3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A really magic Harry Potter wand for Lumos and Reveal Your Secrets charms
Further to my instructable for the '''Awesome Harry Potter Wand''', here is a more technical version. Still as beautiful to look at (more so if you have practiced on the simpler version) and yet this one actually performs magic (albeit science driven magic). A simple UV LED is used in line with a battery and a home made switch to make a wand that is able to illuminate otherwise invisible UV marker pen writing, and is bright enough to be a torch for the Lumos and Lumos Maxima charms.
Actually, it's very easy to make. If you have wanted to do something vaguely electronic, but the whole electronic thing frightens you, this is a good place to start. You will be building about the simplest circuit there is (a light, battery and switch), but the effect is incredible. This project provides a nice combination of craft and technical challenges with an equally interesting result.
If you thought the other wand was amazing wait till you have seen this, it'll blow you away.
For more great making and doing projects, free printables and templates of the highest quality please see my site dadcando.
And if you make one of these post up a picture of it, or better still email me and I'll put a picture of your wand up on dadcando.
Please Note: You should never point a bright light into someone's eyes. Apart from the fact that it is not very nice to be dazzled, bright LEDs and Bright UV LEDs can in certain circumstances cause damage to the retina (the back of the eye that does the seeing!) and the cornea (the bit the light goes through). When scavenging bits from another device, never increase the battery voltage or add other components designed to up-rate the output of LEDs or lights, unless you really know what you are doing, because you can easily break them, give your self a shock or create a fire hazard.
As Zootboy has pointed out, only use the batteries suggested in the instructable because they have the correct internal resistance. Using batteries with a lower internal resistance could cause the batteries to heat up or the LED to get hot and burn out.
However, this is not a problem at all if you use the batteries suggested.
Happy Making
Step 1Get a cheap UV marker and key ring LED set
you can get these off the web, or from Amazon. I have searched for them and there are some links on the Magical Wands page of dadcando for the cheapest I could find, but most big office stationers or art shops should stock them.
201 comments
1-40 of 201next »
Apr 13, 2012. 11:49 PMSusanR12 says:
A little late to the party but I'm not too crafty so I bought a cheap plastic wand that came with a red LED and switched out the red for a UV. I also changed the button to a mercury tilt switch so it turns on when pointed down. I then replaced the black ink cartridge on my ink jet printer with UV ink made for fountain pens. I photocopied a map in black and white and it works great. Thanks for the idea.
Mar 23, 2012. 11:53 AMCatastropheJones says:
Does the paperclip switch burn out?
How long does your LED last?
How do you know the specs on the LED light? I'm looking to purchase the components cheaply, but I want to match resistance, and not burn out the bulb. I can get the batteries and LEDs for significantly cheaper if I'm not buying a whole keyring at $.99 apiece. (I'm making several of these, and don't want to make the cost X10 because I'm spending a dollar per LED when I could spend pennies.)
Do you know what the viewing angle on the keyring light is? Do you know if the wand would get too hot if I put resistors in the circuit?
Feb 15, 2012. 8:51 AMmanish15 says:
And I thought this was magic. Great work by the way.
Dec 26, 2009. 8:55 PMmakendo says:
 Fantastic project - many thanks for the instructable!
Jun 17, 2011. 6:00 PMBrandon919 says:
I love it !!!!!!
Mar 23, 2011. 9:25 AMxxev75 says:
this is awesome gj gj
Feb 24, 2011. 9:38 AMharry potter rules says:
where can i buy a uv led key-ring light
Feb 24, 2011. 9:29 AMharry potter rules says:
i already have a harry potter wand which doesn't light up
could i cut it near the end and put the light in and then glue/or tape(lots)it back together
i really want to make it for world book day
Feb 24, 2011. 7:06 AMharry potter rules says:
this is amazing
please can u subscribe to me then show me easier ways on how to make a
light up harry potter wand on my orange board :)
Dec 17, 2010. 6:33 PMcraziemutant says:
From the tip to the battery, there's a lot of empty space after rolling. Is there a remedy to this problem? I don't think hot glue will pass the battery to fill that area.
Dec 16, 2010. 1:58 PMlmperkins says:
I made a couple of these wands (excellent Instructable BTW) with a slight twist. I used the Joule thief circuit (described in another instructable, http://www.instructables.com/id/Make-a-Joule-Thief/) so I could use an inexpensive AAA battery. The larger battery with this circuit should give a very long lifetime for the wand. They came out quite nicely IMHO.
Oct 29, 2010. 7:57 AMAF-Geek says:
Small, but wide, rubber/elastic bands work well to hold wires to batteries (or regular size, looped around several times). They keep pressure on the connection, so you don't have to worry about the tape pulling loose.
Oct 28, 2010. 2:53 PMwirecutter says:
Brilliant a Wizard Instructable !
If you fit a changeover switch with a centre off you can have a white LED at the tip and two UV LEDs at the sides of the tip and if the leds are covered if a UV filter its effect really spooky as the LED's are invisible under the filter
Jul 15, 2009. 2:07 PMtwocvbloke says:
I wonder if you can get UV ink for inkjet printers? :D Could make some interesting thing for revealing with a UV light... ;)
Oct 28, 2010. 1:43 PMwirecutter says:
Hi
If you find it don't put it in a Epson type The Da... stuff kills the ink jet head
A better way is to get a couple of UV pens and dissolve the ink out with I.S.P.
and then use that in a washed out cartage.
Aug 4, 2009. 12:07 AMBluedove2897 says:
Yea that would be awesome
Jul 19, 2009. 6:54 AMmaruawe says:
You can get glow powder from glowinc.com Mix this with black ink ( quarter teaspoon with 5 ml of ink , Heat for 30 seconds in microwave stir throughly
refill black ink cartridge and print away... Be sure to 400 powder ,the granules will explode in the microwave(happened to me ) Don't know about uv ink but ask about it at the site they have everything else
Jul 19, 2009. 11:04 AMtwocvbloke says:
I was thinking of transparent ink, like what you get in security pens, you print out seemingly blank documents, but under UV light, all is revealed... :D
Jul 19, 2009. 12:14 PMtwocvbloke says:
Oh yeah, I forgot about that.... :\
Jul 20, 2009. 7:46 AMRedgerr says:
common mistake to read the top posts before the bottom ones ;)
Jul 20, 2009. 3:08 PMtwocvbloke says:
My memory's useless, I forget things I've read, so I had read it, I just forgot I read it... :P
Jul 20, 2009. 6:48 AMmaruawe says:
thanks for sharing this ,I have been looking but the best I could was with glow powder.. .I use the glow powder on my business cards and get a lot of comments ...... One person left it on his desk and the cleaning woman had a cow when she went in to clean and saw the glowing cad on the desk( wish I could have got that one on film........)
Jun 24, 2009. 11:40 AMthepelton says:
I solemnly swear that I am up to no good.
Sep 13, 2010. 6:50 PMnebih says:
mischief managed!
Jul 20, 2009. 7:48 AMRedgerr says:
well thats good to know :o
Aug 6, 2009. 5:51 AMgamer444 says:
does somebody know how to make a wand box, I can't find instructions anywhere!!!! (sorry if there are spelling mistakes but I am french so...)
Jun 30, 2010. 8:37 AMgmgfarrand says:
Just shooting from the hip here... If you have a box, you could probably use that floral foam stuff and easily make an indentation for your wands in that, then glue either felt or velvet over it for that finished look.
Aug 7, 2010. 1:23 AM(YOUR N says:
this to 2 complecated y cant u use real pics insted of drawings :C good idea :D
Jun 30, 2010. 10:06 AMgmgfarrand says:
Or... What about either spraying it with clearcoat or brush on varnish, just in case humidity could make the glue, gummy...
Jun 24, 2010. 9:33 PMSonicX 22 says:
"You should never point a bright light into someone's eyes. Apart from the fact that it is not very nice to be dazzled." But that could be our first spell, lol
Sep 15, 2009. 5:06 PMwhscameragal says:
dont buy them from amazon they are available at the dollar store!
Aug 19, 2009. 7:57 AMaabarrera says:
can you send me one of yor wands becouse i cant make one i'm having trouble plaese send me one reply back
Aug 13, 2009. 3:13 PMyahya kurdi says:
nice
1-40 of 201next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
332
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
