A Radio Stand Becomes a Kitchen Island!
1,001
25
6
Published
Introduction: A Radio Stand Becomes a Kitchen Island!
About: There is nothing I love more then making something new and usable again that someone else would have thrown out or torn down!
I knew what I wanted in our kitchen – a red kitchen island with a butcher block top on wheels but I’m not always the sharpest tool in the shed, sometimes it takes awhile for me to see what is staring me directly in the face. We pulled this radio stand out of the play house (our future duck coop) and I really didn’t know what to do with it. I set it aside and got to work on the many other pieces I already had until I literally dwindled down to it. I even thought about giving it away as I just couldn’t figure out how to make it functional. It was very cool and rather pretty though it did have some veneer cracking and missing on the front of it (as you can see in the before) so I had planned to probably paint it regardless. But if you stand it against a wall it is either useless as a shelf or you have to face the prettiest part of the whole piece to the wall. I just couldn’t figure out how to use it in a functional way so I put it out of my mind. Check out more at our place: www.grandmashousediy.com or check us out on facebook! Thanks for viewing!
Step 1: Not Solid Wood - It Did Not Pain Me to Paint It
Meanwhile, I knew all along I wanted a butcher block island in my kitchen and I have also always wanted a book shelf in my kitchen for all of my recipe books and things so I got to work designing an island. It wasn’t very big and it was basically a small bookshelf on wheels that was a basic rectangle. I didn’t want to build it (I’m not a builder, I’m a recycler) so I was planning on probably finding something at the salvage yard. It took me so long to finally put two and two together *facepalm*. Not only was this radio stand almost exactly the same as I was designing, it’s better because it looks amazing from every angle. The very reason I was having so much trouble figuring out a function for it is what literally makes it perfect as my island because now you can see it from every angle and use it too. Funny how things work out. Deciding on bright neon red was immediate for me, it just had to be red so I bought three cans of the neon red in the most affordable spray paint my local fleet store offered. Check out more at our place: www.grandmashousediy.com or check us out on facebook! Thanks for viewing!
Step 2: Love the Cook Book Storage!
When I painted it I taped up the “fabric” to keep it its original gold color. I put two coats of primer on it, three coats of paint and then two coats of poly acrylic, which I also put on the fabric (front and back) to help protect it. My biggest worry about it is that it was never very sturdy. I had a butcher block island once that consisted of two cabinets screwed together that we put feet on and once when I tried to move it myself one of the feet caved right over – I didn’t want that to happen again. So, I cut two 2x4s to set it on and screwed up through them into each leg as carefully as I could. This was a bit tense as I had to be perfectly straight or the screw would have burst out the side of one of the legs. Then I added big castors so it has no reason to lean when it is pushed, it will just roll. On top of that we added slats of oak we had left over from our counter tops that we covered the bottom with to add even more support. It is surprisingly sturdy now and rolls so easily, when we want the kitchen open we just slide it out of the way. We’re still looking for stools and I can see myself, every winter from now on, sitting at my island in front of the fire after work, perhaps sipping tea and reading from one of my cook books. Check out more at our place: www.grandmashousediy.com or check us out on facebook! Thanks for viewing!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    6 Comments
    The island looks great! I love the way it looks with the fabric inlay. Thank you for sharing how you made this! I hope we see more from you in the future.
    Thank you! Some projects tend to be a little bit on a "wing and prayer" so I was really excited that this one turned out nice!
    your finished product is beautiful.
    the legs look a bit spindly for a butcher block( of course I tend to over-engineer things I build). have you had any stability issues?
    No stability issues yet, I was REALLY worried about that initially too. At first we just had the two 2x4s across the bottom, one running from one leg to the other and they started shifting and twisting immediately, covering them with the 1x3s and creating that bottom "shelf" stabilized everything and seemed to take care of the problem! Thank you for commenting!!
    What a brilliant recycle/repurpose project. Totally inspiring Thank for sharing
