A New K'nex Grenade!
1,204
Published
Introduction: A New K'nex Grenade!
About: Hey! I am a designer of unique, wonderful, and complex Lego puzzle boxes with real storage compartments, and I have several unique K'nex gun concepts that I'm working on. I also play Kendama A LOT :)
This is my K'nex grenade, It does need some changes though. It doesn't explode far, and it takes a med-long time to rebuild. But it does look cool!
Step 1: Get the Plastic!
Get your stuff. Read the list or look at the pics, or both. You decide!
))>>{CONNECTORS}<<((
x16 Green connectors and x2 Metallic greens.
x4 Orange (Black version) connectors.
x3 Dark grey connectors.
x2 Red connectors (Granite version).
x1 A pile of sharpanel of your choice.
x1 Light grey connector.
x2 Snowflake conenctors (Black version).
x8 Yellow connectors (Grey version).
))>>{RODS}<<((
x18 Green rods.
x5 White rods.
x1 Blue rod.
x1 Yellow rod.
))>>{MISC.}<<((
x1 Tiny blue connector.
x1 Blue ring.
x1 Y connector.
x3 Rubber bands.
Now that we have all the parts, let's have some FUN!
Step 2: The Body
We will make the body now!
Pic #1: Get this stuff.
Pic #2: Make these.
Pic #3: Get these things.
Pic #4: Make this.
Pic #5: Make 7 more.
Good! Good! We made the body!!! Now we will make the pin next!
Step 3: Pins & Needles
Let's make the pin shall we?
Pic #1: Get these.
Pic #2: Make this, and save the Y connector for later.
That was easy... Now we make the handle!
Step 4: Ze Handle
You can use the handle to clip the grenade onto your pants!
We will build it now!
Pic #1: Get all this stuff.
Pic #2: Make this.
Pic #3: Slip the pin in here.
Pic #4: Slip a blue rod through here and add some grey connectors like this.
Pic #5: Another view.
Pic #6: Don't forget to add the green rods onto the red connectors!
We made the handle, now we put it all together! MUHAHAHAHAAA!
Step 5: Putting It All Together
Now we will put it together!
Pic #1: Get this junk- I mean stuff.
Pic #2: Attach this onto that.
Pic #3: Slide the pin into the hole.
Pic #4: Push the green rods on the handle into the green connectors.
Pic #5: Add your shrapnel.
Pic #6: Add the bottom to keep the shrapnel in.
Pic #7: Push on the snowflake connector on the bottom to make room for the Y connector to fit on to the yellow rod.
Pic #8: Attach the Y connector to the yellow rod.
Pic #9: Put rubber bands around the center.
Now that it's built, you may explode the grenade. All you need to do is pull the handle off the grenade and throw. Have fun :)
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    12 Comments
    Very cool I like how it has a coll looking pin
    I believe you can remove 16 green rods from the yellow connectors. Some shrapnel may slip out though, if that happens, just experiment with different shrapnel.
    I LIKE IT! I MADE IT!
    I 'k'new' everyone would like it :D
    You can substitute some of the connectors with others if you want.
    14 Green rods? Or green connectors?
    Well sort of, it explodes easier with the pin off...
