A simple Sterling Silver Band Ring
 by creatinglinus
Featured
The first piece of solder constructed jewellery I made was a simple sterling silver band ring in college. It is also the first project I give to my beginner students. It touches on most of the basics of solder constructed jewellery making: shaping, filing, sawing, fitting joints, soldering and finishing. Making a band ring will also introduce beginner students to basic tools and their use. Although there are few steps, go slow and be patient with them; eventually you will get it. My advice to students is always do your best and don't lower your standards, but be kind to yourself; you are learning and to expect perfection is unrealistic. If you do something enough times, with care and the intention of improving, you will eventually get very good at it; finish one piece then move on to the next that is how you get better.
Step 1: Picking the Stock
A band ring can be made with sheet or wire. The benefit of using wire is it gives instant shape, for example: half round wire or square wire. The benefit of using sheet is it is much easer to work with than wire. If this is your first band ring, I would recommend using 18 gauge (1 mm) or 16 gauge (1.3 mm) sheet. I have noticed over the years that anything over 10 mm wide, will frustrate most beginners. For the purpose of this Tutorial, I am using 18 gauge sterling silver sheet which is 7 mm wide.
sharonwisely says: Jun 13, 2013. 11:14 AM
This ring is stunning! Thanks for the easy-to-follow directions. I would love to see you do a similar Instructable with a copper band that has sterling silver on the inside and riveted over the ends. Hope that makes sense. I like to work with copper; but, of course, it turns your finger green. I would like to know how to coat the inside with sterling silver, either by soldering it on (?) or, like I said earlier, placing it inside the copper and then riveting it over the ends. Not sure if I'm using the correct terminology. Thanks so much for sharing your knowledge!
jadedseas says: May 7, 2013. 9:04 PM
Doh! I was looking for the calculations you would use to measure out the ring... Just need a refresher. Something about adding pie to your length to account for the thickness???
picturesofsilver says: Mar 22, 2013. 8:59 PM
thank you, excellent instructable. I was looking for info on finishing the inside of a ring I made from sterling silver clay.
Janice
gothycdesigns says: Nov 27, 2012. 9:31 PM
Nice work. Thanks for sharing. I'll have to download the PDF.
Kinsei01 says: Oct 30, 2012. 11:41 AM
Cool. Seems like a fun project.
Makes me wanna get some silver and go try this out in the shop.
Although out of personal taste, I don't think I'd add the hammering at the end. I kind of like the more simple solid silver ring.
Mrballeng says: Oct 27, 2012. 2:03 AM
Top quality instruction here. Thank you very much for posting. What would you say is closest in comparison to silver when working with metal? That is between copper, nickel, steel, zinc, lead, brass, bronze, pewter, and aluminum. Thanks. Brent
bikerbob2005 in reply to MrballengOct 29, 2012. 2:31 AM
copper will harden when worked so it can start to crack that makes it tough to get into final form
nickel will need a tig welder to close up it looks best and stays looking great
steel will rust will lose luster fast acids in skin will eat it away at joints
zinc,lead are toxic home shops can not work safely
brass is fun good to start with also to make a test part to see if idea works
bronze is hard and chips easy
pewter i have only worked with the old type it is also toxic the new mix is safe like bronze it is hard and chips/cracks
aluminum is tricky needs special type of solder can be worked easy with file and hammer
silver is the best, for the price practice on brass
Mrballeng in reply to bikerbob2005Oct 29, 2012. 12:54 PM
Thanks for the advice. Brass it is.
creatinglinus (author) in reply to MrballengOct 27, 2012. 9:18 AM
Hello Brent,
Well, I've never worked with nickel, steel, zinc or lead, but I would say brass is closest. But 14 karat Gold is a better match.
Thank you for your kind words.
Nicole.
John Sphar says: Oct 29, 2012. 7:24 AM
Where does one purchase sterling silver sheets stock?
creatinglinus (author) in reply to John SpharOct 29, 2012. 11:38 AM
Hello John,
A good source is http://www.riogrande.com/
one of my favoriate online stores for all things jewellery. But depending where you live, there might be a local jewellery supply store.
nicole.
desertsniper says: Oct 29, 2012. 7:45 AM
very cool. I have been researching ring making for a while, i really want to make an engagement ring for my girlfriend. I think it would be more meaningful then buying one. but there is still so much to learn and working with those kind of expensive materials i want to make sure i get it right!
Skymeat says: Oct 28, 2012. 7:48 PM
Great Instructable! I have most of the important tools already, just materials. As far as sizing charts go - Is there something printable available? Like a sizing chart with MM or .001 marks that I can verify with calipers?
MiltReynolds says: Oct 28, 2012. 3:35 PM
Excellent instructable! Qualifies, in my mind, as THE model for posting how-to articles. Photographs, lots of them, excellent lighting and composition. Your text strikes a good balance between friendly and inviting, and clear and exact. Keep 'em coming!
Bill WW says: Oct 28, 2012. 1:30 PM
Marked this as a favorite, thanks much.
Agree that brass and copper are good workable metals also.
Can you recommend a good source for jewellery metals?
Bill
creatinglinus (author) in reply to Bill WWOct 28, 2012. 3:20 PM
Hello Bill,
nicole.
f5mando says: Oct 28, 2012. 2:57 PM
Excellent! Takes me back to my mounting jewel(l)er days in the 'quarter in Brum..
jsparticus says: Oct 28, 2012. 11:36 AM
What is the total cost to get tools and material to start building rings as a hobby?
dantistus says: Oct 28, 2012. 9:41 AM
I never suspected it took so much effort to create a simple ring! Thank you for opening my eyes! Great instructible!!!
rimar2000 says: Oct 28, 2012. 6:30 AM
Very good result! Thanks for the info.
zomfibame says: Oct 27, 2012. 4:09 PM
great instructable, that ring turned out nice.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
