Step 3Cutting the plywood and aluminium sheets
Next you need to cut a square hole in the top plywood sheet (the thinner sheet) to make a frame. I was using 35mm piezos (any smaller probably wouldn't work as the rubber would squash too much), and a gap of 5mm around these, making the width of the border of the top frame 45 mm. So the next step is to cut the top sheet into a frame with 45mm width left around each edge. To do this, mark out a line 45mm in from each edge, then drill large holes inside the corners of this square. Then use the padsaw with a wood cutting blade to cut out the central part.
You may want to sand the edges of the plywood sheets at this point to make it look neater.
Add Comment
