Broken LCD monitors basically come in three categories:
1) Cracked LCD panel, rendering the unit completely worthless
2) Backlight problem
3) Power supply problem
If it's a backlight or power supply problem, it can be fixed.
Usually, the problem stems from the high voltage inverter circuitry, either bad power transistors, capacitors, or thermal stress on the circuit board leading to broken solder joints.
But fixing these problems can often be a short term solution. The bulbs themselves have a limited lifespan, and the high voltage power supplies are prone to failure.
The panels themselves almost always outlive the backlights and high voltage power supplies.
The 17" Dell LCD monitor I found was no exception. When I first plugged it in, it would cycle power on and off continuously, with a notable burning smell. Further inspection revealed a fried power transistor. When i replaced it, the monitor stayed on, but the backlight would flicker on and off, then finally shut off after a few seconds..
The panel was good, but trying to fix the backlight with the proper parts wasn't really worth it.
But maybe I could still save it, or even make it better. After all, it's just a light. Lights should be user-replaceable things anyway.
I mean, a Lite-Brite was the cheapest toy, yet you could at least change the bulb.
So here's the result of my experiment, with help from an old CRT monitor:
Remove these ads by
Signing UpStep 1Go to trash, locate a CRT monitor
Install a light bulb socket about 1/2 way back. I used switching socket from an old lamp.
(for the bulb, I used a 60w-equivalent "daylight"/6500k CFL bulb. It has a blueish glow to it. )
::Blank Stare::
The new bulb will cost about $10, $70 was the LED substitute for the cold florescent, but I still wouldn't install one. I don't even like taking them out. I ended up buying a foot of white LEDs from a novelty lighting site for about $8 and it works great. Right now I'm powering the back-light separately with an un-used plug from my computer's power unit.
For an estetic look try try to put 12mm fluorescent bulbs ( like in emergency light {EXIT} ) inside the original case, and the inverter for that lamps put it with wire in a separatly box :)
Announcing the lightest CRT ( ish ) monitor ever! :P
Have you thought of a strobe? ( NOT for epileptics )
I am so happy i can use them now
Sweet job!!!!!!!!!!!!!!
The ambient lighting in the last picture is pretty cool though, something people would probably pay extra for on a store-bought monitor.
