I knew my small old horizontal milling machine needed cutters, an arbor and arbor support, a drawbar, guards and a vise when I got it. It turned out it needed a lot more than that.
I have a nice old Wilton 3 1/2" drill press vise, it has a fast action screw and the jaws open to 3 3/4" but are 1 3/4" high so it's kind of too tall for the small stuff I usually have to mill. I tried using a cheap imported drill press vise I got from a yard sale and it was difficult to rely on for a single part and impossible for two, but its very obvious shortcomings made me read about different types of vises.
At the time I looked there seemed to be fewer affordable options. First I checked out Palmgren's low profile vises because they had been recommended for my machine, but decided a screwless vise might work alright, too, and later found some plans for making them. Then I read about pull-type vises on Kurt's website, which work in a similar way. They were way out of my budget but they seemed like something I could make using a nice piece of left over cast iron I had scavenged for making a milling slide for my lathe.
The finished vise is a good size for holding little things - for comparison it's about the same size as the ones for a Taig, and about half the size of the smaller Kurt. I think it works really well.
Step 1: Design
The pieces I had, combined with a catalog diagram and a left-hand tap determined the basic design. If I had a taller piece of square cast iron I would have made it with slots in the sides instead of lugs, and if it was a little longer I would have put the thrust bearing under the jaw inside the vise.
The 3/8"-20 thread is fairly strong and left enough room so I could have a 1/4" hex drive on the end and use a ratchet for tightening it. The screw is centered in the base of the vise and pulls against the end with the fixed jaw, and the moving nut fits in a channel and is angled at the front where it presses against a similarly angled flat on a dowel pin. Clamping pressure draws the jaws together, and pulls the moving jaw and the nut together against the vise body.
What I found from a quick, non-exhaustive search both features seem to have been patented independently in 1951 in the United States by L. L. Walker and L. Pupura but I've seen it advertised that their combination is manufactured exclusively by Kurt.
beowolf says: Dec 12, 2012. 9:31 AM
Although it's a great little project, it's not really comprehensive as far as dimensional drawing goes. Can anyone help me with a more concise drawing(s)?
pfred2 says: Dec 3, 2011. 6:41 PM
If you want your work to stay true in a vise with a loose movable jaw (like all those junk drill press vises) try the round stock against the movable jaw trick. What happens while you tighten a vise is the movable jaw rises up, and it takes your work with it. Putting a round between the movable jaw and your work mitigates that effect somewhat.
Lousy text art:
Round stock --> OL <-- Movable Jaw
Put a dial indicator on your work while you tighten it in a vise to see the effect. I've gotten vises more accurate using the round trick on them.
While no replacement for a decent machinists vise, it helps sometimes.
steveo625c6 says: Apr 1, 2011. 9:43 PM
I might have to add the one I am doing in Machine shop. Its similar but requires being ground to size before it will all fit together.
We are also doing an arbor press in the next 5 weeks, maybe I'll get some build pictures up of that too.
Great project!
BoiseTyler says: Mar 8, 2009. 3:14 AM
Hey, would you mind if I added your project to my site - <a rel="nofollow" href="http://www.projectsinmetal.com">ProjectsInMetal.com</a>?<br/><br/>I'm always looking for fun projects to add to the site and I think my readers would get a kick out of yours. I already have plans for a screwless toolmaker's vise, but not for a vise like yours. <br/><br/>You can let me know by clicking on my name here and sending me a private message, or by visiting my site and filling out the contact form.<br/><br/>Thanks in advance!<br/>
rimar2000 says: May 9, 2008. 5:08 AM
Excellent. Good design, good work. Congratulations. The low profile is indispensable many times.
threesixesinarow (author) in reply to rimar2000May 9, 2008. 8:16 AM
Thanks. Can you believe I still have to use parallels to raise workpieces a lot of the time.
Hands Without Shadows says: May 8, 2008. 5:03 PM
Its better to have a tall vice, that way you can use it with big and small parts.
threesixesinarow (author) in reply to Hands Without ShadowsMay 9, 2008. 8:05 AM
The inexpensive bigger ones don't look bad and the way the jaw works lets me cheat a little on size like you can see in the main photo. At least it doesn't take so much space when I'm not using it. This might give an idea the size of mine compared with the one originally sold for the Atlas - that machine is big and heavy but I think its working range is even smaller than on the X1 micromill!
darkmuskrat says: May 8, 2008. 4:11 PM
Cool man, would be perfect on my drill press
threesixesinarow (author) in reply to darkmuskratMay 9, 2008. 7:52 AM
With vises like the bigger ones in the pictures here you only have to worry about drilling into the base and not the clamping screw as well...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
