A mould for cardboard and plastic solar cookers
video A mould for cardboard and plastic solar cookers
This video shows a way you can make a mold for big cardboard or plastic or sheet metal solar cookers. I have made one solar cooker with this method. It is a compound parabolic reflective dish and it keeps the reflected sunlight in one area for up to 3 hours.
If you want to try a a similar dish, without making a mold, I may put a template (made from my mold) online soon. Comment if you want it.
thank you
Brian White
9 comments
Dec 13, 2007. 11:46 AMnagutron says:
Great idea, by the way. You should definitely make an Instructable with higher-resolution images of your device and the diagram you drew. It would also be cool to see the cooker in action!
Dec 13, 2007. 2:59 PMGorillazMiko says:
cool video, but you should make it an instructable with good pictures, just like what nagurton said
Dec 13, 2007. 3:32 AMWeissensteinburg says:
This looks to me like a compass. A curve drawn with a compass isn't actually a parabola. While it will still cook, a true parabola will cook much faster.
Also, the globe isn't parabolic either (same reason as above)
As seen on this instructable's comments, it's a big deal.
Dec 13, 2007. 11:43 AMnagutron says:
I was pretty confused about this, too, but it made more sense to me once I spent a few minutes sketching it out on paper. The string is attached to the saddle and to the top of the central post, sliding freely through the eyelet at the top of the sliding tube. This means that the constant length of the string will cause the bottom of the sliding tube to describe a perfect parabolar, not a sphere as you suggest. I've attached an image below that explains why this works. See also the Wikipedia entry on Parabolas.
Your link to the other Instructable's comments was useful. Here are some other cool ways to get a parabola, without calculation:
  • Shine a flashlight at an angle to a wall; the shape that it makes is a "conic section" and is thus a perfect parabola.
  • Hang a string from two points. The shape that it hangs in is also a perfect parabola.
  • Spin a container of liquid. The shape that the liquid will pull out into is a perfect parabola.
  • Stretch a membrane over a container with a circular opening, and then lower the pressure inside the container. The suction will pull the membrane inwards into the shape of a parabola.
Dec 13, 2007. 5:21 PMWeissensteinburg says:
Nagutron clarified how your device works for me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
