3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A simple and cheap fireman car siren.
The circuit I describe here a simple and cheap sirens of fire engines. The circuit is based on only 2 blocks: one oscillator (slow) and another oscillator (which is faster). Lock the pictures.
This circuit use only 14 components, all of easy acquisition and low price (here in Brazil at least) and can be mounted on a plate trial (which is what I did).
I will tell the story of this circuit. I made a whistle and acute with the 555 ci (which became the second block) and the following thought: if I on the other controlling the second IC 555, have a break in the whistle, thus swinging a whistle. But when you mount the circuit, realized that he played a voltage on pin 5 of IC 2 and change the swing of it! Thus the siren this project!
Step 1Building and modifying
building and modifying
The mounting plate in an experimental and easy to do through the scheme. Check all connections for which no errors. If you want a high-power siren, I suggest the following change in Figure 2. It was just that! Build your siren, modify it and improve it and publish your changes! until the next! Bye!
5 comments
Jul 30, 2009. 2:44 PMadmin says:
This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do. 1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable. 2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made! Thanks for your submission and let me know if you have any questions along the way.
Oct 31, 2009. 3:38 PMerikals says:
is that linux you are using or a linux theme for windows?
Aug 20, 2009. 3:18 PMJR737 says:
A video would be nice too. But I will build this!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Nemweb
