A pocket full of knots.
Traditionally, a knotting board is a large display of the knots a Scout can make. Being large, they became unpopular.
Now, though, spend a few minutes with card, wire and a cigar tin, and you can have a pocket-sized display fit to earn any Cub or Scout that bit extra credit towards a badge.
(You could consider this to be eight Instructables in one, since will also learn how to tie seven different knots. How's that for value?)
Step 1What you need.
What you need.
  • Most small tins will do for this project, but the best tins are those flat, conveniently pocket-sized tins that hold a handful of slim cigars*.
  • Odd lengths of electrical wire. Mains wire is good for this as it gives you a choice of colours, enabling you to tell one part of a knot from another.
  • Wire cutters.
  • A piece of stiff card.
  • Superglue.
  • Fine pen for labelling knots.
  • Optional: paints to disguise the carcinogenic origins of the tin.
*Please remember, folks, all forms of tobacco are very, very bad for you. I in no way condone smoking, but I have a friend who does smoke, and he lets me have his empty tins in exchange for me shutting up about what he is doing to his health.
116 comments
1-40 of 116next »
Oct 9, 2011. 12:23 PMavatar_i says:
That is a very nice way to show- and remember- how to make those knots.
When I was a kid, I remember an Uncel telling me how to remember the bowline like this:
[Rope held out in front of you, verticle]
Make a loop.
Think of the loop as a hole beneath a tree.
A rabbit comes out of the hole,
The rabbit goes around the three,
The rabbit goes back into the hole,
Voila, a bowline!
Jun 8, 2011. 12:26 AMhjjusa says:
On the Bowline, when I was a ScoutMaster in Las Cruces NM, I was fooling around with a piece of rope. I tied a slip knot and stuck the loose end through and slipped the knot and Voila, a Bowline. I showed this to another SM and we went round and round about whether it was a Boline or not. Fast forward 10 years I was SM in another town, I was looking through a knot book and ran across the very same knot. It is called an Eskimo Bowline.
Jul 26, 2011. 9:24 AMbrdavid says:
there are 4 types of "Bowlines" but 2 classes! the bowline, the left handed bowline AKA: The Dutch Marine Bowline, The Cowboy Bowline, the Working end of the knot is on the outside of the look where as the working end of the Bowline is on the inside of the loop, all fall in the first class, let us call normal. The second class is harder to explain. the last loop(bright) ties around the working end and not around the standing end of the rope, thus again you will have two versions of this knot, one with the working end inside of the main loop and the other outside of the main loop. here is a link:
http://en.wikipedia.org/wiki/Eskimo_bowline
Jul 15, 2011. 6:14 AMreddevved says:
One of my Scout leaders called it a "Cat's Eye Knot" or something like that before but that might be because I didn't tie it with a loop I tied it with a piece of rope on a pole.
Jul 15, 2011. 5:51 AMreddevved says:
I tie the "Reef Knot" (in quotes because I'm in the BSA and I know it as a Square Knot) this way. I find it faster and easier to do behind my back (to show off) in competitions.
Apr 22, 2009. 3:40 PMERCCRE123 says:
didn't bear grylls demonstrate this but he cut the center so it will seperate with slack?
Jun 28, 2011. 3:16 PMmaniac_maker says:
bear grylls used it but cut it.. he used the rope tied off to a tree to rappel down a cliff. BUT, he did not want to just lose the rope, so; he tied a sheep shank and cut the center cord, that way when there was tension, it would hold, but when slack, it would come apart, so the cut allowed him to pull most of the rope down with him.
Jul 16, 2010. 3:50 PMCheezpaper says:
Isn't this just a clove hitch formed outside of the anchoring object?
May 12, 2011. 9:13 AMAOGutierrez says:
Its a clove hitch with an overhand knot under the crossing. Much more secure and it only becomes tighter as it is worked.
Jan 1, 2011. 7:42 PMbutterfly grower says:
I like this. It is easyer to cary than that big bord. I added a taunt line and two half hiches
Sep 8, 2008. 7:29 AMberserk says:
I like your idea of a reference box rather than book :-)
Something felt wrong when I saw the sheet bend, so I looked it up on wikipediaWikipedia. I think it's backward, making it much less secure. The loose ends shound both be sticking out on the same side.
