Introduction: A Quick and Easy Edge Lit Sign
Picture of A Quick and Easy Edge Lit Sign
This was made from two bits of Perspex that I used my CNC to engrave Open and Closed into then used a string of LED's to edge light them. A short length of 25x15 trunking and hot glue holds it all in place.
A simple three position switch selects Open, Closed and off.
I did say it was simple :-)
DJNPHOTO (author)2013-05-13
how deep did you engrave it and what kind of bit did you use
Djandco (author)DJNPHOTO2013-05-13
Hi there,
I built a CNC a few years back that basically has a Dremel attached to it. The bit I used was a sort of cone shaped coarse grinding bit and at high speed on the Dremel but low speed on the CNC it does not melt the plastic.
I also ran the program twice at two cutting depths hence the slight offset on some of the letters.
I have done one free hand but it takes a lot longer to do and if you sneeze half way through.....
Regards
Darren
About This Instructable
2,007views
13favorites
License:
Bio: I build therefore I am.
More by Djandco:EZ-Robot Wall.EAnother board of many ping-pong ballsA quick and easy edge lit sign
Add instructable to:
