3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A really magic Harry Potter wand for Lumos and Reveal Your Secrets charms
Step 16Fill the end of the wand
fill the end of the wand
The big end of the wand will be at least the same diameter as the 4LR44 battery, so it will take some filling. Remember glue gun glue is very hot so filling it up all in one go would be dangerous, use up loads of glue and take ages to set.
I suggest that you roll a small bit of tissue into a small ball and pack the wand a little first. then fill the end in tow or three stages, making sure it has cooled a bit in between each filling. This should only take you about 10 minutes.
For the last bit make sure that the end bulges slightly so that you get a nice rounded finish.
If you go over the metal of the switch it might heat up the previous glue you did there and the switch might relax its position and touch the other contact. This is not a problem, just be aware that you might have to support the switch while the glue sets again. You could put a scrap of card between the switch contacts to stop them touching while the glue is setting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
332
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
