These are great chairs,very well made and still available new, but because they were so popular are available very cheaply secondhand.
The years haven't been kind to my chairs, though, and the webbing started to break to the point where I couldn't use them anymore.
At the same time, bike innertubes have become incredibly cheap. I love my cycling, but I find it abhorrent that my fellow cyclists seem to think that because this is the case, it's acceptable to leave punctured tubes at the side of the road.
This was the germ of an idea....
EDIT: If you're looking to replace the cane on a cane chair, I have just found:
www.instructables.com/id/Innertube-Chair-Seat-Caning/
So all credit to TimAnderson for a nice instructable.
Remove these ads by
Signing UpStep 1The chair
Inner tube straps would have no limit to their stretch. I've re-built many, many chairs. When I tried using rubber strip - not unlike sliced inner tube, it always failed due to uncontrollable stretch... The more weight, the more stretch.
I'd think perhaps if a hessian or fabric belt was used under the inner tube belt, it might provide some limiting to the stretch. Were I to be doing this job again, I would have no hesitation in purchasing rubber sheet with fabric re-enforcing in it and slice that into strips but I'm inclined to think this would be as expensive as using the genuine Pirelli webbing.
I have had to redo it a couple of times. But I never have to buy inner tubes, I always find them when I go cycling. Naughty roadies seem to leave them behind.
Thanks for your comments though; if I couldn't get my materials as a waste product, I'd buy fabric like you said. (:
wider than the inter-tubing that could clamp on the ends of your intertubing.
They are flat on all sides and narrow and stick-like, but none the less would lie
flush against the sides of the chair. Pardon the torturous description, I have no idea what they are called, but I've seen them used for making picture frames.
They would probably stick pretty well, and put less stress on the intertubing, since
it wouldn't put so much adverse torque on the band itself, because the knots cause stresses to pull on the tube in a twisting motion. Rubber tubing would handle stresses for longer periods coming from one direction.
You could also use two small pieces of wood, carpet tacks and (possibly) glue for
the same effect.
I like the idea of using fasteners as opposed to knots, but they have the advantage of being able to get the tension correct.
I'll investigate, though, and get back to you.
