A Mod to Banana Inventors Trigger on the XM8
704
Posted in PlayKnex
Introduction: A Mod to Banana Inventors Trigger on the XM8
About: Look behind you...
This trigger works a lot better and doesnt slip. It took a lot of trial and error to make it work. It should be simple enough to change and it will work a lot better. Credit to banana inventor for the gun and the pic i used in step 1. I know the instructable is rubbish so don't tell me, but it is my first one and they should get better over time.
Enjoy:
(P.S. Don't forget to rate, also I don't care if you give bad comments so don't bother!!)
PLEASE FEEL FREE TO USE IT JUST GIVE ME CREDIT!
Step 1: Removing the Parts...
This is where you remove the parts to make room for the new system. Just follow the notes on the picture. If you need help then just ask. Obviously do the same on the other side.
Step 2: The New Design
This is the new design. It should be easy enough to make and again if you are stuck, then just ask.
1. Make this
2. Add on 2 more orange connectors and the grey connors
3. Insert the trigger rod
4. Attach the trigger (this picture may be confusing, it was hard to take without everything falling over-If you are not sure look at The original instructable)
And its done!
Step 3: Putting It All Together
This is how to connect. Its easy:
Warning: DO NOT pull the trigger unless the gun is cocked or it may explode (no joke, it happened to me!)
And now it is completed! Thanks for looking at my instructable, I hope it works as well for you as it does for me. MOre instructables coming soon.......
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    8 Comments
    thats a really good idea, may i use?, you will get 100% credit for it. 5*
    Yes u can...now I'm gonna write that ppl can use it on the instructable
    BORED HERE SOMEONE COMMENT......!!!!!
    That's a really clever idea, to use a rod as the block for the firing pin. Thanks for this idea. I hope you won't mind if i use it in my later projects. Thnx! :)
    Yh u use it and thanks :P
    so basically u did wat i did on some of my guns and sort of whats on the osnjckma2, and some other unmentioned guns. clever tho, well done
    cheers, i just wanted 2 post sumthin so i just thought ah well ill post this