Apr 12, 2010. 5:14 AMcaarntedd says:
Greetings beserk (and Kiteman). I know this is an extremely belated reply but I've only just discovered this 'ible due to Kiteman's recent entry into the paracord contest.
The sheet bend is not "much less secure" for having the tails on opposite sides of the knot unless you are using the ropes at close to their maximum load.
If used to join a line to a tarp or something similar it makes no difference as the tarp will rip before the rope breaks. If joining a small rope to a larger one for the purpose of  hauling or securing the larger rope, no difference as the load is not great. If slippage is a problem then use a double bend and/or a stop knot in the tail.
When a knot or bend is placed in a rope the load capacity of the rope is significantly reduced at the point of the knot or bend (by about 20 to 50 percent depending on it's complexity), and even more so if they are incorrectly tied.
The lines need to be aligned for maximum strength and not offset around the area of the knot or bend, because when a load is applied the knot or bend will twist as the ropes pull into line, severely weakening this area. This problem is eliminated by having the tails on the same side.  For uses that have little or no load such as Kiteman's contest entry, tail orientation doesn't matter.
Jun 2, 2009. 9:41 AMThe Anti-Economist says:
Isn't that an "S" shape?
Apr 22, 2009. 10:21 AMzoltzerino says:
Hey Kiteman, I am a member of the UK Scouting movement, but sadly I'm have to leave and move up to the Explorers VERY soon due to my age. My last night at Scouts will be spent skiing on a dry slope a few miles form where I live. I can remember the good old days in the Cubs - we played something called "The Smartie game" a fun, competitive, team game involving the little sugar coated chocolates. One of the things we do at Scouts is "Picking Daisies"; a codename for the alledgedly banned game of "British Bulldogs"... :-D ZZZZ
May 4, 2009. 6:25 PMxerxesx20 says:
Excellent idea! To learn and return is a thing of beauty, seldom seen these days!
Apr 23, 2009. 1:09 PMzoltzerino says:
Well, its not just me moving up it is about half the troop. It was me and a load of mates who joined scouts at the same time, and the numbers were dwindling already ( I can't see http://susg.org lasting much longer, the beavers seem to move up to cubs, but about 90% of the cubs dont move to scouts, so, funding is an issue.)
When me and my mates move up there will only be about 5 consistent members in the scout troop all of whom are newcomers.
I may do the youg leader thing either permanently or as part of mt DofE perhaps.
ZZZZ
Apr 25, 2009. 4:32 AMzoltzerino says:
Workington!
You know Ulverston?
I won't be at the parade, as I am competing in a bike race event...
I will be a young leader, and there are some Cubs moving up soon thankfully.
ZZZZ
Apr 22, 2009. 10:12 AMzoltzerino says:
Not so common... meaning they are found in places? Where would you find them in the UK? I haven't found them anywhere. ZZZZ
Apr 23, 2009. 1:04 PMzoltzerino says:
I've come across the Marks and Sparks ones - they are not all there cracked up to be. ZZZZ
Aug 30, 2008. 7:08 AMLithium Rain says:
That's weird, since the curiously strong altoids claim to hail from England! Hmm, want to buy one from me off ebay? :D
Jan 25, 2010. 9:44 PMbad ass pope says:
Don't forget Fisherman's Friend!
Aug 30, 2008. 8:42 AMLithium Rain says:
That's weird. It's exactly the opposite here-supermarkets are lousy with them, but the little stores? Forget it.
Mar 22, 2009. 8:49 PMzzoe says:
Great inst'able, wish i'd written it. Splendid, cool, useful....&c. But what about the rye? You left out the rye.
Mar 24, 2009. 6:24 PMzzoe says:
I do not 'laugh out loud', but merely smile, wryly.
Aug 1, 2008. 2:52 PMunpicky says:
great instructable and fantastic pictures! i like the fact that you use different colors of wire
1-40 of 116next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
791
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
