through a diagonal of the square chip, the perpendicular component of a magnetic field to the chip die will cause a voltage to appear at the other diagonal, the intensity and polarity of the voltage being proportional to the intensity and polarity of the magnetic field.
I tested the circuit on a protoboard, no solder job, no PCB. The components are easy to find and the thing can be assembled in a very short time.
Step 1The circuit
The circuit
It is pretty simple. The building blocks are a silicon Hall effect sensor (the magnetic field sensor), a differential amplifier (i.e. an amplifier capable to convert a voltage at two points in a voltage with reference to ground), an oscillator controlled by a voltage (VCO) and the sound transducer (a piezo buzzer).
The differential amplifier is necessary because the VCO needs a voltage referenced to ground. It does not actually amplify the signal, simply adapt the voltage reference.
The Hall sensor is courtesy of a floppy disk drive while the operational amplifier comes from one of my spare parts boxes. It could be replaced by almost any op amp suitable for single supply. The VCO is part of a 74HC4046 chip. This one is a PLL chip, a component used to generate frequencies with reference a stable and precise reference, typically a crystal quartz. I just needed the oscillator which is good enough for the purposes.
The VCO output then goes to a piezo buzzer.
The Hall effect sensor I placed on a 2x2 piece of perfboard, this makes it easier to handle.
The chip is symmetric, this means you can connect it with the single requirement that the pins going to the differential amplifier be on a diagonal and the supply on the other one.
There isn't really much more to say. No, wait, should you find the pitch too high and annoying, you can make the capacitor 100nF.
OK, that's really all for now.
Ciao
24 comments
Sep 22, 2010. 11:11 PMdsasorin says:
hi. About the hall sensor: I can't find the pinouts. I understand that one diagonal is for power supply, and the other is for output. And by the way, what is the output ? uA, mA, mV, V ???? I also understand that input is 5 V.
Am i right ? Use of a OA is a must anyway. Thanks.
Jan 20, 2009. 6:52 AMSalar says:
Hey 5Volt, im working on a project to make a bar locator and i was wondering if you can help me. Its basically exaclly as what you have made here but a more powerfull version. please let me know if you can help me. salar3@hotmail.com thanks
Jan 21, 2009. 5:52 PMSalar says:
just to give you a background, I'm a 3rd year mechanical engineering technology student and currently I'm on my coop and would like to work on the bar locator project and hopefully develop it to a step where it can be manufactured. I am currently working around couple of bar locators where they, by creating a magnetic field through 2 coils, produce a noise and when this field is distrusted by any metal the noise will change in freq. since I saw your little project i thought you can help me.
Aug 7, 2008. 4:04 AMrohitdesa says:
hey 5volt....ive got similar looking hall sensors on a salvaged floppy drive. they're 4 pin surface mount and have got the markings "IC" with the 'I' broken into 3 pieces. i cant seem to figure out which pin is which. your schematic shows a square for the hall sensor; could you please attach an image of the hall ic with its pinout? all my hall sensors are connected in series with two resistors (1.2k->hall sensor->hall sensor->hall sensor->2.7k) so if they are in series,how does the floppy motor controller know which hall sensor is sensing? (btw, i am assuming, after looking at your schematic, that the two pins used for this series connection are the output pins. the other two pins are presumably for power; though they are separate for each hall ic) also, what is the function of that zig zag trace on the floppy pcb? (umm, sorry for such a long, technical post; help will be appreciated :-) )
Aug 16, 2008. 7:46 PMrohitdesa says:
Trekking in the land of the good chocolates, huh? Lucky fella! :-) The zigzag trace measures about 6 ohms on a multimeter. Those guys have gone through a big effort to make sure that the zigzag goes all the way round just below the magnet of the rotor. They've taken pains to even add a few 0ohm bridges as well! Regarding the sensors: if I figure out how to use them in the way they are connected on the PCB, i do a post. Though I'm pretty sure the PCB is just single layered. Thanks again. Rohit
Aug 27, 2007. 1:35 PMdanymw says:
oh,there are 2 of these(right)in that 'black box',near the cd-rom motor.i think that when the disk is out,they send a small laser beam through each other.the box has 3 cables.i still cant figure it out,but i think i can't use it
Aug 27, 2007. 1:32 PMdanymw says:
can you tell me what's this? and how to make this motor spin?
Apr 2, 2007. 12:36 AMmark101 says:
This looks really cool to me, you got the sensor from a floppy drive! Brilliant! I wish I had thought of that. I think people want the pin-outs of the various parts and a circuit diagram/schematic.
Jul 9, 2007. 10:27 AMOlegKr says:
Dear sir! Please tell me: 1. Hall sensor from floppy drive - Part number or name? 2. floppy drive - Model, Type, ... ? I hope for your understanding and help. Sincerely, Oleg Kryuchkov. Penza State University. E-mail: oleg@alice.stup.ac.ru
Apr 2, 2007. 6:38 PMmark101 says:
oh I didn't see the PDF, I was expecting a picture here. Thanks for the pinouts on the 4046
Apr 11, 2007. 3:08 AMoligore says:
Can you make it sound like those radioactivity detectors? You could freak people out by going around testing things
Apr 1, 2007. 7:27 PMzachninme says:
Did that sensor come on that breakout board? Or did you make it..?
Apr 1, 2007. 9:54 AMongissim says:
I think that this could use some more documentation. Good schematic and such, but this instructable could give more explanation of parts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:5Volt
