3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A simple electric motor, and a simple brushless electric motor
Here's two simple electric motors that are easy to build. They are slight variations on the common spinning coil design.  The first has the magnets spinning and uses the rotor as a switch to control the coil, the other has a reed switch which is activated by a small magnet spinning on a cardboard disc.
Materials:
  •  2 x neodymium disc magnets (3/4")
  •  Thick cardboard
  •  28SWG Magnet wire
  •  A 500ml plastic drinks bottle
  •  Insulated wire (stranded)
  •  2mm copper wire
  •  Hot melt glue
For the reed switch version, the above plus a reed switch and a small magnet to activate the reed switch.
Step 1Straighten the wire
Straighten the wire
Cut a piece of the copper wire about 150mm long, if it isn't straight, you can straighten the wire by twisting it an electric drill. Hold the other end with pliers and twist it in the drill, it should straighten it out.
13 comments
Jan 13, 2011. 5:27 PMfafashizzle says:
Ok thanks but also i wondering if i could use rare earth magnets and how exactly does a reed relay work?? Once again... thanks for the help
Mar 19, 2011. 2:55 PMilpug says:
Rare earth magnets are the same thing as neodymium magnets.
Jan 12, 2011. 8:54 AMfafashizzle says:
Hi i was wondering for the reed switch motor if i could use normal magnets instead of neodymium magnets... your help would be appreciated
Jan 12, 2011. 8:59 AMfafashizzle says:
also could i use a reed relay instead of a reed switch?
Oct 7, 2010. 6:38 PMrimar2000 says:
Interesting. What role does the optional diode?
Oct 8, 2010. 4:45 AMrimar2000 says:
Thanks, reukpower.
Oct 7, 2010. 6:51 PMNachoMahma says:
. That diode is there to short out the spike that is generated when the magnetic field collapses in the coil when the switch is opened.
Oct 7, 2010. 7:22 PMrimar2000 says:
Thanks, Nacho. I envy those who know electronics.
Oct 6, 2010. 2:07 PMKiteman says:
The brushless version is quite nice. Two questions, though:
Which one has the greatest torque?
Which one has the longest battery life?
Oct 5, 2010. 5:23 PMPhil B says:
I like the version where the magnet on the spinning wheel activates the reed switch to replace the pulsing normally provided by the brushes. Otherwise, it is similar to what is sometimes called a Beekman's Motor or a Ten Minute Motor. Motors like this are fun to use for children's demonstrations. Thank you for your Instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
312
Author:scraptopower(Scrap to power)
Always a brew in hand, I like to make stuff.
